109 fuel
Discussion in 'SRT Hellcat Performance' started by Baddkty, May 31, 2016.
  1. Baddkty
    Baddkty Senior Hellcat Member
    May 1, 2016
    81
    33
    hey guys. When the hellcat was first hitting the streets in Detroit, I heard a lot of guys running stock cars with 109 fuel. Guess it was supposed to bump timing? What's the story on this... Does it do anything? Any hurt to the car?
    thx guys
  2. speedycat
    speedycat VIP Hellcat Member
    May 11, 2016
    231
    72
    98
    Texas
    Not much benefit for gas over 93 octane unless you tune for it. But if you are worried about the quality of you fuel then adding some 109 in would help reduce knock if you have any.
  3. themarshall
    themarshall Silver Member Hellcat Car Club Gold Supporting Member HCC Charter Member
    Feb 3, 2015
    229
    50
    speedycat is right, in my cat it did help with a slight drop in e.t. about 1/10 and a bump in mph about 2 mph. 50% load fuel, computer will not sence knock, computer(s) would alow more adv.
  4. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    680
    226
    On a stock tune 109 mixed 50/50 just makes up for the any bad 93 in your local pump. Gets you all the 93 tune available. You need to up the tune to take advantage of MS 109.
  5. Milspec
    Milspec Silver Member
    Feb 15, 2015
    206
    43
    So just to clarify the stock maf sensor will not adjust for ms109 octane fuel?
  6. SUPERCOOLSRT
    SUPERCOOLSRT VIP Hellcat Member
    Nov 18, 2015
    128
    62
    98
    Huntington Beach, ca
    i run 109 sometimes, helps w about 2 tenths at the track.
    u must put equal amounts of pump gas in or more or car might go into limp mode
    for example 5 galons 109 w 6 of 91/93 shouls be fine.
    if goes into limp mode u then must drive around and burn gas off
    also give car 10 minutes of driving to get used to the 109 in system before racing.
    njoy
  7. TNCHARGER
    Nov 19, 2015
    1,173
    426
    258
    Did you have issues running straight 109? I have ran it my HC and 2013 SRT and never had any issues. Never heard of anyone having issues running straight 109...you are talking about VP MS-109 which is 105 octane unleaded?
Similar Threads
  1. Dragon
    106
    13,204
  2. Badbeatbee
    16
    1,195
  3. NickJ
    14
    650
  4. kphillbilly
    14
    1,229
  5. dancap3286
    26
    2,200
Loading...
