Air Flow Filter Independent Tests
Discussion in 'SRT Hellcat Performance' started by goingsolo2, May 2, 2015.
  1. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    I just went outside and did some testing on the two filters. I used my fiancés blow dryer, inserting it directly into the intake hole in the front light bezel. I placed a flat piece of paper on top of each filter in there and turned the hair dryer on the same setting. The paper lift was very close on the two filters, but the stock Hellcat filter seems to flow a bit more, as the lift was about 1/4" higher. I am not saying aFe's filter is not a good product, but that particular filter did not flow better with my test. It might flow better when driving openly on the road. The aFe filter is a quality made product, but I'd like to see some numbers straight from aFe comparing flow rates. If you pout your hand behind each, you can also feel that the OEM filter is letting more air through. I tested it with a blower as well, that I use to dry my car, and the results were the same…a little more lift for the OEM filter. You can see my video above.
    I also just tested on a tabletop, as in the video above and the stock filter was blown off and the aFe did not move…see video below.
  2. rayzazoo
    Nov 8, 2014
    3,965
    1,619
    818
    A start to an interesting discussion regarding air flow through filters for the Hellcat. If others could post a similar comparison of other filters on the market that they have in hand (e.g. GreenUSA, K&N, etc) that would be helpful for the discussion.
    AEM 28-20460 vs Stock 392 SRT Filter 04861746AA
    AFE 31-10220 (dry S) vs Stock Hellcat SRT Filter 68172459AA
  3. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    I just went outside and did some testing on the two filters. I used my fiancés blow dryer, inserting it directly into the intake hole in the front light bezel. I placed a flat piece of paper on top of each filter in there and turned the hair dryer on the same setting. The paper lift was very close on the two filters, but the stock Hellcat filter seems to flow a bit more, as the lift was about 1/4" higher. I am not saying aFe's filter is not a good product, but that particular filter did not flow better with my test. It might flow better when driving openly on the road. The aFe filter is a quality made product, but I'd like to see some numbers straight from aFe comparing flow rates. If you pout your hand behind each, you can also feel that the OEM filter is letting more air through. I tested it with a blower as well, that I use to dry my car, and the results were the same…a little more lift for the OEM filter. You can see my video above. Thanks rayzazoo!
  4. EverythingSRT
    EverythingSRT Silver Member
    Jan 30, 2015
    440
    126
    Alberta canada
    Interesting! It even sounds like it flows less restrictive through the stock filter
  5. LForst
    LForst Driver of Badassery
    Oct 29, 2014
    511
    265
    California
    GS I noticed the stock one tilted a little right as the media lifted can you do test again with afe tilting it slightly
  6. B5 Blue
    1,746
    Nice test, can't wait for you fiance to ask why the blow dryer smells funny:D
    • Funny Funny x 2
  7. B5 Blue
    1,746
    Thanks ray. When you send the AEM back are you going to get a Green filter?
  8. SRT_HC_707
    Jan 1, 2015
    4,954
    1,444
    70.196059, -148.559760
    It's hard to beat an OE paper filter. It's a good compromise of flow and filtering. I never understood why so many people run to the aftermarket filters based on some marketing mumbo jumbo LOL.
    At least dyno your own car before and after in the same session. And even then if there is more power what's the guarantee it filters as least as good. No reasonable way for the average person to actually measure that. Stock filer is fine for me!
  9. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,514
    1,432
    818
    Endless Mtns of Pa
    AEM has been returned, and the AFE is going back to Amazon. Stock for me too
  10. rayzazoo
    Nov 8, 2014
    3,965
    1,619
    818
    The videos above are from other users. I've had an AEM for my 2012 since 2013, however, have recently been using the stock filter.
  11. B5 Blue
    1,746
    Yeah but the video you posted showing the rpm rate at WOT says to me NOT to run the stock filter and I'll be using the Green filter.
  12. rayzazoo
    Nov 8, 2014
    3,965
    1,619
    818
    Agree, I believe the K&N and Green Filter will flow better than the stock.
  13. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    I wish the companies would just post flow rates compared to stock in CFM…I don' know whether or not to use the aFe or OEM. I don't have a way to test how they flow during actual driving.
  14. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    I actually did it again immediately after in the video because it slipped out of my hand and tilted…the second time, it is straight. Same result.
  15. goingsolo2
    Oct 29, 2014
    1,562
    642
    Long Island, NY
    I'm going to keep the aFe one for now in my storage until I hear back from them with some flow numbers. I called this morning and emailed one of their engineers.
2016 challenger air filter cfm test
aem dryflow filter test
are the 392 and hellcat filters the same size
best hellcat air filter
green panel filter cfm
hellcat air filter
hellcat flow numbers
what is aem filter 21-2059dk cfm
