17" Weld drag wheel fitment confirmed!
Discussion in 'SRT Hellcat Wheels and Tires' started by CasualObserver, Apr 14, 2015.
  1. CasualObserver
    CasualObserver Senior Hellcat Member
    Feb 7, 2015
    100
    55
    68
    I just got a set of 17x9 Weld S77 (30mm) wheels delivered. They fit the back great with no issues. I am having a set of M&H Racemaster drag radials mounted on them tomorrow.
    Besides the obvious advantage of the taller sidewall and larger contact patch; the weight savings are significant.
    Stock Hellcat wheel tire with ~300 miles = 64.5LBS
    Weld s77 17x9 wheel = 21 LBS.
    Brand new M&H Racemaster 17"x275 = 30.9 LBS.
    Roughly 52 LBS for the combo for a savings of 12.5 LBS per wheel. Any time you can up traction and save 25LBS in wheels/tires is a great day! I fully expect to 60ft better than any 20" drag radial, and to do so with less shock loading to the drive train.
    And without further adieu Pictures!
    • Like Like x 3
    • Useful Useful x 3
  2. Ohiotj
    Ohiotj Silver Member
    Nov 29, 2014
    372
    118
    Thanks for posting this. Do you think a 17x10 rim would have fit?
  3. CasualObserver
    Feb 7, 2015
    100
    55
    68
    If the offset stayd the same the wheel would get very close to the swaybar. It has roughly .5" of clearance as is. I think you could squeeze it in if the extra inch was added to the outboard more. Maybe you could run a 325 then?
  4. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,066
    652
    413
    So Cal
    275 & 28" tire on a 17" rim ? I think you would have been better off with a 305 & 29" tire on a 18" rim but looks like a nice wheels just no 29" tires in 17" sizes avail.
  5. CasualObserver
    Feb 7, 2015
    100
    55
    68
    It's all about saving weight, I'd go 16" if I could. Also the shorter tire lowers the final drive a touch.on
  6. B5 Blue
    1,747
    Hoosier has 28x10x17 24lbs not radial tho
  7. CasualObserver
    Feb 7, 2015
    100
    55
    68
    I got the tires Mounted yesterday. They look seriously meaty in these wheels. As soon as I have a chance to put them in the challenger I'll post pictures.
    DAT Sidewall...
    • Like Like x 3
  8. Billet Hellcat
    Dec 2, 2014
    1,066
    652
    413
    So Cal
    Those look great would like to see them on the HC ;)
  9. CasualObserver
    Feb 7, 2015
    100
    55
    68
    Working on it!
  10. CasualObserver
    Feb 7, 2015
    100
    55
    68
    Pics as promised! The combo worked fairly well. On the cars first trip to the strip we got a 1.635 60ft out of them to yield a 10.985@127. With a bit more heat in the tires and a cooler day I think there is more left in it. Very happy so far with this setup.
    • Like Like x 3
    • Useful Useful x 2
  11. DGatzby
    Jan 16, 2015
    3,721
    1,990
    748
    Twin Cities, MN
    Nice write up/pics. Question, did you go to the drags yesterday with the OEM driveshaft still on your car?
  12. CasualObserver
    Feb 7, 2015
    100
    55
    68
    The OEM shaft was on the car and stayed that way!;-). Having a setup with a smaller wheel and taller sidewall helps with the shock that breaks things. I don't anticipate braking a shaft. If I do, oh well.
  13. DGatzby
    Jan 16, 2015
    3,721
    1,990
    748
    Twin Cities, MN
    Ok thanks. I am hesitating going with the 20" DR's with the history we have been reading, until the drive shaft moves up on my priority and spending lists. My favorite strip is 120 miles away, getting stranded up there will not be good.
  14. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    Why would you not go with a wider wheel than stock? I too want more sidewall, but I also want more width. Would a 17x10.5 or 17x11 not fit?
  15. CasualObserver
    Feb 7, 2015
    100
    55
    68
    Given I had heard of no fitment at all for a 17" wheel I elected to play it safe. Also, even though it is 9" wide the extra contact patch I get is huge due to the taller sidewalk. When warmed up I can stomp the gas pedal at the track without wheel spin. Putting an unnecessarily wide wheel/tire on the car only adds weight. If I run into a situation where I can't put power down I'll look elsewhere for wheels.
17 inch weld s77
charger hellcat weld wheels
dodge charger weld wheels
dodge ram wheels drag
drag wheels for the hellcat
hellcat 17 wheels
hellcat drag radials
srt challenger with weld rts s77 wheels
