2015+ Dodge Challenger SRT8 Fog Light LED Bulbs! Install Video! Match Factory Halos!
Discussion in 'Diode Dynamics' started by Diode Dynamics, Jun 10, 2015.
  1. Diode Dynamics
    Diode Dynamics Silver Member Hellcat Supporting Vendor
    Jun 8, 2015
    356
    81
    St. Louis, MIssouri
    [​IMG]
    We carry LED bulbs for replacement of your Challenger's fog lights. They are available in HP, XP, and XML styles. This will make your fog lights a nice bright white that closely matches factory HIDs and Halos!
    We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
    QUALITY
    LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means we use only brand-name suppliers such as CREE, Epistar, Cree, Osram, and Samsung.
    While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
    Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
    Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
    Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
    All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
    BRIGHTNESS
    Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
    HP48: 265 lumens. Slightly lower brightness than factory
    XP80: 510 lumens. Similar brightness to factory.
    XML2: 1410 lumens. Much brighter than factory. These are bright!
    *XML2 available in 4000K / 5000K / 6000K color temperatures
    Please note that most LED fog lights are intended for cosmetic purposes only, and will not project light in the same way that the factory bulbs do. Your car will look great at night, but if you are looking for higher output, we strongly recommend using an HID conversion.
    [​IMG]
    Bulb Design
    HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
    XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
    XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
    These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
    Included in your order is TWO BULBS (to fit your 2015+ SRT8 Challenger).
    All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
    Click below for more info or to order:
    2015+ Dodge SRT8 Challenger
    If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Nick C.
  2. FA5T CAT
    FA5T CAT Silver Member
    Feb 16, 2015
    460
    180
    Santa Clarita, California
    Hellcats don't have foglights
    • Funny Funny x 1
  3. Diode Dynamics
    Jun 8, 2015
    356
    81
    St. Louis, MIssouri
    I know, but I noticed there was a section on the forum for SRT8 owners
    Nick C.
  4. FA5T CAT
    Feb 16, 2015
    460
    180
    Cool product.... Hope you guys do well.
  5. Diode Dynamics
    Jun 8, 2015
    356
    81
    St. Louis, MIssouri
    Thank you!
    We are very excited to show everyone what we've been working on for the Hellcats
    Nick C.
  6. FA5T CAT
    Feb 16, 2015
    460
    180
    When do you anticipate releasing your hellcat product(s)?
  7. Diode Dynamics
    Jun 8, 2015
    356
    81
    St. Louis, MIssouri
    The Hellcat Challenger products have already been released, but we are still working on the Charger's
    Nick C.
  8. FA5T CAT
    Feb 16, 2015
    460
    180
    What site can i go to in order to see your challenger hellcat products?
  9. Diode Dynamics
    Jun 8, 2015
    356
    81
    St. Louis, MIssouri
    They are listed here on our site for 2015+ Challengers: Dodge Challenger LED and HID Lighting
    Feel free to give us a call if you have any questions: (314) 205-3033
    Thanks,
    Nick C.
  10. FA5T CAT
    Feb 16, 2015
    460
    180
    Thanks!
  11. Diode Dynamics
    Jun 8, 2015
    356
    81
    St. Louis, MIssouri
    You're welcome!
    Nick C.
  12. Diode Dynamics
    Jun 8, 2015
    356
    81
    St. Louis, MIssouri
    [​IMG]
    Diode Dynamics is pleased to announce a new color for our popular XML2 fog light -YELLOW (3000K)! The XML2 utilizes genuine CREE XML2 components, for a true, measured output of 1,420 lumens. 100% plug-and-play. Sizes available include 9005, 9006, H8, H10, H11, H16, and PSX24W.
    Thanks!
    Nick C.
2015 challenger fog light bulb
2015 dodge challeneger hid foglights
2015 dodge challenger fog lights
diode dynamics led fog lights are intended for cosmetic purposes only
fog light led
green led fog lights for a 2015 challenger
halos for 2015 charger srt fog lights
hid fog 2016 challenger
