Adding Coolant?
Discussion in 'SRT Hellcat General Discussions' started by Coldheartid, May 27, 2015.
  1. Coldheartid
    Coldheartid Silver Member
    Aug 29, 2014
    221
    77
    Miami Fl
    So, I have heard or read somewhere that in order to add antifreeze to the coolant system you have to go to the dealership. Now I could understand this if you replacing a large portion of the coolant and had to put the system in a vacuum. But is this trus if you are just adding some to top it off.?
  2. HCone
    HCone Gold Member
    Dec 4, 2014
    1,063
    310
    serv mgr told me it is a premix 50/50 with water. I would get it from dealer to be safe
  3. Hemikid
    Hemikid Hellcat Member
    Oct 3, 2014
    71
    14
    Saskatchewan
    I think what coldheartid meant was if the cooling system is pressurized and to add coolant that the dealer had to do it. If you drain the whole system you need a vacuum system to get the air out of the system so you don't get a vapor lock and over heat. To just add coolant , don't open rad cap when car is hot just like any other vehicle, let it cool down and you will be ok. I took my rad cap off and checked the spring pressure on the cap and nothing happened. System is not under constant pressure.
  4. Coldheartid
    Aug 29, 2014
    221
    77
    Miami Fl
    Thanks, That is exactly what I was wondering.
add coolant 2015 charger
adding antifreeze for dodge ram 1500 hemi
