ATI 918999HC Hellcat damper installation stud needed or alternate
Discussion in 'Dodge Challenger SRT Hellcat' started by dhg66, Apr 11, 2016.
  1. dhg66
    dhg66 Hellcat Member
    Aug 31, 2015
    80
    9
    Borger Texas
    Anyone have any leads on where to purchase the ATI 918999HC Hellcat damper installation stud, ATI is out of stock and all they can say is that they are being made with no idea of when the will be available. We are at the point of ready to install the ATI damper/pulley and would ideally like to have the stud asap Any help or suggestions is much appreciated
  2. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    Are you referring to the crank bolt?
  3. dhg66
    Aug 31, 2015
    80
    9
    Borger Texas
    no not the crank bolt, the stud adapter that is required to thread into the crank on one end and the other end is 5/8 16 thread ( IIRC ) that threads into the damper installation tool
  4. TNCHARGER
    Nov 19, 2015
    1,218
    475
    408
    Understood. You might try calling AJ Berge at Hemituner Performance. I got my kit from him. He might have them or a lead for you. 516-603-9276
  5. dhg66
    Aug 31, 2015
    80
    9
    Borger Texas
    thank you will do
  6. dhg66
    Aug 31, 2015
    80
    9
    Borger Texas
    I found two damper install kits that have the M16 x 1.5 adapter stud and ordered both from Amazon for insurance if one just happens to be bad or breaks, we should be able to finish the install this coming weekend
  7. Fionn MacCumhaill
    Fionn MacCumhaill Irish A'Hole - Wanna Fight About It!? Hellcat Car Club HCC Charter Member
    Nov 14, 2014
    605
    300
    Denver Colorado
    Is this damper install kit specific to the ATI damper or is it needed for any damper swap on a Hellcat? I am ordering an Innovators West 9% OD kit this week and would like to know if I need this install kit for my swap also. Thanks!
  8. TallCool1
    2,439
    829
    Pacific NW
    Those are sweet! Any cutting of bolt heads to fit like the ati?
  9. Fionn MacCumhaill
    Nov 14, 2014
    605
    300
    Denver Colorado
    When I asked them, they said no cutting of bolt heads or timing cover needed; that is why I went with their product over ATI. I will know for sure when I get it installed and will let you know the outcome.
  10. TallCool1
    2,439
    829
    Pacific NW
    Thanks a bunch.
  11. Fionn MacCumhaill
    Nov 14, 2014
    605
    300
    Denver Colorado
    Still would like to know if I need this damper install kit the OP was talking about. It would suck if I find out I need it after the front clip is torn down and it holds up the install. dhg66 any idea on this? Is the install kit you asked about only for the ATI kit or is it needed for any damper swap?
    Thanks!
  12. TallCool1
    2,439
    829
    Pacific NW
    If innovator's can't help, maybe ask Speedlogix they've sold this line?
  13. dhg66
    Aug 31, 2015
    80
    9
    Borger Texas
    Hi
    you need a damper install kit that has a M16 * 1.5 mm pitch threaded stud. It is not specific to the ATI damper. Most damper install kits do not have this M16 * 1.5 mm pitch threaded stud. There are some damper install kits on Amazon that have 12 different adapter studs and with this many one is usually the M16 * 1.5 MM one, but you need to confirm to be sure.
    You do not need to tear down the front clip, just drop the fans out the bottom of the car, they will not come out the top. Make sure you get a new damper bolt I think the HHP pinning kit comes with a new bolt but the ATI pinning kit does not. Have something to lock the flexplate so you can apply enough force to break the damper bolt loose and retorque the new one to the 239 ft lbs. We ( my friend) fabricated a lock to fit the flexplate teeth out of some flat bar. Buy a small air operated drill, these are smaller to fit in the tight areas so you can drill the hole(s) to pin the crank. Hope this helps.
  14. dhg66
    Aug 31, 2015
    80
    9
    Borger Texas
    Here is a link to one of the damper install kits with the right stud
    Amazon.com: Cal-Van Tools 38800 Harmonic Balancer Installer: Automotive
  15. TallCool1
    2,439
    829
    Pacific NW
    When do you think you'll tackle this?
innovators west hellcat damper
