8, 9, 10 speed automatics.....
Discussion in 'General Automotive Discussion' started by Driver72, Aug 21, 2015.
  1. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,212
    280
    Seems like with power ratings, there is a race to have the "most gears" in an automatic gearbox.
    Has it become silly?
    8 speed autos to me seem like the pinnacle.
    I mean really at what point does having more gears work against you.
    The 9 speed auto in Chrysler's cars seem pointless. In one report I read, you can't even get the car to go into 9th gear unless you are going like 80+ mph and the ground practically has to be going downhill, as any little grade and it's gearing is so tall it can't keep the car going 80 mph.
    Now 10 speeds are coming.
    Help me understand:
    If you have a 6th gear that's 1:1
    7th gear is like .85 to 1
    8th gear is like .70 to 1
    What's left? Anything taller and it can't move the car/truck along at freeway speeds.
    More gears before the 1 to 1 gear?
    Well again, at some point the additional shifts and complexity of it has to work against acceleration right?
    Do you really want or need 7-8 gears before you even get to an overdrive gear?
    In some smaller displacement engines now it requires 3rd gear just to get to 60 mph. With a 10 speed it would probably require 4th gear....to get to 60.
    1/4 mile runs will finish in what 6th or even 7th gear???
    Am I the only one who doesn't seem to understand the need or desire to go above 8 speed autos.
    Granted I'll admit when we had 5 speed autos, I often wished for an additional highway gear, especially on 4 bangers where at 70 mph cruising you'd be at 3500 rpms. But when 7 and 8 speed autos started showing up a few years ago, I felt, that's perfect.
    Now 9 and 10 speeds, have the quest for more gears gone too far?
  2. B5 Blue
    1,745
    POS 4 banger can have lower final drive to move out of it's way
  3. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    595
    281
    Houston, TX
    If it keeps going then everything will probably go to CVT. More speeds means more time spent at higher rpms near red line. That seems like the most logical progression, doesn't it? Now that would be a fast ride while taking away a lot of the driving experience!
  4. B5 Blue
    1,745
    CVT can't handle lots of torque
  5. rw99
    rw99 Silver Member
    Feb 13, 2015
    192
    80
    178
    Castro Valley, CA
    To me, for a big torque performance car, 5-6 gears is enough. Run a mid-3 rear end and put 1:1 at fourth gear.
    I find my A8 to be a bit weird: 6th is the new 4th. And 3rd is kinda the new 2nd...
    Caveat: it's only weird if you're shifting it yourself. Stick it in Sport or Track and it's pretty good.
    Rich
  6. fnkychkn
    Jan 24, 2015
    1,542
    646
    greasy cardboard box
    it's not all about speed and acceleration. pretty sure it's driven by fuel economy and emissions.
  7. huggytree
    huggytree Gold Member
    Nov 22, 2014
    3,128
    742
    give it 20 years.....10hp a20 egg that drives itself......and gets 200 mpg
    in 20 years see what happens and remember where you heard it first
  8. Dak59RT
    Dak59RT Gold Member
    Nov 14, 2014
    595
    281
    Houston, TX
    Couldn't that change after SRT R&D further develops the technology? It wasn't that long ago that automatic transmissions in general were second best to manual transmissions. Now they're banging away shifts faster than we can blink. ;)
  9. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,011
    486
    403
    Westchester
    7-8th-9th gear are for emission purposes to make the mpg crazy high, Corvettes 7th gear is so tall but reduced the emissions so much.
