2015 Hellcat and SRT Axles now available
Discussion in 'Driveshaft Shop' started by Driveshaft Shop, Mar 23, 2016.
  1. Driveshaft Shop
    Driveshaft Shop Gold Member Hellcat Supporting Vendor
    Nov 17, 2015
    176
    113
    RA7285X5----------2015+ HELLCAT/392 1400HP DIRECT-FIT LEVEL 5 AXLE (MUST RE-USE FACTORY TONE RING) (2 Per car) *Torque Outer Bolts to 50ft.lbs*-------------- 1599.99
    [​IMG]
    So the 2015 Hellcat/SRT is a new platform by Mopar and its nicely done. The axle is closer to an aftermarket performance axle in design but has an interesting twist, there actually quite strong with some Hellcats hitting the 900hp range before breakage. Like any axle we look to make here at DSS, we always open the axle up for the critical dimensions but also to see what was done by the manufacturer to make this new 2015+ model better than the earlier style it’s replacing. They don’t disappoint (maybe us a little, but not you if you or are getting one) but guessing what HP they can handle? This sort of thing is always hard, but like all OE's they have come to realize the axles have to be better and this one is. We found the bars and internals are Big, in the fact that not only the internal splines are much larger but the CV parts themselves are along with the splines into the diff and the spindle. Most CV's are done in series and this one is the same as what can be found on Vipers, Lamborghini's and a few other high end, high HP cars. what DSS has decided to do for this is start with our exclusive Billet 2 piece design incorporating 300m Stubs into Chromoly hats to give the best strength/cost factor you can get. The Axle bars will be larger, the one on this axle is a bit bigger then the 06-08 and still bigger then the 09-14 and I’m going to make a guess that the axle may hold as much as 900HP+ ? The Driveshaft Shop axle will have the 300M Bars with rolled splines and ground centers that will allow the bars to torsionally twist but not break. We WILL NOT be making them in the Anti-Wheel hop style for this reason, with all the years and experience we have behind us we have come to realize the axles need to be the same diameter in high HP cars to ensure they are the same strength. Wheel hop should be addressed at the source (bushings, mounts, etc.) and when this is done correctly, you will need axles that will be of equal strength. Being this axle from the factory will more than likely handle so much power, it would un-wise to make the axles any other way in our opinion. So there you have it, a completely new Axle from DSS for the 2015+ SRT/Hellcat. All parts are made and ready to be assembled for you, if you’re planning to get past what we believe the stock axles will hold We do have the 9" IRS kit being made in a production run as you read this.
    The Driveshaft Shop
    4530 Southmark Dr
    Salisbury NC 28147
    (800)564-2244
    [​IMG]
  2. Hemi Rocket
    Hemi Rocket Gold Member
    Sep 27, 2015
    1,491
    Albany NY
    Nice to see more high quality parts coming out for our Cats. Kudo's to DSS! ;) I have to ask what is the difference between an Anti-Wheel hop style axle and standard axle? Is it two different diameter shafts vs two of equal diameter?
  3. Driveshaft Shop
    Nov 17, 2015
    176
    113
    yes, we have found out with Higher HP cars it just makes on strong axle and one weaker, one can twist well and the other not so much.
  4. Bossnova3
    Bossnova3 Silver Member
    Mar 31, 2015
    172
    70
    178
    Awesome on my list soon
  5. Bucks666
    Bucks666 Silver Member
    Apr 21, 2015
    169
    55
    Central Ohio
    In stock?
  6. Driveshaft Shop
    Nov 17, 2015
    176
    113
    yes, we have them and your favorite vendors already have them in stock also
  7. Bucks666
    Apr 21, 2015
    169
    55
    Central Ohio
    Perfect thank you !!
  8. mike@bwp
    mike@bwp Gold Member Hellcat Supporting Vendor
    Jul 20, 2015
    480
    297
    513
    Abingdon, Md
    Stock axle on the left DSS on the right
  9. Driveshaft Shop
    Nov 17, 2015
    176
    113
    Anyone know Edwin from this shop
    RB Tech
    1830 S. Figueroa St
    Los Angeles, CA 90015
