Anyone else having clutch problems ?
Discussion in 'Dodge Challenger SRT Hellcat' started by Bucks666, Jul 24, 2015.
  1. Bucks666
    Bucks666 Silver Member
    Apr 21, 2015
    175
    62
    Central Ohio
    Well just got my car back from the dealer yesterday , had a pop sound and burnt clutch smell a few weeks ago after shifting from 3rd to 4th at about 4 grand . After that it wouldn't engage easily so took it in and tech said its gotta be the clutch . I don't drive like a maniac nor have I done any burnouts . Been driving manuals my entire life so I know it's not driver error . I went to leave and pull it out of the service bay and clutch pedal dropped to the floor , nothing like the old one at all very weak pedal in my opinion . Had my sales guy take it around and he agreed it's not stiff at all , in fact you could almost shift with barley moving the pedal . Is this normal ??? It's a hydrolic setup so why would it not be stiffer ? I was told to put 100 miles on it and bring it back in ..... Not sure why but service manager gave me that response . They replaced slave cylinder, pressure plate and disc, and flywheel . Any input from some mechanically inclined folks would be greatly appreciated
  2. koda711
    koda711 Hellcat Member
    Apr 24, 2015
    37
    12
    Hartland, MI
    That is not right my clutch pedal is pretty stout, I have gotten on the clutch pretty good since I had the car and it seems to be holding up okay I have been experiencing some vibration in my clutch pedal at 2300 miles but it's not bad.
  3. B5 Blue
    1,745
    If you took your hand and pulled the clutch pedal all the way up and then pushed lightly until you felt a fair amount of resistance what is that distance the pedal moved?
  4. GALTCAT
    GALTCAT Silver Member
    Jan 11, 2015
    216
    50
    What's next? How far would a properly operating clutch move?
  5. B5 Blue
    1,745
    No. Shouldn't move at all
  6. cole3986
    cole3986 Gold Member
    Apr 25, 2015
    1,796
    940
    563
    Lawrenceville, NJ
    In a mechanical clutch it should move about an inch, in a hydraulic clutch it should move at all, as it like a brake pedal, when it moves, it is moving fluid witch should have resistance do to the slave cylinder moving out (due to the fluid pressure) which is depressing the springs in the pressure plate (allowing the disc to disengage from the flywheel). Just adding a little color in what in B5 is saying
  7. cole3986
    Apr 25, 2015
    1,796
    940
    563
    Lawrenceville, NJ
    Jeeze, I mean should not move at all- hydraulic clutch, too much multi tasking
  8. 2510
    2510 BANNED
    Jun 1, 2015
    212
    73
    It sounds like they are searching - why would they change slave cylinder, pressure plate, clutch and especially flywheel - couldn't find issue so let's change everything. No pedal sounds like they didn't bleed properly but that would be unbelievable. Suprised they didn't change throwout bearing also.
    Please keep us up to date, that would be sick if clutches started blowing now also. FUBAR'd the whole drivetrain then....ugh
  9. cole3986
    Apr 25, 2015
    1,796
    940
    563
    Lawrenceville, NJ
    yes, just like your brakes, air will give a spongy pedal, if the pedal is spongy (it may still work) it has air. It should only have air if it was apart and not bled correctly.
  10. Bucks666
    Apr 21, 2015
    175
    62
    Central Ohio
    Sorry guys for the late response just got back in . So I drove it around today for a while and noticed the pedal does have some resistance but not nearly what I had before all this took place . Pedal does go all the way up on its own but feels very soft .Now that you mention air in the system it actually makes some sense . I've driven a few vehicles with air in the brake lines and has the same feel to it . This one is tough to explain but it definitely pisses me off . On a positive note afe got installed today definitely worth it .
  11. Travis Burchard
    Travis Burchard Hellcat Member
    Oct 5, 2014
    102
    21
    18
    Montana
    Same thing with mine after getting it back from the shop, they also said drive it around for awhile. They said no way to bleed the hydraulics, time will tell waiting for spring.
  12. devildoghellcat
    devildoghellcat VIP Hellcat Member
    Dec 16, 2014
    111
    43
    98
    in
    it definately needs bled i had to pump mine 250 + times fully up then full down ...... thats how they are bled mine was engaging right off the floor and felt soft , after all this took car to texas mile and shifted good no problems
  13. Bucks666
    Apr 21, 2015
    175
    62
    Central Ohio
    Yep had it all figured out by the time I traded it in on my A8 . Took it to the track and seemed okay .
  14. devildoghellcat
    Dec 16, 2014
    111
    43
    98
    in
    so how do you like AFE BUCK
  15. devildoghellcat
    Dec 16, 2014
    111
    43
    98
    in
    i have one on too i had it for the texas mile thought my car ran good
2011 challenger rt clutch feels soft
2015 dodge challenger srt hellcat hydraulic clutch
2015 dodge hellcat clutch problems
hellcat clutch
hellcat clutch failure
hellcat failed number two cylinder
srt challenger throwout bearing
