Barton Pistol Grip Shifter
Discussion in 'SRT Hellcat General Discussions' started by Hugh Jorgan, Dec 15, 2015.
  1. Hugh Jorgan
    Hugh Jorgan Silver Member
    Oct 27, 2014
    456
    128
    I'm in the middle of installing the Barton shifter which is fairly straightforward, but the only issue is the neck of shifter is wider than the stock unit and I do not see how the factory boot is going to fit on it. Has anyone else installed this shift lever & if so, how did you get the boot on?
  2. Sublimecat
    Sublimecat Silver Member
    Oct 2, 2014
    921
    339
    173
    Akron, Ohio
    Barton will tell you to turn the boot inside out. Underneath near the top of the boot there is a plastic ring that holds the boot tight around the stock shaft. You have to gently pull the leather apart from itself where it is glued together and remove the ring. Once the ring is out the leather will stretch over the shaft of the shifter.
  3. Sublime 70
    Sublime 70 Gold Member
    Oct 21, 2014
    260
    118
    I used a screwdriver which widened as the handle got bigger , put some leather softener on it put the end in the shifter boot....let it sit for a while and the leather stretched .....making it slip over the barton handle.....worked great.
  4. SRT_HC_707
    Jan 1, 2015
    4,953
    1,444
    70.196059, -148.559760
    How about some gratuitous pictures of your installed Barton pistol grips. I get it looks sweet!
  5. Hugh Jorgan
    Oct 27, 2014
    456
    128
    Got it....Thanks!
  6. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    pictures and your review on the product and install. plez
  7. owenspackman
    owenspackman BritishCat
    Feb 11, 2015
    975
    516
    368
    Charleston SC
  8. Hugh Jorgan
    Oct 27, 2014
    456
    128
    I installed a Hurst shifter in my '10 Challenger years ago & changing the mechanism is fairly easy. I needed to learn what to take apart on the console & because Barton doesn't include instructions with their shifter had me surfing the web to find out how to take it apart. That being said, it comes apart very easy with basic metric tools. The only thing I recommend getting is plastic trim removal "levers" so that you can take the console trim plate off without scratching it. The nice thing about their pistol grip shifter is that you can adjust the lever fore, aft, left & right to fit your comfort level. I installed it last evening & I have yet to drive the car, but there is a night & day difference between the factory shifter & the aftermarket ones. DSCF8089.JPG DSCF8090.JPG DSCF8090.JPG
    • Like Like x 5
  9. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,737
    504
    423
    Henderson, NV
    Wow that's sharp. Always loved the pistol grip. Good job
  10. Sublimecat
    Oct 2, 2014
    921
    339
    173
    Akron, Ohio
    Nice install. That pistol grip looks sharp. My install below
  11. carcass
    carcass Silver Member
    Sep 7, 2015
    858
    267
    173
    friggin rights. those look awesome. both the pistol grip and ball shifter are good choices, I'm getting one and putting it in with a better clutch around spring time.
    Going to have a hard time choosing between the two.
  12. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    Does the plastic trim tool scratch or ding up the console when prying with it?or leave marks?
    Thanks
  13. Hugh Jorgan
    Oct 27, 2014
    456
    128
    No. You use it to pry up the console top enough to free a couple of the retaining clips & once those are free you can just simply (and carefully) pull the top up to free up the rest of the clips.
  14. bugeye1959
    bugeye1959 Hellcat Member
    Apr 20, 2015
    68
    13
    Okatie, South Carolina
    I think back to the pistol grip that I had in my 1970 340 Challenger, and how cool I thought it was. Now for the 64000 dollar question, which Barton shifter does everyone think would feel the best when rowing through the gears on a drag strip or road course between the pistol grip and the ball shifter?
  15. SRT MANG
    SRT MANG Silver Member
    Dec 29, 2014
    533
    160
    DELAWARE
    Once you get the shift boot off, is it self explanatory how the factory shifter comes out?
    Also, if there are no instructions with the Barton, how did you go about adjusting fore, aft, left and right?
barton pistol grip shifter
barton pistol grip shifter challenger
barton shifter challenger
barton shifter for challenger hellcat
hellcat pistol grip
hellcat pistol grip shifter
pistol grip shifter for srt challenger
stretch leather over pistol grip
