A new HELLCAT ....Hellcat X 805 hp supercharged and turbo charged
Discussion in 'SRT Hellcat Performance' started by Milspec, Jul 19, 2015.
  1. Milspec
    Milspec Silver Member
    Feb 15, 2015
    206
    43
  2. MoparProud
    MoparProud Gold Member
    Oct 26, 2014
    1,246
    278
    Search guy, covered in two or three threads already. Not a chance in hell it will be a kit from the factory.
  3. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,216
    281
    Well that's interesting!
    I'm curious what they did to the internals, if anything?
    The turbos they added must be relatively small.
    Wonder if they put a larger intercooler, oil cooler, etc.
    If they didn't then it's awesome news that the stock internals and cooling system can take the 5-7 lbs of boost that is probably added from the turbos to give it the additional 100 hp and 150+ ft-lbs of torque.
  4. Milspec
    Feb 15, 2015
    206
    43
    Yea I wonder how much they built up the car for the extra power or if at all. I would love to see some
    0-60 times and maybe there tire choice. And why they went to turbos instead of just building on the supercharger. And 805hp I would think more like a 1000 with some turbos.
  5. Driver72
    Mar 10, 2015
    1,216
    281
    They added the turbos because the Hellcat X plane was a supercharged and turbocharged plane, so they wanted to replicate that.
    The reason it's only 800+ hp and not 900-1000 with the turbos is probably just as I stated, the turbos are quite small, probably adding small amounts of boost, I'd guess in the 4-5 psi range at most.
    Just enough to bring the power up, but not enough to destroy the internals of the engine.
    0-60 times on this would probably be very similar to our stock Hellcat's, maybe a tenth or so faster.
    It's simple, it's about traction. They could make it 1,200 hp, but with our stock tires, it won't matter, they'll just spin.
    The additional power of this car, at least on stock tires, will come at speeds above 55-60 mph, when you can use full throttle without the tires spinning like crazy.
  6. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,033
    The car has twin 61mm hellion (hope that's spelled right) turbos, I think I recall there making 5 pounds of boost...there is a company in Michigan that did the install.....I personally would think a bigger supercharger would make more sense... But I see the theme there going for...and it's for a good charity...
  7. koda711
    koda711 Hellcat Member
    Apr 24, 2015
    37
    12
    Hartland, MI
    The company that did the Hellcat X is Walsh performance in Wixom, MI.
  8. Milspec
    Feb 15, 2015
    206
    43
    Well I hope they offer it as a Kit
  9. 1BADHC
    1BADHC Hellcat Member
    Jun 6, 2015
    74
    20
    St. Louis,Mo
    If they do I would buy
  10. KLR CAT
    KLR CAT Active Hellcat Member
    Apr 9, 2015
    42
    28
    Hellion offers a TT kit for the challengers already, and fits the 2015, but tuning a compound boost setup sucks. They are heat monsters and don't like daily driving. You could dump the SC and run it 6.4 Apache or a sheet metal intake, and be better off but that really defeats the purpose of buying a Hellcat. You might as well start with a 392 and a built short block from arrington, and be ahead of the 10K ahead of teh game. 61mm turbos good for 900whp on their own. so really no need to compound boost for big power.The SC really just becomes a flow restriction after a certain point.
  11. 1BADHC
    Jun 6, 2015
    74
    20
    St. Louis,Mo
    Very true as I had this setup on my 13 srt8
805 hp hellcat
hellcat supercharged turbo
hellcat with turbo and supercharger
is the hellcat supercharged and turbocharged
new hellcat x
supercharged and turbocharged hellcat
turbo and supercharged hellcat
turbo supercharged hellcat
