95mm Throttle Body
Discussion in 'SRT Hellcat Performance' started by Radride, Apr 26, 2016.
  1. Radride
    Radride Silver Member
    Jan 15, 2016
    880
    162
    Up Here!!!
    Modern Muscle has a 95mm throttle body for the Hellcat. Just bolting that on, do you think you'll see an increase in power on a stock car? Or is this mod for a highly modded car?
    Hellcat CNC Ported 95mm Throttle Body by Modern Muscle Performance
    R.K.
  2. pivotal
    pivotal Senior Hellcat Member
    Mar 24, 2016
    122
    35
    Silver Spring MD
    I'm guessing it will make a little bit of power up top on a stock car. Hard to say for sure, and I don't know if Modern Muscle has dyno-tested this throttle body.
  3. Cruisin1966
    Cruisin1966 Silver Member
    Nov 8, 2014
    1,105
    235
    198
    Calgary
    Can't seeing it being a benefit at all without other mods: PCM, tune, pulley (or two)
  4. BODUKE
    BODUKE Gold Member
    Jan 31, 2015
    1,697
    395
    Detroit
    Ported throttle bodys can add some power.
  5. Cruisin1966
    Nov 8, 2014
    1,105
    235
    198
    Calgary
    Not without a tune. Which would require a new PCM. If you go that far, you might as well go a little further, as I can't imagine there's much left on the table from the engineers.
  6. TNCHARGER
    Nov 19, 2015
    1,209
    408
    The MM throttle body is ported and polished to speed up air flow. The size of the opening at the butterfly is same as stock. I had an MM ported TB on my 392 and on the 426 stroker that replaced it. The TB provided slightly better response due to the air speed...especially at low RPMs...
    I did replace the MM TB with an 88mm TB and picked up power in the upper RPMs. The 426 with the large cam required more air volume. I did notice the car seemed to have less low end response after switching to the 88mm.
    I was happy with the MM TB but I do know it wasn't adding big HP. You might pickup 2-7 at most but the throttle response was nice. I might install one of his 95s on my cat.
    • Useful Useful x 2
  7. shadowsk
    shadowsk Silver Member
    Mar 10, 2016
    439
    South Carolina
    How hard of an install is it? Can a rookie handle it?
  8. Wack_Cat
    Wack_Cat Silver Member
    Feb 5, 2016
    195
    32
    Northern Colorado
    This could be good with a tune and smaller pulley. Might have to try it.
  9. TNCHARGER
    Nov 19, 2015
    1,209
    408
    I haven't really looked at the HC TB but if it is like the other Hemi TBs it is bolt off and bolt on. Easier than changing a tire.
  10. shadowsk
    Mar 10, 2016
    439
    South Carolina
    Thanks, Just ordered it.
  11. shadowsk
    Mar 10, 2016
    439
    South Carolina
    These guys are on the damn ball! Ordered today at 1 and received a shipping notice a couple hours later. UPS says it will be here tomorrow. Not sure when I'll get it installed but I'll be sure to post something up when I do.
  12. rayzazoo
    Nov 8, 2014
    3,626
    1,376
    818
    On a stock car, you'll notice a a slightly quicker throttle response. None the less, the supercharger is max spinning 1059 CFM in stock form (assuming standard air density).
    Dyno gains with this will sell it from a marketing standpoint, however, this is a helper modification to a smaller pulley, tune and aftermarket intake.
    Theoretical max flow for the ported 95mm would be 1182 CFM (prior to blade) to 1089 CFM (at the blade) to 1182 CFM (post blade).
  13. shadowsk
    Mar 10, 2016
    439
    South Carolina
    Thanks, my plans were to go with a DS and the 3.09 gears. I already have Triumph wheels and Drag Radials ordered. With this, the DS, and 3.09 gears I'll be ready for the extra HP mods down the road . At least that's the plan.
  14. Dragons90
    Dragons90 Silver Member
    Feb 23, 2015
    202
    82
    178
    Round Rock
    TNCharger.. you know Dave over at MM. What does he say about putting this TB on a stock car with just a AFE replacement filter
  15. TNCHARGER
    Nov 19, 2015
    1,209
    408
    I haven't spoken to Dave about it but like the 87mm for the other Hemi engines this is a plug and play for a stock vehicle. Of course it will enhance other mods too when tuned with them.
2015 dodge challnger hellcat throttle body
hellcat throttle body on 392
hellcat throttle body on charger
hellcat throttle body size
hellcat throttle body upgrade 2016 srt 392 dodge charger
how do you change the air tables after a throttle body replacement on hellcat
throttle body hellcat
wat size ported throttle body for 392
