AIT's - AIR TEMPERATURE TESTING
Discussion in 'SRT Hellcat Performance' started by Top Cat, Feb 12, 2016.
  1. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    I thought this was an Interesting article to read.
    About the relationship between a supercharger, heat exchangers and intercoolers and how it affects to an engine.
    TC
    At the end of the day, what really matters is HOW DOES MY SUPERCHARGER KIT
    PERFORM WHEN I’M IN BOOST? DOES IT DELIVER THE ADVERTISED HP AND
    PERFORMANCE? Occasionally, temperature or other test data by an individual may be
    misleading.
    For example: There has been considerable discussions regarding air and water temperatures of
    supercharger kits. Comparisons are okay if they are accurate. If not, they are just more
    misinformation circulating on the web.
    And, it is not our intent to compare the design and efficiency of any kit or the individual
    mechanical components that influence air discharge temp. These are the supercharger, inlet tract,
    intercooler, heat exchanger, pump etc. Optimizing these parts lower the air discharge temps.
    resulting in greater HP and reduced detonation potential. “Hot air” under-hood inlets increase
    temps and hurt performance by 30-55HP while adding an external real cool air kit does the
    opposite. One would have to be living in a village to not be aware of these basics- cooler air
    MAKES MORE HP.
    Instead, we hope to point out the testing procedure and criteria we use at Kenne Bell to
    accurately compare the charge and coolant temps when dyno testing. Disregard any of the
    following 12 parameters and accuracy is compromised resulting in bogus comparison data. As
    you will see, it’s easy to skew the data with even the same car, kit, day, ambient and boost.
    If any meaningful or accurate data is to be derived from comparing the air discharge temps of
    supercharger kits on a vehicle, it must be a controlled test with specific test parameters that
    ELIMINATE THE VARIABLES.
    All the below will, and do, affect temperature when tested on a chassis dyno. One “kit” may
    wrongly appear superior or inferior on the same vehicle because of the simple temp or boost
    reading error or failure to note a cool air kit upgrade or open vs closed hood change to one kit
    and not the other.
    Also, dyno testing with an open hood vs a vehicle at road speed are two different temp scenarios.
    VARIABLES THAT AFFECT COMPARISON TESTING
    1) UNDER-HOOD TEMP (HOOD UP VS DOWN)
    2) AMBIENT TEMP.
    3) ACTUAL BOOST (1 PSI OF BOOST= 10*-15* SC air discharge temps.)
    4) RPM, LENGTH OF RUN + GEAR RATIO
    5) STARTING AIR TEMP
    6) STARTING INTER COOLER FLUID TEMP.
    7) WATER VS. COOLANT RATIO
    8) SUPERCHARGER TEMP.
    9) INLET RESTRICTION
    10) IDLE-RUN-AFTER RUN
    11) WHERE THE ACTUAL CHARGE TEMP MEASUREMENT IS TAKEN
    12) IMPROPER CIRCULATION (AIR TO WATER)
    13) HEAT EXCHANGERS, INTERCOOLERS & PUMPS
    1a) FILTER TEMP- The ONLY measurement to use for “engine in” air temp. calculations. Other
    temp readings under, above or around the dyno or car are wrong. The engine draws air from the
    filter. Nowhere else matters. Keep in mind this temp. alters HP at 1% per 10* of variation. Also,
    cooler ambient air makes more boost.
    1b) UNDER-HOOD TEMPS (HOOD UP VS DOWN)- Why do dyno operators insist on testing
    with the hood “up?” That isn’t the way the cars are driven. CLOSE THE HOOD- unless you
    want false air data. Under-hood temps. reach 200* vs 70* or ambient outside air. If the filter
    (inlet source) is located under the hood, then the dyno run should be conducted the same wayhood
    closed. Why is that so difficult to grasp for so many? What are they afraid of? Yes, the hot
    under-hood air will reduce HP, increase the detonation threshold, lower boost, alter supercharger
    efficiency and elevate engine and exhaust temps. Not good, but it is what it is- hotter air.
    It’s why everyone uses scoops and not mini sized grill cracks to supply the 750-1500 cu.ft. of
    cool air flow required by the engine. And why the Camaro utilizes an air scoop in the grill. They
    are looking for cool outside air for their filter box. Close the hood with an “open” under-hood
    filter and watch your kits power drop 55HP! See “Kenne Bell 30HP Advantage” for
    comparisons.
    Fact: Very little cool air finds it’s way through those little 50 CFM grill openings. Yes, some
    outside air mixes with all that hot air from the radiator, engine, headers etc. but it is all ingested
    via the filter into your engine.
    Finally, under-hood shrouds and seals do virtually nothing. Once eliminated, this common but
    huge test misstep (we’ve seen up to 55 HP and 100* with hood “up” vs. “down”) the rest is
    common sense testing and the air and water data will support meaningful accurate results. All
    Kenne Bell kits mount the filter outside the engine bay where temps are cooler and consistent
    at any vehicle position or speed. The dyno fan will simulate vehicle high speed and under-hood
    air flow.
    So, no exceptions. Locate the ambient temp sensor at the filter whether it be under-hood (hood
    down) or behind the front bumper. Begin test at the same temp or data is junk.
    2) AMBIENT TEMP- Cool outside the engine bay air is what also cools the fluid in the heat
    exchanger. Cooler air= cooler water= cooler supercharger air into the intercooler= cooler air
    charge to engine= more boost= higher HP. So, ambient air temp should be the same as it
    influences all the other components. 20* higher ambient raises intercooler air and water temps. It
    does matter.
    3) ACTUAL BOOST- Boost makes HP, but it produces heat. There’s no free ride. Twin Screw
    positive displacement, and centrifugal superchargers generate approximately 10* of charge temp
    per PSI. Starting run design temps are approx. 10* per PSI + Inlet temp. Example: 90* ambient +
    90* (9 PSI) = min air charge temp 180* before intercooler. Roots style are higher. Be sure
    “actual” boost is the same. Don’t just assume all 9 PSI kits develop exactly the same boost. The
    intercooler system (air to water or air to air) is typically 50-75% efficient depending on numerous
    kit design variables. To accurately compare kits, boost cannot vary.
    4) RPM, LENGTH OF RUN & GEAR RATIO- The higher the RPM, read end or trans. gears the
    longer the dyno run and the greater the final temp. Everything heats up with time until there is
    stabilization. Use the same vehicle to insure accuracy.
    5) STARTING INTERCOOLER WATER TEMP- If the intercooler water ( it cools the air) is
    20* hotter at the “start” of the run, the “finish” will be hotter. Start temps must be identical for
    accurate comparisons. Intercooler “start” water and air temps can vary from ambient 70* to 200*
    depending on idle time. Now, at what temp do you “start” the run? Get the picture?
    6) STARTING INLET AIR TEMP- Same here. Obviously, a hotter filter at the beginning of a
    run results in higher supercharger discharge temps. A 30-50* variance is common. Start test at
    same filter air temp. or the tests are useless. NOTE: Under-hood filters are difficult to test
    because engine bay temps increase (heat soak) with time when idling from ambient to 200*.
    Open the hood and let cooler dyno room external air blow in and the test are skewed.
    7) WATER VS. COOLANT- Since no liquid cools better than water, 100% water is best. 50/50
    is not as efficient in cooling. 90/10 is better. Try placing ice cubes in a pot of coolant. Ice 32*
    and coolant 50* between the ice cubes. Engine coolant “resists” lower temperatures and freezing.
    Run the same mix when testing if your goal is an accurate comparison.
    8) SUPERCHARGER TEMP (HEAT SOAKING)- Obviously, heat soaked components can heat
    the air passing through them. For example: We use a thermal laser gun to quickly measure
    supercharger case temp. If the supercharger is covered (never on our design priority list) with a
    manifold, intercooler or plastic engine cover, it obviously runs hotter. Then there’s the heat
    transfer from the engine. However, for test comparisons, the temps. of the supercharger and other
    metal or plastic pieces in a particular kit “are what they are.” Also consider the type of
    supercharger and the pressure ratio. Centrifugals run cooler at idle because they are not
    compressing air (boost) like the positive displacement superchargers. No heat of compression- no
    boost. Less boost at low and mid range- less heat. Boost IS heat. The twin screw can run higher
    pressure ratios of 2.1 (15 psi) vs 1.4 (6 psi) so, of course the “idle” temps are higher. Again, you
    look at the higher efficiency and boost of a 15-30 psi Twin Screw and the benefits. Higher IAT’s
    are unavoidable.
    9) INLET RESTRICTION- NEVER compare 2 kits with inlet tracts ( filter, meter, tubing,
    throttle body etc.) that vary in restriction/efficiency. If one inlet is larger and enjoys less
    restriction to air flow to the supercharger, then the supercharger is not required to work as hard.
    Like sucking coke through a straw vs. a straw half pinched off. The upside of a larger inlet tract
    is the supercharger uses less HP to suck in the air and subsequently runs cooler AND develops
    more boost. Supercharging efficiency, boost and inlet temps will all be better but DIFFERENT.
    10) IDLE/RUN-AFTER RUN- Idle temp. will be highest before a run. Let it cool to the test
    temp. and make the run in the same gear, car, boost, trans. and RPM. Check the data at the same
    peak RPM as everything heats up after getting off the throttle.
    11) WHERE THE ACTUAL CHARGE TEMP MEASUREMENTS IS TAKEN- This is
    probably the most important part of the measurement process. Equally important is the sensor
    being used is properly calibrated. Different air temp sensors can be calibrated differently and if
    the person testing is not aware of this, all data will be useless. Transfer functions are different for
    some push in type sensors vs screw in type and vs shielded/unshielded sensors. The most
    accurate and fastest response air temperature sensors are the unshielded type. Never compare
    shielded sensors against unshielded.
    Given that the a) sensor types are the same (unshielded) and b) the transfer functions are correct,
    then c) placement of the sensor is critical. Let’s make sure we are not using a sensor that is
    located upstream of the supercharger on one system and then downstream on the other. Believe it
    or not this mistake has been made before. Whenever temperature readings are only a
    few degrees above ambient under boost, always suspect the sensor is either a)
    located upstream (before) the supercharger as is the case in many applications
    if a new sensor has not been relocated from the factory location to the discharge
    side of the intercooler, or b) sensor is incorrectly calibrated or c) sensor is of the
    shielded type. Ever wonder why there are sensor “relocation kits?” was it the wrong location?
    Big problem when the Camaro and other Ford kits were introduced.
    12) IMPROPER CIRCULATION (AIR TO WATER)- Always compare systems that have proper
    water circulation. A common error when seeing high discharge air temps is not to insure there is
    adequate flow in the system. In any new installation it is very easy to have air pockets that
    hinder/stop circulation of the liquid (cooling media). Even the best designed system can produce
    high charge temperatures if proper purging of the intercooler system has not been performed.
    Blockage of airflow to the heat exchanger from debris, bumper cover, etc. can also have a drastic
    effect. There has to be sufficient airflow across the heat exchanger to drop the charge
    temperature.
    13) HEAT EXCHANGERS, INTERCOOLERS & PUMPS- At Kenne Bell we test numerous
    configurations and sizes, including our competitions heat exchangers, intercoolers and pumps.
    HEAT EXCHANGERS
    We double or stack heat exchangers and check various frontal locations for air flow velocity (in
    and out), cooling and heat soaking.
    Example: A larger surface area HE mounted in front of a radiator may seem like a great idea but
    it has distinct shortcomings.
    1) RESTRICTION- Who can deny that it is a big restriction to the radiators air flow and
    ENGINE COOLING. The engine WILL run HOTTER!
    2) TEMP- Do you really believe 70* ambient blowing through a 130* of HE water will
    cool a radiator better than the 70* air? Oops!
    INTERCOOLERS
    Thinner intercoolers flow more air and enjoy less boost loss because the core is less resistant to
    laminar air flow. Thicker cores flow less air, kill more boost but do a better job of cooling.
    HOWEVER, THE LOWER BOOST WILL REDUCE HP by 15-20 HP/ psi loss. Yes, the
    supercharger boost and speed can be increased.
    PUMPS
    Unfortunately, the supercharger will now consume more engine HP to blow the additional
    through the thicker more restrictive core. Excess water flow/ speed through the HE doesn’t allow
    sufficient time for the water to remain in the core and cool. Insufficient flow/speed keeps the
    water in the HE too long resulting in excess heating.
    CONCLUSION
    When we develop this package, temps and flow (air and water) are measured both “in” and “out”
    of the HE, IC, radiator and pumps in addition to the all important filter temp.
    That’s how Kenne Bell develops and tests product. Again, it’s all about the overall design at
    WOT and the HP the supercharger kit produces in boost. No one can deny they make plenty of
    HP with room to grow.
    What we often think is the same is the same but it’s different.
    If analyzing supercharger kits by the same or competing manufacturers, it is important to refer to
    the above 13 test variables and make the necessary adjustments to guarantee boost temperatures,
    run length, inlet, restriction, temps measurement location is identical- and the hood is CLOSED,
    like you drive the car .
    There’s a saying on the Kenne Bell dyno that an OEM engineer left us- “One of the real dangers
    in running a test is you are bound to get data”.
    We hope the information is helpful.
    • Like Like x 5
    • Useful Useful x 3
    • Winner Winner x 2
  2. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    Sorry about the long read, but it has some good information on CAI, location of filters, what is ambient air temps and what effects them, some times you need to look farther than just a sales pitch and start asking questions, if they don't get answered then maybe that should be a red flag, fixing a problem with a fix to fix the first issue usually means you paid for something that did not do what it was sold to do.....................
    TC
  3. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    I've had conversations with CR racing and they said contrary to belief a thinner core will cool better than a thicker one, there are a lot of different factors when designing a unit,location, size of the unit,fluid flow rate,how much surface area and how much of the radiator is being blocked as that will increase engine temps, so it's a balance of things when doing a daily driver vs a pure race car, also the use of fans will greatly increase efficiency of the unit.
    TC
  4. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    Physics 101? One of a few reasons both AFCO and CR Racing recommend the fan version for better cooling in the street cars .
    TC
  5. TallCool1
    2,439
    829
    Pacific NW
    It was just a reference that shorter intercooler fins usually present more streamlined air flow / less air path oposition.
    As a description of movement in physics, laminar (of a flow) is taking place along constant streamlines; not turbulent.
    Bell used it correct in context.
  6. 8SECSRT
    8SECSRT Hellcat Member
    Nov 1, 2015
    37
    Thicker intercoolers/HE have a few plus and minuses. Fin count is a no brainier but we don't have the room for massive HE up front unless we cut the front cover.
  7. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,598
    655
    I took it to man, internal air flow?
  8. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    The thinner unit with twin fans would fit and cool better for street driven cars, the AFCO unit with fans fit just need them to turn the top inlet tube, CR will do one also if anyone is interested.
    TC
  9. White Trash
    White Trash BMF Hellcat Car Club HCC Charter Member HCC National Vice Pres.
    Oct 23, 2014
    1,107
    420
    258
    (Undisclosed Classified)
    On a race run application the colder the air going into the engine the more HP it makes.
    I have ice tanks pumping ice water into the supercharger cooling the charge. On my Outlaw Car although it's a Turbo it's a makes a difference of 150 HP. The air is 40 degrees off the trans brake and 45 degrees at the end of a run
  10. Racist Cat
    Jan 28, 2016
    1,598
    655
    On my diesel, we would use co2 to cool down hard parts. Just like nos, same bottles, solenoids, etc.
    An idea. Could spray below the supercharger, or the top cover. Even could spray into the center hood vent, and make it look like purging nos, lol.
    Also, we used to use water injection and nitrous together.
    The engine really didn't care for ice in the intake, so, you have to be careful, but, water injection on a super charged car is where it's at.
  11. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,386
    439
    I'm not sure what you mean by AFCO and CR. Are you talking about a different LT radiator or . . . ? The only one I've heard of is the BWoody.
  12. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    AFCO and CR Racing make heat ex changers and radiators , I have used the AFCO on Linda's 2010 challenger race car when we had the 4.2 Kenne Bell super charger on it, CR Racing was very interested in making a unit for the Hellcats.
    TC
  13. TallCool1
    2,439
    829
    Pacific NW
    CR Racing is top notch. I'd love to see someone offer their car as a test mule. They have have a great facility in Indy you can find them here Home - C&R Racing
    When I spoke to them they wanted to do a complete setup engine and sc coolers. They really need a car otherwise all parts including mounts everything cooling related behind the facia, which is what stopped me. That said anyone who works with them will likely get a hell of a deal, they deliver the best and it would open up something for the Hellcat community.
  14. Top Cat
    Nov 26, 2014
    1,925
    1,083
    768
    Doylestown,Pa
    Paul seems like a great guy to work with at CR, I agree someone in the Indiana area should step up, if need be I can get them in contact with Paul.
    TC
  15. TrackDay
    Mar 28, 2015
    1,386
    439
    I can be in Indy in about 3 hours. If he's interested I'll give feedback on how well a LTR cooler does in 20 minute track sessions. Just need to know what he'd like to do to the car and how long he needs it.
hellcat intercooler upgrade
ice tank hellcat
supercharger temperature hellcat
