2015+ Dodge Challenger Hellcat RGBW Multicolor LED Boards! Factory "Halo" Upgrade!
Discussion in 'Diode Dynamics' started by Diode Dynamics, Jun 23, 2015.
  1. Diode Dynamics
    Diode Dynamics Silver Member Hellcat Supporting Vendor
    Jun 8, 2015
    361
    83
    St. Louis, MIssouri
    [​IMG]
    [​IMG]
    2015+ Dodge Challenger Hellcat DRL LED Boards
    Upgrade your Challenger Hellcat's factory angel eyes with these drop-in RGBW multicolor replacement LEDs! These modules are a direct replacement for the factory-installed LED panels in the 2015+ Dodge Challenger. Your order includes a full set of panels, as well as drivers to safely and reliably power them.
    From the factory, the halo rings in the headlight are illuminated by small 1210-size white LEDs. Our multicolor board is designed with high-power RGBW LEDs, as a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
    Made in USA, the replacement panels utilize RGBW LED chips. Each one illuminates with red, blue, green, and 6500K white. The multicolor function allows for full multicolor control using any standard common-anode RGB or RGBW controller (not included).
    Remember, this product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
    To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
    There is a standard RGBW input plug (5-pin) to connect to your RGBW controller. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty.
    Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
    All Diode Dynamics products are backed by a 3-year replacement warranty.
    2015+ Dodge Challenger LED Boards
    If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Nick C.
    Diode Dynamics
    [​IMG]
    • Winner Winner x 2
  2. Diode Dynamics
    Jun 8, 2015
    361
    83
    St. Louis, MIssouri
  3. Bascadog
    Bascadog Silver Member
    Mar 15, 2015
    422
    176
    Southern Ca
    For installation do you have authorized dealers? anyone you can recommend to install this kit on my HC in Ventura County Ca?
    Thanks
  4. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    Any installer in metro Detroit...
  5. Next Phase
    Next Phase Silver Member
    Oct 22, 2014
    908
    301
    173
    I missed it.... What's the $$$?
  6. jayp
    jayp Silver Member
    Mar 28, 2015
    133
    54
    Anything for charger..if so i want them like yesterday. ..in metro detroit...need installer too!!
  7. Diode Dynamics
    Jun 8, 2015
    361
    83
    St. Louis, MIssouri
  8. Bascadog
    Mar 15, 2015
    422
    176
    Southern Ca
    Guess only some people get their questions answered huh
    • Funny Funny x 1
  9. Diode Dynamics
    Jun 8, 2015
    361
    83
    St. Louis, MIssouri
    We have a dealer locator tool here on our site: Dealer Locator
    Feel free to give us a call if you need any suggestions: (314) 205-3033
    Thanks!
    Nick C.
  10. THEONE
    THEONE Hellcat Member
    Aug 29, 2014
    83
    24
    Pensacola, FL
    Hello,
    Do you have a wiring solution where your kit can be used and still have the daytime run and parking lights work from the cars factory controls? I'm interested in the kit but I want more of stealth install until I use it.
    v/r
    Dan
  11. Diode Dynamics
    Jun 8, 2015
    361
    83
    St. Louis, MIssouri
    Dan,
    The kit can be wired to function the same as the factory units. Nobody would know you had them installed until you change the color with the remote
    The white is also better looking than the factory white IMO
    Nick C.
  12. owenspackman
    owenspackman BritishCat
    Feb 11, 2015
    972
    511
    368
    Charleston SC
    you didn't miss the price. They just ignored your request. this isn't on their website either......
  13. Diode Dynamics
    Jun 8, 2015
    361
    83
    St. Louis, MIssouri
  14. Diode Dynamics
    Jun 8, 2015
    361
    83
    St. Louis, MIssouri
    The 2015+ Charger boards have already been designed and should be available within the next few weeks
    We are looking for a 2015+ Charger here in St. Louis to bring into our studio for comparison photos and installation videos
    If you are local to us, and are interested in receiving free-products for your 2015+ Charger, please give us a call: (314) 205-3033
    Thanks!
    Nick C.
  15. Deputydog
    Deputydog Gold Member
    Nov 2, 2014
    1,002
    261
    Spokane, Washington
    They are illegal to use on the streets in any color other than white or amber just FYI, but are way cool anyway.
2015 dodge challenger rgbw lights
2015 dodge charger hellcat angel eyes
angel eyes on hellcat
dodge challenger hellcat diode
halo lights for 2012 charger sold in ventura county
hellcat with red led headlights what is it
how to brighten halo headlights on a 2015 dodge challenger
make challenger halos brighter 2015
