20 x 10's in front?
Discussion in 'SRT Hellcat Wheels and Tires' started by Driver72, Mar 22, 2015.
  1. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,212
    280
    Anybody do that yet?
    There doesn't seem to be a lot of room between stock wheel and upper suspension arm (or whatever that thing is that bends around the upper part of the tire).
    So if someone was to go to a 20 x 10 wheel up front with the same offset as stock I'm guessing it would be VERY close to rubbing.
  2. Driver72
    Mar 10, 2015
    1,212
    280
    20 x 10
    25 mm offset
    suppose to put wheel 13 mm (1/2") closer to suspension parts, but rimsntires calculator says it would be 7 mm (1/3") closer overall with stock tire.
    7mm closer would clear no problem and I'd be super happy if that was the case.
    13mm would be REALLY close.
    I can put my finger between the upper suspension part and the tire, but it's tight.
    Seems that space is just a bit more than 1/2 inch.
    But I'd be worried with only a few millimeters space.
    What do you guys think?
