Anyone Remove Their Hoodmat?
Discussion in 'SRT Hellcat Performance' started by VanishingPoint, Jul 4, 2015.
  1. VanishingPoint
    VanishingPoint Silver Member
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    I am tempted to do this, because I think it will allow more air moving over the S/C, and allow more S/C noise to come through.
    Where can I get those replacement clips, and are they easy to remove, or does there exist a chance parts could break off and fall within the hood, never to exit?
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    I have taken mine off,,,I had to cut the clips off,,I tried for ever to pop then out,, no luck... Napa auto parts will have the clips/ push tabs for under 6 dollars, don't go to the dealer,, they 5 dollars a piece.. keep in mind that your windshield washer lines are under your hood. You will need to two way tape them to keep them off your engine
  3. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,439
    943
    668
    Cape Coral, SW Florida
    My 08 Bee was never equiped with a insulation pad from the factory. Only thing to think about is, I believe the underneath of the hood is not clear coated. At least it wasn't on the older models.
    If you need clips for the washer lines, check out the older cars for ideas.
  4. VanishingPoint
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    Thank you. How did you do it without losing the pieces holding it? What technique?
    What were the results?
  5. Top Cat
    Top Cat Gold Member Hellcat Car Club Fastest Cat/Record Holder HCC Charter Member
    Nov 26, 2014
    1,925
    1,080
    768
    Doylestown,Pa
    Removing it will do jack as far as temps
    TC
    • Agree Agree x 3
  6. hellcat1
    Sep 27, 2014
    10,672
    2,030
    I ended up cutting the nine clips with a pair of dike cutters... The other parts will make there way out sooner or later....
  7. VanishingPoint
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    I am sure if it did anything it will be immeasurable, however, anything that lets any more air around it can't be a bad thing. As well as potentially removing the rear hood seal, drilling additional vents, etc. Somewhere, somehow, I feel some of these things should add up
  8. B5 Blue
    1,745
    Why would you do this? Leave it on!
    • Agree Agree x 7
  9. VanishingPoint
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    1. I want more supercharger noise
    2. It is part of my plan to find away to get more hot air out from under the hood which is more of a project.
  10. hellcat1
    Sep 27, 2014
    10,672
    2,030
    You can hear the supercharger more without the under hood blanket,, if you want more air flow take the seal out from were the hood meets the windshield, you will get more air flow, and hear the supercharger a lot more,, just be careful of water getting in..
  11. Paladin06
    Sep 3, 2014
    4,701
    1,853
    San Tan Valley, AZ
    This is one of those threads that makes me scratch my head.:confused:
    • Agree Agree x 3
    • Funny Funny x 1
  12. theriotmaker
    theriotmaker Rookie
    Apr 24, 2015
    17
    6
    Just remember, not having a barrier between the heat under the hood and the hood and it's paint will negatively effect the paints wear over time, due to possible extremely high Temps at the middle of hood.
    But F**k the world is your hellcat, do it your way!!!!
    • Agree Agree x 3
    • Funny Funny x 2
  13. Paladin06
    Sep 3, 2014
    4,701
    1,853
    San Tan Valley, AZ
    The world, really?
    • Funny Funny x 2
  14. VanishingPoint
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    I am experimenting with my laser temp gauge, and the heat. I will develop a more conclusive report at a later date.
    I have removed the rear hod seal prior-and it did work for S/C noise and definitely-definitely moved more air from under the hood (it bowed up less at certain speeds speed). Still I felt like it made the hood more wonky than it already was.
    Further, people always say that about the paint, and I wonder how true that is. After sitting I will measure the hood with out the blanket, and without to see what is coming through,
    Expect a full report at a later date.
    For instance, did you know that for some reason, my passenger side of the engine runs 10 +/- degrees hotter than the driver side?
    Measurements ranged from the hood vents, the cylinder covers (front & rear), even the pax side of the supercharger was hotter.
    Obviously, I hope there is a reason for this-and not that one bank is running lean :(.
    • Useful Useful x 4
  15. VanishingPoint
    Jan 6, 2015
    923
    235
    Somewhere, Texas
    Still working on temp checks. The hood can get to like 150's, the main inlet snout is sometimes 180's.
