A few aftermarket questions for the 6MT
Discussion in 'SRT Hellcat Performance' started by numine, Feb 25, 2016.
  1. numine
    numine Rookie
    Feb 23, 2016
    10
    1
    So, most threads I've looked through on here are about the A8, and I know it's the faster of the two, but I'm looking to make my 6MT make the Hellcat name proud. So I have a few questions.
    First, what all can I do to the car without busting warranty?
    Second, does the 6MT have the same Driveshaft issues as the A8 with Drag Radials?
    Third, does anyone know what the max torque/hp the 6MT drivetrain can handle before serious upgrades?
    Thanks in advance and I look forward to being an active part of the forum!
  2. Sepipr21
    Sepipr21 Silver Member
    Oct 17, 2015
    405
    48
    1st-Almost nothing g power related. You want power; warranty it's put of the window.
    2nd-no/not yet. Why? Because the clutch doesn't hold up, once the clutch hold up I would say yes.
    3rd-a lot.you will break a lot of things before you break the tranny.
  3. numine
    numine Rookie
    Feb 23, 2016
    10
    1
    What about the clutch doesn't hold up? This is the first I've heard of clutch issues. And I'm not so much asking about just the tranny so much as the whole system back to the driveline. For instance, once the driveshaft is replaced, does anyone know the next point of failure and where it comes into play?
  4. Sepipr21
    Oct 17, 2015
    405
    48
    Just search clutch in here and you will se. I replaced mine 6K miles in my car.
    In autos, drive shaft, then axel, seems the components breaking in that order ussually.
    In M6 I know one that put BBG upgraded clutch and he broke his axel.
  5. NX91Notch
    NX91Notch Gold Member
    Jan 8, 2015
    501
    249
    Seminole, FL
    The clutch holds up just find. The 6 speeds will break the drive shafts just as fast a the A8's will.
    6,500 daily driven miles on my clutch and it is just fine. We have sold at least five 6 speed cars at my dealership and all but 1 has come back with a problem and it was clearly user error.
  6. Sepipr21
    Oct 17, 2015
    405
    48
    I have not seen one that have break a DS in here.
  7. numine
    numine Rookie
    Feb 23, 2016
    10
    1
    I'm more just looking at what I'll need to replace before going for power mods and a tune. Not that I'm planning on shredding my warranty just yet, but hey, who knows how long my megalomania will be held at bay
  8. NX91Notch
    Jan 8, 2015
    501
    249
    Seminole, FL
    Then.they are slipping the clutch more than they should instead of letting it dump. :)
    I know the argument....the A8 "leaves harder". Automatics are usually softer on drivetrain parts due to the converter absorbing some energy. The M6 will leave just as hard if driven correctly. The only thing that may save the drivetain on the Hellcat is the tall first gear that is in the trans.
    You should see my box of broken parts from years and years of drag racing high hp manual transmission cars. I use to have a spare trans for my Mustang always built and ready to go. I have broken everything from driveshafts, axles, input shafts, etc.
    I haven't broken the Hellcat yet due to I haven't put it on the track yet.
  9. Sepipr21
    Oct 17, 2015
    405
    48
    That's my point, you will not, trust me. Many have tried in the forum and you will not. Stella putted Slicks and what happened dumped the clutch and clutch fried.
    With an upgraded clutch I could see some parts breaking, but not with the OEM clutch. No way...
  10. Sepipr21
    Oct 17, 2015
    405
    48
    1) Clutch (trust me, that's the 1st,thing)
    2) DS
    3)Axels. I posted that in my 1st post. It's what people are breaking.
  11. numine
    numine Rookie
    Feb 23, 2016
    10
    1
    Let me know when you do decide to track you Cat, if you have the 6MT, I'd be very interested to see that slip since you seem to know your way around the dragstrip
  12. Sepipr21
    Oct 17, 2015
    405
    48
    They alread
    There's a reason I had to replace my clutch after 6K. First day in there and what happended? Now I have a new clutch. It doesn't hold up.
  13. Sepipr21
    Oct 17, 2015
    405
    48
    In Stock tires seems to be fine as long as you rest the car. Put some DR and clutch doesn't like them.
  14. NX91Notch
    Jan 8, 2015
    501
    249
    Seminole, FL
    On drag radials or street tires?
    Was the clutch brunt or did it explode?
  15. Sepipr21
    Oct 17, 2015
    405
    48
    Ask stellas... It was his car... in mine, I just could not shift into 4rd or 5 or reverse easily anymore.
