Anyone done the 3.10 pulley option?
Discussion in 'Metco Motorsports' started by Sammy123, Mar 19, 2017.
  1. Sammy123
    Sammy123 Senior Hellcat Member
    Aug 19, 2016
    217
    74
    Has anyone done the 3.10 pulley options? This supposedly only adds 1-2 psi of boost.
    Can the stock PCM adjust for this or is a tune still required?
  2. B5 MOPAR
    B5 MOPAR VIP Hellcat Member
    Jun 18, 2016
    668
    210
    73
    Calgary, Alberta
  3. HC777
    HC777 Senior Hellcat Member
    Nov 25, 2016
    186
    65
    68
    I would think the computer could compensate for 1-2psi with no tune at all. The maf should tell the computer to add fuel. I would make for dang sure you are running 93 and above tho.
    Curious to see what the WOT wideband numbers look like.
  4. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    333
    180
    The 3.10" pulley is intended for applications also equipped with the Innovators West or ATI overdrive balancer. We never considered it a stand-alone upgrade, but there's no reason you couldn't use it that way.
    As a manufacturer, we would never recommend a pulley change without a tune. However, there may be certain circumstances (or even certain cars) that could get away with this added airflow without the normal PCM revisions. In all situations, we would strongly recommend that the car's tune with the pulley at least be looked at by a competent tuner to confirm that it is safe for all driving conditions.
    My opinion, though, is that this question is actually one best posed to a tuner, as there may be changes necessary to the calibration to take advantage of the higher boost level, like wastegate functionality.
  5. Radride
    Radride Silver Member
    Jan 15, 2016
    1,023
    202
    198
    Up Here!!!
    Rick, I was told by numerous tuners on here that even with the 3.10" pulley alone, a tune is mandatory. That is why some of us haven't gone this route because if you have to tune anyways, you might as well run a 2.85 and make some serious power.
    R.K.
  6. Rick@Metco
    Sep 7, 2014
    333
    180
    Agreed 100%. ^
  7. Mopar22
    Mopar22 Gold Member
    Jan 9, 2016
    274
    126
    New Mexico
    I use the 3.10 with the stock tune, I see about 1.5 lbs of boost. I do live at 5,200 ft asl so it puts me at 9-10 lbs . I use it for cruising around town and when I don't feel like mixing pump 101 with 91 to make 93 octane for my 2.85 pulley and tune.
  8. m.p.l
    m.p.l Rookie
    May 15, 2015
    0
    1
    Germany
    I've now the 3.10" pulley with the ATI 10% OD installed.
    But wich belt is the right?
    The Gates K100594HD (the right One for the ATI 10% OD only) is a little bit to long, i've got belt slip at higher rpm's
    Thx Marc!
  9. Rick@Metco
    Sep 7, 2014
    333
    180
    I don't have belt data on that specific pulley combination, so it may require some quick experimentation.
    Can you post a pic that shows the tension indicator on the back of the tensioner assembly? The image below shows a belt on the tight side.
  10. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,271
    373
    Newport, MI
    Don't u make a larger tensioner to increase belt wrap? That may help m.p.l
  11. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,646
    921
    Suwanee, Georgia
    Yes 594 is big and I'll share the picture since I just put the tensioner and idler pulley from Rick@Metco
  12. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,646
    921
    Suwanee, Georgia
    I've the front view pic at the moment since I had to leave for kids soccer game and would take rear tensioner pic later tonight
    One is OEM tensioner/idler pulley vs Metco.
  13. hellcat562
    hellcat562 Silver Member
    Jun 4, 2015
    433
    154
    I'm running my built hellcat motor on a 3.10 upper on 91 and q16 and 2.6 upper pulley on q16 for my 70 charger built.
  14. Rick@Metco
    Sep 7, 2014
    333
    180
    Sgoyal your belt tension is now on the money...
  15. sgoyal
    sgoyal Gold Member
    Jul 10, 2015
    2,646
    921
    Suwanee, Georgia
    Here's the backside pic of the tensioner
