Aluminum Drive Install???
Discussion in 'SRT Hellcat Performance' started by Just4Fun, Sep 24, 2015.
  1. Just4Fun
    Just4Fun Senior Hellcat Member
    Sep 21, 2014
    101
    33
    68
    I am about to install my Aluminum DS, it came with a large wad of black grease at the front end.
    Can you guys tell me where that grease should and should not be?
    How about the torque specs for the bolts?
    It would be nice if these guys sent some info along with the DS, I know this isn't brain surgery, but a few details would be a good thing.
    THANKS!!!
  2. HCone
    HCone Gold Member
    Dec 4, 2014
    1,052
    305
    call DSS, I did
  3. cole3986
    cole3986 Gold Member
    Apr 25, 2015
    1,762
    912
    563
    Lawrenceville, NJ
    47 ft pounds on the small bolts and 70 on the big bolts if I recall correctly
  4. HCone
    HCone Gold Member
    Dec 4, 2014
    1,052
    305
    You also need to run a bead of silicone around the coupling ( and yes, DSS told me this )
  5. cole3986
    Apr 25, 2015
    1,762
    912
    563
    Lawrenceville, NJ
    I did not use any silicone.
  6. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,064
    645
    413
    So Cal
    There should be a white sticker on the shaft with the torque specs
    57 ft lbs for the smaller 10mm bolts
    70 ft lbs for the 4 large u-joint bolts
    Remove the exhaust remove the stock shaft grease end goes forward to trans put the rear spacer on torq the the 4 large u-joint bolts install exhaust done :D
  7. cole3986
    Apr 25, 2015
    1,762
    912
    563
    Lawrenceville, NJ
    LOL,
    Yes, it takes 30 minutes, NOT. Number 1 the exhaust is very heavy you need at least two people to remove. Two, you must release the transmission which is a pull cord under the cut holder in the car (A8). The release may not lock up, if does not lock up, screw with it to see it locks up or have some keep pulling on it while you rotate the drive shaft. It will not work in neutral, do not even try, Third, the coupling that mounts to the transmission is in close the shaft tube, I could find a hex adapter to torque wrench that fit, had to buy a hex head and grind it down so that I could torque the bolts, Fourth, the diameter of the aluminum shaft is much greater than stock, the passenger side reasonator is in close proximity to the shaft, you need to play with the exhaust install to achieve maximum clearance from the shaft. Other than those items, it is a 15 minute job :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
  8. Link
    Link Silver Member
    Jan 27, 2015
    830
    166
    We just pulled down on the shift linkage from below to rotate the DS and I only took off the rear exhaust hangers and supported the weight with a bungee cord. Gave us plenty of room to remove and install the DS(stock). Still waiting on parts for new AL DS. ;)
  9. Just4Fun
    Sep 21, 2014
    101
    33
    68
    I just spoke to a guy at the DSS, he says the newer DS comes with a seal (O ring I'm guessing) on the front. This seal is there to make sure the grease stays in that area of the DS.
    On older units like mine, he said it is important to use RTV to seal the front face of the coupler. They ask that you clean the two surfaces that will mate, then apply RTV to that surface to act as a seal to hold the grease in. He said that failure to do so in the main reason for DS problems.
    It sure seems like there should be instructions that come with the product if this is important!!!
    I asked if they have anything in writing that spells this out......He said....NO!
  10. Link
    Link Silver Member
    Jan 27, 2015
    830
    166
    THX, thats good to know, right.
  11. HCone
    HCone Gold Member
    Dec 4, 2014
    1,052
    305
    wtf is with companies that have no instructions or ones with sh=tty pics and text that is written by someone that has English as a 3rd or 4th language...sheesh
  12. White Trash
    White Trash BMF Hellcat Car Club HCC Charter Member HCC National Vice Pres.
    Oct 23, 2014
    1,057
    384
    258
    (Undisclosed Classified)
    They dont speak english in China
    • Funny Funny x 1
  13. Plum 16
    Plum 16 Silver Member
    Sep 12, 2015
    238
    87
    Eastern Ventura County, CA
    FSM is very handy in these instances.
  14. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,435
    457
    258
    The Boonies
    theres a factory service manual for these cars? where?
  15. HCone
    HCone Gold Member
    Dec 4, 2014
    1,052
    305
    I have a copy of the factory driveshaft installation/removal, but it does not apply to the DSS shaft, even the bolt torques are different
dodge challenger hellcat diveshaft torque specs
