12V Switched Power from Rear View Mirror
Discussion in 'SRT Hellcat Electronics' started by IA_Cat, Apr 19, 2015.
  1. IA_Cat
    IA_Cat Silver Member
    Oct 22, 2014
    150
    49
    Yesterday I decided to install my new Passport Max2 radar detector. I used the blend mount, which is well-made. For power we used t-taps on the black and pink wires on the mirror connector. Black was ground. All of the other wires we found up there did some funky 2V to 6V stuff during power cycles, which could harm a radar detector.
    To gain access, we removed the large black plastic piece that sits behind the mirror, against the windshield. To remove it just pull and rock it left and right.
    Hope this helps someone else.
    • Useful Useful x 11
  2. B5 Blue
    1,748
    Thanks;)
  3. djtomy
    djtomy Rookie
    Aug 30, 2015
    10
    1
    FL
    Anyone had there mirror pop off? while installing a radar mount? how the heck do I get it back on the windshield tab?
  4. Slowhand
    Slowhand Gold Member
    Jan 26, 2015
    606
    266
    Maryland by the bay
    Yeah. My mirror just popped off. Not going back easily either.
  5. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    Should a real small allen screw on it
  6. Slowhand
    Jan 26, 2015
    606
    266
    Maryland by the bay
    Has three bent spring tabs that clasp the head of a pentagonal bolt. There is also a locating nub that fits in a notch. The only screw going in is on the inside..
  7. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,700
    769
    633
    greasy cardboard box
    - place the rearview mirror over the mirror button (part glued to the windshield).
    - Grasp the mirror by the base and rotate it approximately 90 degrees counter-clockwise until the mirror locks into place.
    NOTE: The mirror must be fully seated onto the button before rotating.
    • Useful Useful x 2
  8. Slowhand
    Jan 26, 2015
    606
    266
    Maryland by the bay
    Thanks! I'll try 1st thing in the morning..
  9. fnkychkn
    Jan 24, 2015
    1,700
    769
    633
    best to get the windshield good and hot before attempting this. also, a helper pushing back from the outside might help because simple hand pressure from the inside can crack a cold windshield.
    • Useful Useful x 2
  10. djtomy
    djtomy Rookie
    Aug 30, 2015
    10
    1
    FL
    It has spring clips, and 5 sides. I did it by myself, You have to start with the mirror turned 9 o'clock position (or 3 o'clock) then press hard!!! while pressing, turn it to the 12 o'clock position, its difficult, I had to take all the plastic covers off to get it on... but I finally got it! I actually had to do this twice! hope this helps
    • Useful Useful x 2
  11. Slowhand
    Jan 26, 2015
    606
    266
    Maryland by the bay
    I'm at the dealership now fr oil change and CEL. They're looking at mirror also. And there's a new silver Hellcat Charger here, unwashed. Built for Richard Wagner.
  12. Slowhand
    Jan 26, 2015
    606
    266
    Maryland by the bay
    Oil change-check. Reattached rear-view mirror-check. Checked P062A code for check engine light. Said they found nothing, bring it in when the light is on. I explained that getting an appointment after the light is on -well, the light goes off before they can fit you in. Rep says "call me next time, we'll get it setup". Light came on while driving home. They want me to come by in 2 days. SMH.
12v from rearview mirror
2016 challenger rearveiw mirror
how to remove rear view mirror on 2015 charger
is there 12v power in my rear view mirror
rear view mirror popped out off challenger
rear view mirror with 12volt light attachment
reattach review mirro dodge dart
