Anyone have a small bubble in there carbon stripe?
Discussion in 'SRT Hellcat General Discussions' started by slicks, Jun 18, 2016.
  1. slicks
    slicks Rookie
    Mar 8, 2016
    16
    2
    Just noticed small bubble in back lower stripe on my cat :(
    Tried to press it out but it wont go?? Any suggestions...not sure on warranty because they may not get another on exactly !!
    Thoughts?
  2. sliknik
    sliknik Silver Member
    Dec 24, 2015
    143
    38
    Nor Cal
    you should return the car and buy another one! with no stripes. won't have that issue!
    • Funny Funny x 1
  3. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,004
    475
    403
    Westchester
    Factory stripes have always sucked, Install wise they put literally the bare minimum glue for it to stick. Meaning you mess up a little and attempt to correct it, won't stick. The workers aren't given the time to put them on properly so you end up with bubbles.
  4. Hayabusa
    Hayabusa Gold Member
    Jun 13, 2015
    481
    367
    513
    The Lunatic Fringe
    The first time I had a clearbra put on a car (many years ago) the installer gave me a syringe out of a whole box of new syringes he had. He said to leave the car in the sun for a couple of days to help it cure (water under the wrap to evaporate) and to carefully push any bubbles towards the edge with the pad of my thumb so air/water trapped move out. He said to use the syringe, inserting at an angle, to draw air/water out of larger bubbles and follow previous instructions. It worked okay but...
    ...after having a bunch O' cars, trucks and bikes with clearbra the learning is, if applied correctly, the film lays right, there aren't impurities that cause bubbles, and you don't need a damn syringe laying around! as many have said, it's the skill of the installer as well as the quality of the film
    If it's a minor bubble you can try the above and hope it works. I'd guess a thicker material is better for success.
    Cubeman is spot on...and when there is an attempt to correct by lifting the film you can end up with a section that looks like a scab on a rhino's knee :eek::oops:o_O
  5. Steven_sbs
    Steven_sbs Browncoats Unite Gold Supporting Member
    Dec 18, 2014
    843
    345
    South Jersey
    Three things you might try:
    1) leave the car in the sun for a few hours. The heat should relax the stripe. Press the bubble with a cloth wrapped over a piece of plastic (like a credit card).
    2) Take the car to a vinyl wrap auto body place. They have all kinds of tricks to remove trapped air bubbles.
    3) You could poke a very tiny pin hole in the bubble to let the trapped air escape. Then go back to step 1, then proceed to step 2.
  6. CubeMan
    Dec 31, 2014
    2,004
    475
    403
    Westchester
    Yep, Just to repeat what Hayabusa said. If an installer gives you anything to fix or correct stripes after install. He didn't do a proper install OR he isn't confident in his work.
  7. slicks
    slicks Rookie
    Mar 8, 2016
    16
    2
    The pin hole worked just fine :) Thanks all !!!
