100 octane
Discussion in 'SRT Hellcat General Discussions' started by DNTBTHR, Jun 20, 2016.
  1. DNTBTHR
    DNTBTHR Silver Member
    Dec 4, 2014
    367
    77
    I live in Michigan with 93 octane but would like to add some race gas I have 100 octane available how much can I add to the tank I'm completely stock
  2. NorCaletch19He77Kat
    Aug 30, 2015
    960
    294
    173
    as much as you want..
    a full tank if you want--the question is do you go slower or faster..
    I would say slower without a proper tune..
    sure smells good though!
  3. sledguy
    sledguy SRT Hellcat Supporter Gold Supporting Member
    Sep 6, 2014
    739
    204
    Idaho
    There is a lot of confusion as to what octane numbers represent ~ in part it is the
    measure of the ignition quality of gas. Higher this number, the less susceptible is the gas to 'knocking' (explosion caused by its premature burning in the combustion chamber) when burnt in a standard (spark-ignition internal combustion) engine.
  4. DNTBTHR
    Dec 4, 2014
    367
    77
    Thanks
  5. hellcat buyer
    hellcat buyer Silver Member
    Aug 26, 2015
    128
    74
    198
    I'm not sure a full retune is needed. If you filled up with race gas the knock sensors would slowly "learn" that more timing & boost, or at least less retard, is available. The process we used with Turbo Buicks to speed up the process was to disconnect the computer power lead and/or fuse so the memory of the 93 octane settings is erased; It will quickly learn 100 is available and adjust boost & timing accordingly. I have no technical expertise with the Hellcat yet but I think it will work. Same process discussed heavily on Camaro5 when Zl1s were treated to a full tank of 87 octane regular by incompetent dealer employees upon delivery. Seemed to happen quite often. This whole discussion is predicated on 100 octane UNLEADED being the gas you are contemplating. Leaded will immediately destroy cats, O2 sensors, and more. VP Unleaded 101 is pretty common around here for about $8.50/ gallon. In the Buick I'll get two years out of a tank. I don't think the Hellcat will be that kind pumping a gallon a minute a WOT. Bring a big credit card. Last fill up was $134.00. Norcalkat is right; it has a very sweet smell.
  6. clickr
    clickr Silver Member
    Apr 18, 2015
    384
    120
    Here in NC there is a station that sells NON-Ethanol or pure gas 93 octane, I can tell a difference in my k1600 BMW motorcycle. Maybe try a tank of this stuff if you can find it.
  7. Catless
    Catless Silver Member
    Feb 2, 2015
    1,027
    209
    198
    Parkersburg, WV
  8. pinetreecat
    pinetreecat Gold Member
    May 31, 2015
    716
    337
    If you have over 500 miles on, and you are into some track stuff go ahead and try it. We are going to assume without a tune that your car will be slightly slower because the higher octane will be colder burning in the car (for lack of a better expression ). Not much. But some. Like maybe a half car length in the quarter? Not enough to feel, but noticeable in a side by side race.
    Maybe spend the extra cash elsewhere. $2.80 GAL for 93 vs $8.00 plus for 100?
    Gpod luck and drive safe.
