Anyone figure out how to jump the cooling fans
Discussion in 'SRT Hellcat Performance' started by paul suloff, Aug 4, 2015.
  1. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    714
    247
    Want to run them with engine off to cool at the track.
    Old cars could do it by jumping the fuse with some alligator clips. Terminals are different in 15s.
  2. B5 Blue
    1,745
    Nope:mad: Pulse width signal from ECM
  3. paul suloff
    Aug 25, 2014
    714
    247
    Would think you could find the power supply at the plug for the fans and jump it from the hot terminal and ground under the hood?
  4. B5 Blue
    1,745
    The cooling fan is a module already has constant power and ground, the third wire is from ECM and is a pulse width signal sent to fan module (fan) no way to jump anything like 2014 on down
  5. Nycsrt
    Nycsrt BANNED
    Nov 19, 2014
    1,651
    806
    563
    It my mistake of information you can turn it on hp scanner not suite (scanner)or start wit this wire diagram
  6. Racist Cat
    Racist Cat Gold Member
    Jan 28, 2016
    1,597
    652
    Bump.
    On our dodges we used to put a switchable resistor in the water temp signal to trick the truck into 240* water temp, high idle, and full fan would ensue.
    Might be able to leave the ignition on, and trick the car into thinking high water temp? I know some cars will run the fans engine off if excessive water temps.
    A thought.....
  7. clickr
    clickr Silver Member
    Apr 18, 2015
    380
    118
    what ever you do, might want to unplug the fan first so you don't feed any current back upstream to the computer. Might have to make a jumper wire set and power it from an aux. battery. Then when you are ready, unplug and replug into the original wire connector.
  8. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,224
    614
    413
    PASADENA, CALIFORNIA
    Could turn your PCM into a Samsung Note 7
  9. yellaheep
    yellaheep Gold Member
    Jun 13, 2016
    210
    104
    Littleton Colorado
    With the car not running, and fans on, all you're cooling is the fluid in the radiator...... why not let it idle with the A/C on? The A/C being on triggers the fans to run and at idle, the water pump will be circulating coolant through the engine.
    If you want it cooler than idle temp, maybe get a large cage fan and have it blowing into the lower grille to hopefully get air through the radiator and around the block to cool it?
    [​IMG]
  10. Mike Comp T/A #57
    Mike Comp T/A #57 Gold Member
    May 17, 2016
    350
    306
    433
    Batavia, Ohio
    You have to start the car ever so often to let the water circulate.
jump cooling fan
