24 PSI Pirellis?
Discussion in 'SRT Hellcat Wheels and Tires' started by VanishingPoint, Apr 15, 2015.
  1. VanishingPoint
    VanishingPoint Gold Member
    Jan 6, 2015
    1,028
    261
    258
    Somewhere, Texas
    In the article "Slicks on a Brick" they lower the psi on the Pirelli's to 24 lbs to increase traction.
    Has anyone tried this yet?
  2. Carnage
    Sep 21, 2014
    12,107
    3,278
    823
    Houston, TX
    That's about 8 below recommended and I'm sure it would help but I haven't tried
  3. SRT_HC_707
    Jan 1, 2015
    4,968
    1,449
    70.196059, -148.559760
    I run mine at 39 PSI on the street (summer tires). Traction is fine and I think it handles a bit better.
    At the limits with the go pedal down you will break traction no matter what. Personally I don't like soft tires (unless I'm at a drag strip).
  4. DGatzby
    Jan 16, 2015
    3,705
    1,982
    748
    Twin Cities, MN
    Another thing if you drive around under inflated you could develop abnormal wear on the outside of the tires.
  5. VanishingPoint
    Jan 6, 2015
    1,028
    261
    258
    Somewhere, Texas
    The purpose was more traction at the strip, and I *think* it was an SRT tip passed along particular to this tire set.
    Was just curious if someone here had tried it...
  6. TxTorrnado
    TxTorrnado Rookie
    Dec 7, 2014
    19
    1
    Have you had any luck with the lower tire pressure yet? I took mine to the track with like 36psi and prob should have dropped them a bit.
    I think it would have helped.
  7. Dubya
    Dubya Silver Member
    Jan 3, 2015
    717
    202
    If I understand this correctly...it's a standard practice at the strip.
  8. VanishingPoint
    Jan 6, 2015
    1,028
    261
    258
    Somewhere, Texas
    No but it does maker sense.
  9. TxTorrnado
    TxTorrnado Rookie
    Dec 7, 2014
    19
    1
    If I remember correctly, I used to drop the pressure on my Micky Thompson ET Streets to like 12-14 psi at the track. It helped a lot. Of course, that was with a 15 inch wheel with a lot of sidewall. I could see the wrinkle marks in the tires after I ran. Not sure how the short sidewalls would act?
  10. VanishingPoint
    Jan 6, 2015
    1,028
    261
    258
    Somewhere, Texas
    A lot of modern performance tires are "rolled" so during hard cornering they still have grip as the tire rolls under the rim a bit. Reducing the air makes that roll part flatter, since you only desire max traction in a straight line.
    Modern street drag radials do this to, for some degree.
  11. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,066
    652
    413
    So Cal
    I was at the drags last weekend and there was a guy in a skat pack spinning bad on the start line I gave him my pressure gauge dropped him down to 18-19lbs and he picked up a bunch on the start don't know what tires he was running but help on a prepped surface.
24 psi challenger
