3.09 A8 gear swap
Discussion in 'SRT Hellcat Performance' started by paul suloff, Sep 2, 2015.
  1. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    698
    236
    Anyone gone to a deeper gear? I see there is a complete drop in center available from HHP. Seems like an easy upgrade if it will give you a couple tenths.
  2. srtfan
    srtfan SRT Hellcat Supporter Gold Supporting Member
    May 29, 2015
    286
    146
    Canada
    I like where this is going...
  3. Top Cat
    Nov 26, 2014
    1,925
    1,082
    768
    Doylestown,Pa
    Done, only one outing so I can't give too much feed back.
    TC
  4. paul suloff
    Aug 25, 2014
    698
    236
    Is the one HHP offers the same unit as stock hellcat? 9" with same internals? Assume ring gear is not welded to carrier.
  5. TallCool1
    2,435
    825
    Pacific NW
    paul suloff I'm kinda wondering same this appears like it's off the shelf for the a8 392 cars.
    Top Cat do you know of any differences between this and the stock rear end? Thank you.
  6. paul suloff
    Aug 25, 2014
    698
    236
    Not getting much feedback from HHP on improvements. There car is modified with power adders. I'd like to know with the 3.09 what trans gear a stock car will be in and at what RPM at the 1320? Many times a gear change can hurt performance by applying too much power down low or adding a gear change down track putting the engine out of the power band. Like to hear from the engineering types here to calculate RPM in each gear 2.62 vs 3.09 in 1/4 mile.
  7. TallCool1
    2,435
    825
    Pacific NW
    TIGwelder wanna run the math and numbers?
  8. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,444
    948
    668
    Cape Coral, SW Florida
    With 2.62
    1st -- 4.714 x 2.62 = 12.351 ( x 336 = 4,149 ) = 41.5 MPH @ 6000 -- 42.8 MPH @ 6200
    2nd -- 3.143 x 2.62 = 8.235 ( x 336 = 2,766 ) = 62.3 MPH @ 6000 -- 64.3 MPH @ 6200
    3rd -- 2.106 x 2.62 = 5.518 ( x 336 = 1,854 ) = 92.9 MPH @ 6000 -- 95.9 MPH @ 6200
    4th -- 1.667 x 2.62 = 4.368 ( x 336 = 1,467 ) = 117.3 MPH @ 6000 -- 121.29 MPH @ 6200
    5th -- 1.285 x 2.62 = 3.367 ( x 336 = 1,131 ) = 152.2 MPH @ 6000 -- 157.32 MPH @ 6200
    6th -- 1.000 x 2.62 = 2.620 ( x 336 = 880 ) = 195.6 MPH @ 6000 -- 202.20 MPH @ 6200
    7th -- 0.839 x 2.62 = 2.198 ( x 336 = 738 ) = 233.3 MPH @ 6000 -- 241.11 MPH @ 6200 ( we're past the aero limit here )
    Then we enter driving in a vacuum land :)
    8th -- 0.667 x 2.62 = 1.748 ( x 336 = 587 ) = 293.3 MPH @ 6000 -- 303.13MPH @ 6200
    With 3.09
    • Winner Winner x 6
    • Like Like x 3
  9. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,444
    948
    668
    Without slipage, looks like still in top of 5th gear
  10. paul suloff
    Aug 25, 2014
    698
    236
    Great Thanks!!!:)
  11. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,444
    948
    668
    Compare to a 727's first gear, it would be like having 5.94 gears haha
  12. paul suloff
    Aug 25, 2014
    698
    236
    If it's at the top of 5th in lights that's good. If it blows the tires off down low, that will kill the benefits. Might have to go to bias slicks over 305 45 18 DRs
  13. Top Cat
    Nov 26, 2014
    1,925
    1,082
    768
    Doylestown,Pa
    We only made three pass's with the rear change and no full pass as the car was not running right, but we did pick up big time on the 60' and I expect to see 1.38 or better when we start with all the HP available, I don't expect to change back to slicks, the DR are working great and should be fine with more power, IMO I think I could use a 3.25 gear and still have good traction.
    TC
    • Useful Useful x 3
  14. DB2
    DB2 Silver Member
    Feb 4, 2015
    339
    79
    Im going through the traps in 5th gear at about 4700 rpm.
    Jeeeez.....you think this thing would pop wheelies with the right tires and any steeper gear!
  15. paul suloff
    Aug 25, 2014
    698
    236
    3.09 Should be at the top of 5th gear.
05038702ad
2015 392 differential swap
2015 challenger a8 4th to 5th gear shift issues
2016 challenger rear end upgrade
2016 hell cat rear diff 309
hellcat gear swap
hellcat mph gear
hhp helcat rear
