4 months with no codes.
Discussion in 'SRT Hellcat General Discussions' started by gabe, Oct 13, 2015.
  1. gabe
    gabe Gold Member Hellcat Car Club
    Dec 24, 2014
    691
    343
    Today I got code u113f and the check engine is on. I had to disconnect the battery because of a sound coming from the front driver side fender after turning the car off.
  2. Red Harley
    Red Harley Silver Member Hellcat Car Club Gold Supporting Member HCC National Secretary HCC Charter Member
    Jul 27, 2015
    690
    258
    173
    Hamilton Ms
    Sound could have been you fan. It does stay on after the ignition is turned off.
    I am sure one of the techs will be able to tell you what the code was for.
    Found this on another post by a member
    U113F-LOST COMMUNICATION WITHACTIVE EXHAUST VALVE 1
  3. gabe
    Dec 24, 2014
    691
    343
    [QE="Red Harley, post: 288490, member: 3809"]Sound could have been you fan. It does stay on after the ignition is turned off.
    [/QUOTE]
    I wasn't the fan. It sounded like a pump.
  4. Red Harley
    Jul 27, 2015
    690
    258
    173
    Hamilton Ms
    Take it to the dealership that is what you paid warranty for.
    Seems all the techs on here are quiet
    Tonight.
  5. fnkychkn
    Jan 24, 2015
    1,533
    642
    greasy cardboard box
    The noise you heard is the coolant pump used to circulate coolant through the supercharger/intercooler to prevent the oil from cooking. Normal operation is only with key on.
    Pretty sure there's a PCM update to prevent that code.
    EDIT
  6. gabe
    Dec 24, 2014
    691
    343
    Is the car Ok to drive to drive to the dealership?
    I have to disconnect the battery because the pump won't turn off.
  7. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,011
    484
    403
    Westchester
    The car has to cool the supercharger even after you turn off the car, it will run for a little after turning off the car. All you did is stop it from doing it was suppose to do.
  8. gabe
    Dec 24, 2014
    691
    343
    I conected the battery today in the morning before starting the car and the pump started running and would not stop till i disconnected the battery. Called dealership and they can look at my car till next week.
  9. CubeMan
    Dec 31, 2014
    2,011
    484
    403
    Westchester
    I'd get it towed if it's a pump going no matter what then
  10. fnkychkn
    Jan 24, 2015
    1,533
    642
    should be ok to drive to the dealership. the pump shouldn't run indefinitely.
  11. gabe
    Dec 24, 2014
    691
    343
    Does the pump always run when the car is on or does it turn on when the supercharger is hot?
  12. gabe
    Dec 24, 2014
    691
    343
    Got home from work to day and conected the battery and the supercharger pump turns on with out the car running. Now I have three new codes U1140, U02A9 and P023B.
  13. Lord Hellcat
    Jan 6, 2015
    1,606
    723
    UK
    I've never heard my pump run after switching off.
  14. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,660
    483
    368
    Henderson, NV
    Ditto
  15. fnkychkn
    Jan 24, 2015
    1,533
    642
    should only run when supercharger coolant is hot.
    U1140 lost communication with active exhaust valve 2.
    U02A9 lost communication with charger air cooler coolant pump.
    P023B charge air cooler coolant pump control circuit low. <<< this is most likely causing your pump to remain on.
    loss of communication DTCs possibly caused by battery disconnect.
