12volts for radar detector
Discussion in 'Dodge Challenger SRT Hellcat' started by Sublimecat, Jan 2, 2015.
  1. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    901
    318
    173
    Akron, Ohio
    Has anyone figured out where to get 12volts for a permanently installed radar detector harness? I would take it off the back of the accessory plug on the passenger compartment if I could figure out how to get to it.
  2. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    You can use power from mirror
  3. Jim Hetrick
    Jim Hetrick Silver Member
    Dec 5, 2014
    1,338
    263
    108
    Orange County Cal
    Do you want switched power or non switched power??
  4. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    805
    563
    If you wire to mirror will only have 12 volts when car get started or ignition mode
  5. Jim Hetrick
    Dec 5, 2014
    1,338
    263
    108
    Orange County Cal
    That what I would suggest
  6. Sublimecat
    Oct 2, 2014
    901
    318
    173
    Akron, Ohio
    Switched power if possible. I have a Passport 9500IX with a smartcord. The cord allows control of the detector from a button that gets mounted to on the dash or console area. The power needs to go through the button, up the A pillar and to the detector if possible.
  7. LITSOUT
    LITSOUT Gold Member
    Jan 1, 2015
    147
    90
    278
    Va Beach
    +1 on the switched mirror power which I assume the HC has. I did it on my JGC. What a PITA to get the mirror assembly on/off. I'm hoping the HC is easier. I use the invisicord (link below)
    My Bell Sti is hidden under my visor in a cheapo organizer. Though I can't see the display (good for stealth in the great state of VA) I can hear everything I need...
    Invisicord - Installation
    Matt
  8. LITSOUT
    LITSOUT Gold Member
    Jan 1, 2015
    147
    90
    278
    Va Beach
    Just found this.. Looks like there is an access panel in the rear of the mirror so the whole assembly doesn't have to come off.. easy..
  9. Jim Hetrick
    Dec 5, 2014
    1,338
    263
    108
    Orange County Cal
    look for the mirror wire from under the dash
  10. Sublimecat
    Oct 2, 2014
    901
    318
    173
    Akron, Ohio
    Have you looked under the dash. This car is sealed up tighter than a drum. I am going to start tearing the interior apart tomorrow. I would like to remove the center console and get the power from the outlet and run the smart cord. I can't figure out how the console attaches under the dash.
  11. gts_2001
    gts_2001 Gold Member
    Dec 7, 2014
    1,332
    394
    358
    Grand Rapids, MI
    I have been using Valentine 1's in all of my cars for years. Consider hanging your Valentine 1 off of the driver side visor and running a standard telephone cable (with choice of colors) along the upper windshield under the headliner (very easy to tuck it under). Next, tuck the cable under the upper edge of the A Pillar molding then tuck it under the rubber stripping between the A Pillar and the door. Bring the cable all the way down to lower dash level and route under the dashboard. Once you reach the console, you may need a wire snake from the passenger side to bring it through (a standard hanger wire will also work). Bring cable over to passenger side of console, tuck under vinyl panel (lower edge where carpeting comes up) then route upwards to the 12V plug. (I assume you have the Stealth module). It maks for a nice, tidy, professional installation that takes about 15 minutes. With this method, no need to tear anything apart! Alternatively, one could route the cable between the head liner and windshield (again tucking the wire under the head liner) toward the A Pillar on the passenger side and use the same method described above for coming down the A Pillar, as well. The only car that I have that this didn't work is my Porsche. The reason it didn't work is because of head room and proximity to the sun visor. I had to go with a K-40 installation for that car. Personally, I think the Valentine 1 is a better radar detector. One last suggestion for mounting the V1 on the Sun Visor: Turn the metal clip / mount around "backwards" when attaching to th V1, then slide it on to the leading (front) edge of the visor rather than the trailing (rear) edge of the visor. It stays positioned much more securely using that method.
  12. MoparGuy1
    MoparGuy1 Senior Hellcat Member
    Nov 8, 2014
    123
    30
    Pennsylvania
    I have exactly the same setup. I just ran an invisicord to the mirror and hung the 9500ix off the mirror with a Blendmount. Quick, easy, and out of the way.
  13. magnummrk
    magnummrk SRT Hellcat Supporter Gold Supporting Member
    Sep 30, 2014
    3,825
    1,109
    918
    Wisconsin
    I was debating how to mount my radar detector for a while. I have always had it in the center off the dash at the bottom of the windshield with he cord running down to the outlet. With the Hellcat I really did not want that again. I really wanted it on the driver side of the windshield, but with he curve of the windshield it was a problem. Thursday I bought 2 extra windshield mounts and cut one of them and welded in a small piece of metal that allows the detector to pointing in the right direction. I have the cord running under the steering column and up to the detector. I wanted to keep the mute button on the cord of the detector.
  14. Sublimecat
    Oct 2, 2014
    901
    318
    173
    Akron, Ohio
    I got the console out this morning. Very similar to previous years. Lift shifter boot with a trim tool, unbolt shifter handle, remove console center section with a trim tool, unplug heater control panel harness. Remove plastic trim panels in the rear of the console and the two bolts. Remove the two screws in the front that are now accessible from removing the center section. Console slides to the rear for 1-2 inches. Unplug remaining two wiring harness plugs at the fron of the console and it can be lifted out.
    You need a trim tool, 10mm and 7mm socket to remove the console. Once out, I spliced the radar detector harness into the passenger side power outlet harness. Black wire with white stripe is ground, pink wire with orange stripe is switched power. I ran the smart cord underneath r the passenger dash, up the A pulled, underneath the head liner and to the detector hanging off the mirror with a blend mount. Worked like a champ.
  15. tsc
    tsc SRT Hellcat Enthusiast
    Oct 27, 2014
    1,520
    696
    563
    Cincinnati, OH
    I figured it would be similar to previous models. Thanks for the confirmation!
radar detector switched 12 volts
switched 12v hellcat
