Aftermarket Fuel Pump
Discussion in 'SRT Hellcat Performance' started by mowe, Sep 1, 2015.
  1. mowe
    mowe Gold Member
    Mar 25, 2015
    371
    195
    just talked to the shop who is doing my build and it seems that at 21lbs of boost an over 9xxwhp you run short with the stock fuel pump...
    Currently running a KB boost a pump
    Does anybody make one yet ?
    Build info and final numbers coming soon but looking to see if I need to scale it back or if I have options....
    Thanks for any info !
  2. Top Cat
    Nov 26, 2014
    1,925
    1,084
    768
    Doylestown,Pa
    The Hellcats have a built in boost a pump type system, in going E85 your going to need 30% more fuel, I would ask Tammy to ask Doc what he used..
    TC
  3. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    There are plenty of upgraded aftermarket fuel pumps out there. Look at turbo Mustangs, Supras, GTR's, etc., over 1000whp and imitate their fuel setup. You may need to go to a return style fuel system, Magna-fuel makes a great billet fuel pressure regulator. May take many feet of braided stainless steel hose and -AN fittings.
  4. RadCat
    RadCat Left Shark
    Nov 3, 2014
    1,141
    311
    Oklahoma
    I've got about $5,000 worth of -AN fittings sitting on my dining room table right now...fuel coolers, all kinds of goodies. If you are circulating lots of fuel in a return style system, it will build up heat, so put in a fuel cooler, like a tranny cooler, but for fuel.
  5. christman787
    christman787 Hellcat Member
    Feb 4, 2015
    34
    17
    Oshkosh,wi
    kb makes 2 versions of the boost a pump a street version which is 17volts and a competition version which is 20volts. MSD also make a boost a pump 22volt.
  6. @srt_n8
    @srt_n8 Rookie
    Sep 13, 2015
    29
    18
    Houston
    Mowe, we just built a new setup for the shop car. We are going to install an upper to go along with the already installed lower and try to get it on the dyno this week.
  7. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    (Built, blown, bottle fed I like that ha good 1)
  8. mowe
    mowe Gold Member
    Mar 25, 2015
    371
    195
    We were able to do the same however over 900whp and 21lbs of boost we had fuel issues
    Let me know how it goes. What upper did you use ?
  9. @srt_n8
    @srt_n8 Rookie
    Sep 13, 2015
    29
    18
    Houston
    We are not using the factory pump
  10. mowe
    mowe Gold Member
    Mar 25, 2015
    371
    195
    Want to share ?
  11. @srt_n8
    @srt_n8 Rookie
    Sep 13, 2015
    29
    18
    Houston
    I will share more after testing with the 2.5 upper. I'm not holding out, just want to make sure everything works like we think it should.
  12. Georgia cat
    Georgia cat Gold Member
    Feb 10, 2015
    141
    109
    I would also like this information, on e85/and 18.5/pounds boost, we ran out of fuel at the Georgia half mile races
  13. @srt_n8
    @srt_n8 Rookie
    Sep 13, 2015
    29
    18
    Houston
    We plan to dyno in the next few days and then I'll update
  14. @srt_n8
    @srt_n8 Rookie
    Sep 13, 2015
    29
    18
    Houston
    Looks like our solution works. We put down 907/879 on 18psi, hot as hell and having belt issues. Now it's time to get this thing in to production
  15. catdodgehell
    catdodgehell Gold Member
    Aug 30, 2016
    344
    179
    Waco, TX
    What did you do about the pressure regulator? Stock?
2016 hell cat challenger fuel pump
booster pump hellcat
fuel pump install on hellcat
hellcat boost a pump
hellcat factory fuel pump
hellcat fuel pump
hellcat fuel system
upgrade fuel pump for 2016 challenger
