back space
Discussion in 'SRT Hellcat Wheels and Tires' started by ROBY IRLE, Feb 7, 2015.
  1. ROBY IRLE
    ROBY IRLE Silver Member
    Jan 17, 2015
    144
    29
    can some one tell me the back space for the cat
    thanks rob
  2. B5 Blue
    1,745
    I'd keep it at 2 feet minimum so I have room to walk around it:D
    18 mm is what I hear
  3. ROBY IRLE
    Jan 17, 2015
    144
    29
    back space not off set
  4. B5 Blue
    1,745
    D'oh:eek: Sorry
  5. ROBY IRLE
    Jan 17, 2015
    144
    29
    LOL
  6. hellcatfast
    hellcatfast Hellcat Member
    Dec 11, 2014
    74
    25
    Backspace = 1/2 outside rim width + offset (if positive) 10.5 outside rim width 5.25 + .703 (18 mm ) = 5.953 backsspace
  7. Ricci Cavallaro
    Ricci Cavallaro
    Record Holder
    Fastest Stock Cat
    Oct 15, 2014
    353
    251
    513
    You seem pretty knowledgeable on the wheels. How can I tell if a wheel will fit before buying and trying? In looking at a couple, one 20x10 with a 20mm offset.
    Another with a 25mm offset. Both come in 10.5 too. Want to use for track with Mickey Thompson 305/35/20 DR's. Any opinion or recommendation? Companies said for Hellcat but how will they fit with that tire? I know people have put these on stock rims without issues. Any help would be appreciated!
  8. Jim Hetrick
    Jim Hetrick Silver Member
    Dec 5, 2014
    1,338
    264
    108
    Orange County Cal
    People selling wheels are in most cases refering only to wheel fitment for the reason you have already stated, they dont know what tire you will be putting on. So when you ask them questions listen closely to there response about what they are saying and ask tire info with facts such as Tire diameter ( not rim diameter)and width etc.
  9. Ricci Cavallaro
    Ricci Cavallaro
    Record Holder
    Fastest Stock Cat
    Oct 15, 2014
    353
    251
    513
    Well None of the Companies selling the wheels will recommend anything over the stock size tire. So I guess it's a $1200 guess? Or wait until someone else tries the same wheel and tire combo.
  10. hellcatfast
    Dec 11, 2014
    74
    25
    There are several wheel tire combo calculators you can use to bounce the stock combo to modified combos. A couple of these are RimsnTires.com and Wheel-Size.com. I replaced the stock rims and summer tires with foose legends 22x10.5 with michelin super sport tires 295-30x22 and the dimension results from the calculator were dead on. For the 295-30 the rear fit fine put the front i used a 1/8 spacer, you can grind down a little nipple at the top of the spindle arm and not use the spacer. The height of the front tire is limited to about 3/4 inch taller than stock because of the ball joint bolt (which can be shorten if you cut the threads below the nut) and the section width can not be more than approx. .4 inch greater than stock if no spacer or grinding. In short , the calculator will give you dimensions and you can measure on your car, i used the calculator and purchased my tires before i had the car.
  11. hellcatfast
    Dec 11, 2014
    74
    25
    One thing i forgot to add, remember to add 1 inch to rim width to get outside rim width used in calculators. Example, hellcat rims are 9.5 but that is tire mounting inside rims lips, they are approx. 10.5 outside width used for calculations.
  12. hellcatfast
    Dec 11, 2014
    74
    25
    Ricci, please disregard the last post about calculator using outside rim width, double checked and the tire mounting width (inside) is what the rimsntires used. sorry
  13. ROBY IRLE
    Jan 17, 2015
    144
    29
    I have a rocket racing [booster , hyper shot wheel ] coming for test fit my car is granite color will put pics up asap
  14. baabootoo
    baabootoo Hellcat Member
    Sep 19, 2014
    68
    15
  15. 1FSTCAT
    1FSTCAT The Punisher
    Dec 28, 2014
    1,130
    408
    358
    Virginia
    Post some pics please.
2016 charger on foose legends
back space for 2016 dodge challenger
