Anyone found a way through firewall for wires?
Discussion in 'SRT Hellcat Electronics' started by Harts, May 16, 2015.
  1. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    Temecula, California
    Looking to bring in a few wires from engine bay to interior, anyone know where this can be done at? Don't want to drill any holes.
    Thanks in advance
    John
  2. B5 Blue
    1,745
    That would be nice to know for me as well
  3. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    Ok, found a way! Open hood, drivers side near firewall there is a cover, pop it open
    Look at bottom right you will see body plug with wires loom, gently pull out the plug and route your wires. I would recommend wrapping wire(s) with friction tape to avoid wear and possible short. If adventurous unwrap existing tape, insert your wire(s) then re-tape
    Reinsert the body plug. In the interior the wire(s) will be above and to the left of the brake pedal.
    I did not wrap my wires yet as I have a couple more to bring through, but ran out of time today.
    Hope this helps!
  4. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    What's the plans for the interior??
  5. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    70.196059, -148.559760
    Harts great info. Have you considered drilling a hole through the body plug outside of the existing wires? This will allow you to get a wire (or a few wires) through the plug while not having to worry about the firewall sheet metal chafing the wires you run.
    If you go this route you can drill a hole in the plug, stick a wire hanger through the hole, give it a spray of silicone and your wires should glide right through. Finish it off with a dab of black silicone around your wires to seal it up nicely.
  6. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    I am wiring in a Curb Alert PRO Parking Sensor 5000-CA5 unit. I already installed the sensor and working on the wiring. Not having a front parking alert with the air dam is costly if we bump a parking stop! Once completed I will post step by step instructions if anyone is interested.
  7. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    That would work even better! Would have saved me all the scraps and bruises on my arm too! Thanks!
  8. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    You can probably poke a hole through that plug with an awl too rather than drilling... I haven't looked at that plug so not sure how much room there is to work there but probably not much! Maybe even file a point on a small piece of wire hanger and work that through.
  9. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    It is tight, but think I will heat up the end of a hanger and have it melt it's way through, route the wires then dab with silicone to seal it. Rotate the plug so my wires are on the bottom and don't show as much. Wish you were here earlier, could have done it that way the first time!
  10. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    Mounted the parking sensor behind the lower grill
  11. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    I'm glad the suggestion is helpful. I'd be a bit concerned about that wire chafing over time. If it's carrying voltage that definitely won't be good.
    I can't tell you how many times I've done something only to either think of a better way or have somebody suggest a better way and then I've done it over. ;)
  12. hellcat1
    Sep 27, 2014
    10,672
    2,030
    Is it that tiny little black box??
  13. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    YUP! wire feeds to interior and connects to "brain" and buzzer. Ran out of time today hard wiring it all up, but did test it and it works, gives beeps when I am 20 inches from a parking stop that is 3 inches or taller. With any luck I can find power under the dash and finish it up over next few days.
    Here is a closer picture of sensor, it is about 1 1/2 inches wide and about 3/4 or 1 inch tall.
  14. hellcat1
    Sep 27, 2014
    10,672
    2,030
    That's really cool.. Doesn't take away anything from the front, great idea,, will save your from spoiler...Great job...need to make this a sticky...
  15. Harts
    Harts Gold Member
    Sep 25, 2014
    211
    124
    Once I finish up the wiring I will write up instruction and have pictures of install. Will post it all up when completed
getting wire through firewall challenger
holes in firewall 2012 challenger
running wire through firewall dodge challenger
