2015+ Dodge Charger Hellcat RGBW Multicolor LED Boards! Factory DRL Upgrade! See Install Video
Discussion in 'Diode Dynamics' started by Diode Dynamics, Oct 1, 2015.
  1. Diode Dynamics
    Diode Dynamics Silver Member Hellcat Supporting Vendor
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    [​IMG]
    [​IMG]
    2015+ Dodge Charger Hellcat DRL LED Boards
    Upgrade your Charger Hellcat's factory DRLs with these drop-in RGBW multicolor replacement LEDs! These modules are a direct replacement for the factory-installed LED panels in the 2015+ Dodge Charger. Your order includes a full set of panels, as well as drivers to safely and reliably power them.
    From the factory, the halo rings in the headlight are illuminated by small 1210-size white LEDs. Our multicolor board is designed with high-power RGBW LEDs, as a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
    Made in USA, the replacement panels utilize RGBW LED chips. Each one illuminates with red, blue, green, and 6500K white. The multicolor function allows for full multicolor control using any standard common-anode RGB or RGBW controller (not included).
    Remember, this product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
    To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
    There is a standard RGBW input plug (5-pin) to connect to your RGBW controller. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty.
    Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
    All Diode Dynamics products are backed by a 3-year replacement warranty.
    2015+ Dodge Charger RGBW LED Boards
    If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
    *PM us for the free-shipping code* (U.S. forum members only)
    Thanks for looking!
    Nick C.
    Diode Dynamics
    [​IMG]
  2. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    [​IMG]
  3. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    [​IMG]
  4. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    [​IMG]
  5. SuperChallenger
    SuperChallenger Hellcat Member
    Jul 23, 2015
    41
    13
    im pretty sure some colors are unlawful to use...red / blue up front comes to mind.
    Superchallenger
  6. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    Correct! Which is why our LED board replacements utilize RGBW LEDs. In addition to having all the colors, they produce a brighter and crisper white than the factory LEDs:
    [​IMG]
    We recommend keeping them on white for on-road use, and saving the colors for shows
    Nick C.
  7. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    Here's an example of the white setting on the Charger replacements:
    [​IMG]
    Nick C.
  8. SuperChallenger
    Jul 23, 2015
    41
    13
    not trying to bash your product or anything close to that, but your pics show red and blue front facing which I dont think are lawful to use. pretty sure those are restricted to fire/ems/cops. could get someone is serious trouble if they didnt know that and ran down the road that way
  9. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    We always inform customers to check their local laws before running colors, and indeed running red and blue on the road is not advised. Luckily, our product features RGBW, so you retain the ability to leave them on white. No other vendor's product utilizes RGBW, or is manufactured in the United States.
    Here's more information about the RGBW LEDs used: Automotive Lighting Manufacturer First to Utilize Revolutionary New LEDs | Diode Blog
    Thanks!
    Nick C.
  10. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    [​IMG]
  11. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    [​IMG]
  12. zippy
    zippy Silver Member
    Feb 2, 2015
    359
    135
    Ontario
    very cool indeed
    I want to do this and have the capability, I am just hesitant to separate the headlight assembly
    Never done it before. I think you need to heat it up and then subsequently re-seal it
    I would have no issue with wiring board replacement etc.
    uugh
  13. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    You do have to heat up the housings to separate the lenses. If you don't want to attempt the install yourself, I suggest checking out our dealer locator tool: Dealer Locator
    We can help you find a dealer to install them: (314) 205-3033
    Nick C.
  14. Diode Dynamics
    Jun 8, 2015
    410
    86
    St. Louis, MIssouri
    [​IMG]
    Posted up next to our 2015 Mustang (headed off to SEMA today!)
    Nick C.
  15. coachaward
    coachaward SRT Hellcat Supporter Gold Supporting Member
    Jul 30, 2015
    45
    16
    How does this affect warranty? I'd presume this voids warranty.
charger hellcat drl lights
charger hellcat led headlight
color changing halo headlights i n hellcat
diode dynamics 2016 charger instsll
diode dynamics rgbw charger
dodge charger rgbw drl halo
hellcat charger with halo lights
rgbw diode not bright as factory
