6 Speed Remote Start Install,Calling All Experts
Discussion in 'SRT Hellcat General Discussions' started by FarAwayFromHere, Aug 12, 2015.
  1. FarAwayFromHere
    FarAwayFromHere Gold Member
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Hey All ;
    Does Dodge Parts Make a Plug And Play "T" Harness For A Remote Start one Could Use (Like The Auto Uses) Adapt For The Manual Trans Car? I Am Aware Of safety precautions ETC. I Want To Use A "Compustar" Brand!
    There Is A Specific Routine You Go Thru When Exiting the Vehicle To Allow The Autostart to function.My Issue is installers Hacking Into My Wiring And well we all know where that sometimes Goes? Anyone With Detailed Knowledge Of This Appreciated. I Know My Way Around Wiring And Programming to Some Extent,but would Like Some Installation Input. The Least Invasive Method Sought!
    Calling Dr. Buick/Funky Chicken et all
  2. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
  3. B5 Blue
    1,743
    fnkychkn do you have a theory of operation on clutch circuit for getting a 50 circuit signal to the starter? On an Audi the clutch switch nowadays sends two signals, one with pedal down about 1/3 and another all the way down with both seen in BCM to activate ignition 50 circuit to ECM(which controls starter manual or auto).
  4. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Appreciated B5 ...Finally Someone With Knowlege,
    Thank You!
    Hopefully A Consensus Can Occur!
  5. fnkychkn
    Jan 24, 2015
    1,451
    558
    423
    plastic take-out container
    Well, this promises to be a whole lot of fun. I'll have to wait until next week to research. I'll be partying at Woodward all weekend and most likely not coherent enough to be a reliable source of information. Lol
    • Winner Winner x 2
  6. Snappycat
    Jan 22, 2015
    3,463
    1,033
    628
    The I.E. So. Cal
    If it can be done, Funky Chicken and B5 will find a way. Stay tuned!!!
  7. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Found This
    http://www.compustar.com/techfeed/ft_controllers/manuals/CM6200_Full_Install_7.11_EN.pdf
    Com-Blade-Al Compustar - COM-BLADE-AL
    Then One would only Use the 20 Pin Connection/Thermister/Antenna From What I Can Gleen,you can Program The Factory remotes And Keep All The Factory System.
    Sounds Complicated!
    Would This Be Simpler?
    Since The Auto Already Has The Autostart Capabilities Can We Not Add A Brain For The Clutch/Park Brake/Neutral Switch to Enable The Manual To Start
    1)CLUTCH bypassed
    2) Trans Neutral
    3) Park Brake Set
    4) Motion Sensor (Back-Up Incase Neutral Switch Fails) ie: trans in Gear
    This IMHO Looks a Heck of allot easier to Do Instead of a compustar and another add on Box etc.
    Honestly Cannot fathom with the available technology,why this has to be so complicated to achieve in A Standard Trans Vehicle.
  8. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Crickets......
  9. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Bump
  10. soundman5000
    soundman5000 Silver Member
    Jun 25, 2015
    531
    122
    I had a x girlfriend that would start her car on a cold morning by not getting in the cold car but would somehow stand outside the car and press the clutch with her right foot, turn the key and then go back inside and allow the car to warm up. Well, she did that until the car took off without her inside! She chased the car through the front yard and both she and the car ending up in the neighbors ditch.
    Made me think of that funny moment years ago. I think you need to be in the car to start one with a stick! ..LOL
    • Funny Funny x 2
  11. redhemi
    redhemi Gold Member
    Dec 9, 2014
    469
    222
    southeast Pa.
    I miss my remote start:(
    Funny story a friend parked his mstang in the drive went out the next morning and car is gone,called the cops thinking stollen,well they found the car it coasted down the drive into the bottom of the in-ground pool!!:eek:
  12. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Russsstang!
  13. Thebossaudio
    Thebossaudio Silver Member
    Mar 4, 2015
    191
    31
    Xpresskit makes a t-harness bit I don't think is for the clutch bypass. You have to make a relay for that is pretty simple I have done alot of them
  14. fnkychkn
    Jan 24, 2015
    1,451
    558
    423
    sorry, i forgot all about you. the mopar kit does not need a harness except for hood switch (if not already wired).
    you can see the install instruction here: http://starparts.chrysler.com/info/default/k6862063.pdf
    i emailed a couple of contacts for suggestions and will post up when they reply.
  15. FarAwayFromHere
    Aug 8, 2015
    1,417
    443
    CA-NA-DA
    Fnky We Are Talking 6 Speed Right?
    Thanks For This!
    I Have A Feeling Once You Get The Info From "Contacts This May Change?
    Now How Am I Going To Get A Starscan Module With Current Updates............HMMM?
2009 challenger remote start install
adding remote start to a 6 speed hellcat
can i get remote start installed on a challenger rt
dball2 manual transmission install
dodge challenger manual viper remote start
