aFe POWER Momentum Intake - Hellcat +37HP - Over 700WHP
Discussion in 'aFe Power' started by aFe POWER, Mar 30, 2015.
  1. aFe POWER
    aFe POWER Gold Member Hellcat Supporting Vendor
    Mar 27, 2015
    404
    381
    513
    Corona, CA
    aFe POWER (advanced FLOW engineering) is excited to announce the new Momentum Series of Sealed Air Intake Systems for the LX platform, beginning with the Challenger Hellcat.
    We have finalized our testing, and will be sending this to production shortly, and these intakes will be available soon. This same sealed housing (with integration to the factory ram-air setup, more on that below) will work across multiple engine options in the LX family, so look for more applications soon.
    Let's get to the fun!
    aFe POWER Momentum Sealed Air Intake System - 2015+ Dodge Challenger Hellcat Supercharged 6.2L
    [​IMG]
    The aFe Momentum Intake System is built to maximize airflow, and utilizes a massive air filter designed specifically for this intake. By outflowing the factory intake and improving efficiency, gains of +37HP and +33lbs x ft of torque are realized at the rear wheels with just this upgrade. (Dyno sheet below)
    That takes the maximum power from 665.78HP to 701.67HP!
    Quick Data Points:
    • Improved Horsepower & Torque - Improved Throttle Response
    • Sealed Intake Design - Roto-molded Tube w/Premium Hardware
    • Massive Cone Air Filter - Choice of Cleanable/Reuseable Oiled or Dry Filter Media
    • One-Piece Sealed Housing w/Clear Sight Window
    • Direct Bolt-On - No Cutting or Drilling - 30 Minute Install - Utilizes Factory Ram Air
    • No Tuning Needed
    [​IMG]
    (This is a prototype 3D printed part used in testing - Final version will be roto-molded and smooth)​
    Development Information
    For those not immediately familiar with aFe POWER, and our Intake Development process; All design and engineering comes from our 165,000 sq. ft. facilities in Southern California. We utilize the latest in technology, 3D scanning, 3D printing, CAD design software, and have an in-house AWD Dynojet Dynamometer.
    We scanned the Challenger engine bay, analyzing the stock intact tract, and designed a new intake system that outflows the stock setup. Once the initial design was completed, we were able to "print" plastic prototype parts from our 3D printers, and construct the complete prototype and install on the vehicle. (Those of you that attended the Spring Festival of LX's this year saw the prototype installed.) From there we were able to test the vehicle on the dyno. Through rigorous testing, such as monitoring performance and ECU parameters in real-time, we were able to tweak and make any changes that were necessary.
    Once R&D is complete, we move to manufacturing of the intake itself, creating the intake molds from CNC machines, and production begins. Premium hardware is used on the kit, including stainless steel T-Bolt clamps and Momentum intakes are designed with fewer parts, which allows this intake to be installed in 30 minutes for most.
    Installation for the housing mounts the kit directly into the factory location on the fender well, ensuring the coolest air possible is being captured from the factory ram air intake inlet. A large clear sight window is built into the housing for easy filter inspection without removal of the air box. The largest filter possible was used and is available in two different filter media options: Pro 5R is an oiled filter media for maximum airflow, while the Pro DRY S "oil-less" filter media provides maximum filtration.
    (For those with other applications and engines - This housing will work with several other vehicles, we'll be developing those right after this launch)
    Dyno Sheet
    aFe Momentum Challenger Hellcat Supercharged 6.2L Intake System w/Oiled Pro 5R Filter (91 Octane)
    Bolt-On Results - No Tuning
    [​IMG]
    Additional Photos
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Teaser Video
    • Like Like x 13
    • Winner Winner x 7
  2. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    909
    331
    173
    Akron, Ohio
    Price?
  3. aFe POWER
    Mar 27, 2015
    404
    381
    513
    Corona, CA
    Still finalizing production, but we will announce soon! Was nice to get the intake out at the track this weekend at Chuckwalla.. Let our test car get a chance to do some endurance testing at speed..
  4. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    70.196059, -148.559760
    Welcome to the site.
    Any difference in dyno verified power output with the paper filter vs the oiled filter options. Thanks.
  5. aFe POWER
    Mar 27, 2015
    404
    381
    513
    Corona, CA
    The air filter we use is designed specifically for this intake, and dramatically bigger with a ton more airflow. What I will be able to show soon is the stock intake w/paper filter versus the aFe intake in total flow by CFM. Wait until you see the filter difference over stock. You'll understand why.
    We do offer a dry version of the filter media for those who want a little less maintenance, but it will have an effect on horsepower, especially with high HP engines like the Hellcat.
  6. skibum819
    skibum819 Silver Member
    Mar 18, 2015
    366
    80
    Westchester County, NY
    any major improvements for the oiled version instead of the dry version??
  7. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,650
    538
    423
    Chattanooga, Tennessee
    So, I guess I was born a skeptic. Are you telling us that improved air flow to the supercharger will net that much HP gain? No tuning was performed to achieve this??
  8. SRT_HC_707
    Jan 1, 2015
    4,944
    1,437
    That's my question. With your setup what is the power difference using your paper filter vs. your oiled one... Have you dynoed the difference between the two yet?
  9. aFe POWER
    Mar 27, 2015
    404
    381
    513
    Corona, CA
    We enjoy skepticism, that's why we provide both a dyno sheet with every product, as well as an airflow "dyno" showing airflow differences, which I doubt you'll see from any other manufacturer.
    Our Pro DRY S filter is still a progressive synthetic media, it's not the same as a paper filter. Paper will still have a very slight improvement on filtration, but at the expense of airflow, and having to replace it constantly versus being cleaned.
    And yes, it does produce that much power, as we've increased the volume of the airbox, have a much larger air filter with improved air flow, and the car is able to take advantage. The high gains you're seeing are in proportion to the engines already staggering output, it's actually a low percentage of gain, but has huge impacts because of the large numbers. And you will absolutely feel the difference. We're excited for these kits to hit your hands.
    With every car, including the seemingly brilliant like the Hellcat, there are still gains to be had..
    • Useful Useful x 2
  10. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    I'm more than a little skeptical, how about a non partial review by a member here that is going to have their car on a dyno?
  11. bolivarshagnasty
    Oct 24, 2014
    1,650
    538
    423
    Look forward to more info.
  12. aFe POWER
    Mar 27, 2015
    404
    381
    513
    Corona, CA
    Absolutely.. we'll let the admins pick the victim when the kit is available and make it happen. :)
    • Like Like x 12
  13. aFe POWER
    Mar 27, 2015
    404
    381
    513
    Corona, CA
    Great! That's why we are here, to interact, provide some good products, including stuff you guys are looking for. We're already getting started on headers and exhaust.
    • Like Like x 4
  14. Next Phase
    Next Phase Silver Member
    Oct 22, 2014
    917
    306
    173
    I'm with you Top Cat... I've never seen a CAI boost hp and tq that much...with no tune. Hell, I haven't seen that much with a ported intake manifold...
    I can see 5 to 10 rwhp...
    What's the price point? $300? Ballpark?
  15. Next Phase
    Oct 22, 2014
    917
    306
    173
    Nice!
    What's the plan for the cats? High flows?
afe hellcat
afe hellcat intake
dodge hellcat airbox performance gains
hellcat afe intake
hellcat air box
hellcat airbox
hellcat install in a new ram
hellcat intake
