Anyone running 18" wheels on the street?
Discussion in 'SRT Hellcat Wheels and Tires' started by terryturner, Dec 31, 2015.
  1. terryturner
    terryturner Gold Member
    Apr 1, 2015
    1,184
    319
    Newport, MI
    Considering switching to 18s to give me a little more sidewall. Thinking 275/50 on 18x9 up front and 305/45 on 18x10.5 in rear. Any thoughts? Pix? I have read that the rear wheel may require a shorter sway bar depending on offset. Prolly will go with the shorter sway bar so I can tuck the wheel a little more than it sticking out.
  2. Billet Hellcat
    Billet Hellcat Gold Member
    Dec 2, 2014
    1,064
    646
    413
    So Cal
    Terry I'm running 18" for my drag set specs are Thriumph 18x10.5" with 27mm offset and yes you need shorter sway at links in rear I shortened my stock links 1 1/4" to fit the wheel I'm running a 305/45/18 MT Street R hook up is way better than the 20's 1.49 60'
  3. BLK_MAGIC
    BLK_MAGIC Silver Member
    Dec 11, 2015
    412
    162
    Did you shorten them and did you do it yourself?
  4. Billet Hellcat
    Dec 2, 2014
    1,064
    646
    413
    So Cal
    Yes I did shorten them 1 1/4" and did it myself ;)
  5. BLK_MAGIC
    Dec 11, 2015
    412
    162
    You must be a good welder.
  6. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,183
    585
    413
    PASADENA, CALIFORNIA
    I have 18X10.5 +25MM offset and I had to have shorter sway bar links too. I installed the ones from HHP ($85). But they are way shorter than needed because they are designed to clear 17" wheels. I would think they are about 1-1/4 inches shorter, but I did not measure the difference.
    The Bravado Tribute wheels just barely clear if your car is stock ride height. They are 18X10 with a +20 offset. So adding to the offset and width makes the wheel hit the sway bar.
    My tires are 305/40R18 ET Street S/S.
  7. dragrcr
    dragrcr Gold Member
    Sep 30, 2015
    1,183
    585
    413
    Also, 18's won't fit on the front of a Hellcat. Not sure what you have???
    Be sure and relocate your SHOCK control wires out of the way so they don't rub on your wheels. They can be pushed to the center of the car and tie wrapped etc. In some cases they can be slid in the existing holders with some effort.
  8. terryturner
    Apr 1, 2015
    1,184
    319
    Newport, MI
    18s won't fit on the front due to the massive calipers?
  9. paul suloff
    paul suloff Silver Member
    Aug 25, 2014
    701
    237
    CCW and Bogart are making a 18x6" wheel for the front. (wheel has shallow well that clears calipers) Otherwise need to change brakes to a smaller pkg.
  10. terryturner
    Apr 1, 2015
    1,184
    319
    Newport, MI
    Screw that. I'll stick with the 20s then. Thanks for the info everyone
18 x 10 bravado challenger
bravado tribute 18 inch wheels dodge challenger
