2016 A/C Failure at 10K miles, Yay!
Discussion in 'SRT Hellcat General Discussions' started by rwhite692, Jun 22, 2016.
  1. rwhite692
    rwhite692 Gold Member
    Jul 17, 2015
    652
    261
    Central Valley, Northern California
    Well, I have run into my very first issue with the car...
    My A/C is not working, all of the electronics are behaving normally, but the system is just blowing hot air. It was working fine the day before.
    Popped the hood to check to see what the A/C compressor is doing, and the clutch on the compressor is not engaging when the A/C is turned on.
    Checked all of the A/C related fuses, and all are OK.
    Going to the dealer tomorrow, so we'll see. Hopefully its something simple.
    Of course, here in CA we are entering a triple-digit heat wave, over the next week or so.
  2. 45colt
    45colt Gold Member
    Jan 17, 2015
    202
    100
    Alberta Canada
    We'll that sucks - Hope it is a quick fix
    Good luck to ya
  3. Deadcrustpunk
    Deadcrustpunk Senior Hellcat Member
    Jun 22, 2016
    80
    49
    I'm willing to bet either the coil on the clutch is toasted or there's a loose wire/harness if you have a voltimeter, you can see if it's the coil or not.
  4. rwhite692
    Jul 17, 2015
    652
    261
    Checked all the fuses, Not about to ohm out the clutch solenoid (its not all that easily accessible). I'm under warranty, so we'll see what they find tomorrow.
  5. Deadcrustpunk
    Jun 22, 2016
    80
    49
    If you pull the fuse out put your meter to resistance (ohms) and go to ground. Check which side of the fuse is power and then check the other to the frame, if it is under 1 ohm the coil is torched, if the meter reads open or OL the coil or wires are open.either way i'm with you on having them check it out, i usually do that stuff just for my own info, if you turn it on and you have no power on either side of the fuse cavity then the problem could be a much bigger headache- like a loose connection, or even an output module that has a bad channel-. Sorry this is what i do for a living. But checking resistance on any coil from a solenoid to an amplifier is pretty much the same thing. You wont hurt it at all-
    • Useful Useful x 2
  6. rwhite692
    Jul 17, 2015
    652
    261
    Yep I know how to check it, this just happened tonight...Need to get it fixed and have no time to mess with it...I did quickly check to see I had power at both sides of all the relevant fuses with my test light. But as you say, the clutch solenoid coil could be open.
    Everything I am reading says that the more likely culprit for A/C failure on the LX cars is the control module on the firewall which apparently has a pretty significant failure rate...
  7. Deadcrustpunk
    Jun 22, 2016
    80
    49
    I figured as much, i dont blame you. Our triple digit weather is really hitting us hard. These fires arent helping us either (sorry i am assuming you are in la,oc, or i.e.) you're making the right call-
    The failure of that control module just has disaster written all over it... alllll bad :( let us know how long your turnaround is-. I would like to know
  8. Catless
    Catless Silver Member
    Feb 2, 2015
    1,025
    209
    198
    Parkersburg, WV
    Could be lost Freon charge.
  9. Jungle Cat
    Jungle Cat Gold Member
    Feb 24, 2016
    1,141
    275
    258
    Ac? You don't need it. I thought you guys had dry heat?
    • Funny Funny x 5
  10. Fastcat ny
    Fastcat ny Silver Member
    Aug 24, 2015
    157
    61
    178
    Loss of freon . When the pressures become to high or low the system has pressure cutoff switches to prevent damage to the system . A simple set is gauges hooked up will tell the story. My guess is a small leak shouldn't be a big dea to fix and quick too.
  11. rwhite692
    Jul 17, 2015
    652
    261
    Dealer tech diagnosis is that the fault is with the ECM.
    The ECM controls the A/C compressor clutch and it is not sending out the GND output, to turn on the A/C clutch solenoid. They are overnighting a new ECM.
  12. Steppenwolf
    Steppenwolf Silver Member
    May 19, 2016
    1,125
    359
    Running hard ... in the Wasteland of my Mind.
    Glad to hear you got an answer to what caused it. Hoping not to have this issue on my 2016, but my area of the U.S. rarely sees the summer temps you do in Calif.
  13. Deadcrustpunk
    Jun 22, 2016
    80
    49
    Wow, you got your answer really quickly, bummer that it wound up being your control module, but the answer came fast
  14. rwhite692
    Jul 17, 2015
    652
    261
    So today, the new ECM comes in, they installed it.
    A/C compressor now turns..... and they discover that the high pressure side line, coming off the A/C compressor is leaking like crazy.
    Of course, there are no replacement lines available, because no one stocks anything.
    They ordered a new line and put my case as "VOR" (high priority) status.
    There are two other Hellcats nationwide that are sidelined with the exact same problem, also waiting for replacement lines (the lines are hellcat-specific), which have been shipped out from the line manufacturer, and are expected to make their way to dealers through the parts supply network early next week.
    The tech cannot explain the relationship between the apparent ECM issue (not engaging the compressor clutch) and the coolant leak.
    Perhaps the clutch driver circuit in the ECM failed, due to over-cycling, trying to keep up with the coolant leak?
    Such Fun!
  15. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    7,453
    4,772
    963
    if the system is low on charge it will not blow cold air and may only be slightly cold. if you say the compressor is coming on that is good I guess, refrig
