Battery Tender
Discussion in 'SRT Hellcat General Discussions' started by tsubahog, Oct 25, 2015.
  1. tsubahog
    tsubahog Gold Member
    Mar 30, 2015
    349
    161
    NJ
    I have seen a few thoughts about this on the forum but want to clarify it.....
    Where do you hook up the battery tender without the trunk light staying on?
  2. Aaron Vogel
    Aaron Vogel Gold Member
    Jan 23, 2015
    1,452
    263
    Everywhere
    Just close the trunk, that's what I did. Or unplug the light
  3. WNY Cat
    Nov 16, 2014
    575
    369
    513
    I removed the light. It's easy.
  4. flanman
    flanman Silver Member
    Sep 18, 2015
    139
    35
    Belvidere, IL
    I hooked it up to the terminals in the engine compartment and leave the hood partially latched.
  5. Cdub
    Cdub Gold Member
    Sep 18, 2015
    155
    86
    278
    On my 392...I make the latch latch with the blade of a screwdriver.. as it it were closed... that turns the trunk lamp off as the lamp switch is incorporated in the latch... then I just lower the deck lid until it rests on the "closed" latch... leaves the trunk open a 1/4" or so.. In the spring.. push the truck release button... the latch opens and the lamp starts working as prescribed. I "assume" this procedure will work on the Hellcat as well. But all other options work too ;)
  6. nocarbutmopar
    nocarbutmopar Silver Member
    Oct 21, 2015
    398
    120
    New Mexico
    that's a long post
  7. Hemi_SRT8
    Hemi_SRT8 Rookie
    Sep 16, 2015
    14
    2
    use the engine compartment...
  8. Richard g
    Richard g Silver Member Hellcat Car Club Gold Supporting Member
    Dec 18, 2014
    273
    70
    South Carolina
    The trunk light is on a timer & goes out after a few minuets with trunk still ajar.
    • Useful Useful x 3
  9. Plum 16
    Plum 16 Silver Member
    Sep 12, 2015
    242
    94
    Eastern Ventura County, CA
    I've been using Battery Tenders for years in the collector cars. A couple of suggestions if I may:
    1. There is enough cush in the trunk seal so that if that if you are going to the battery directly, you should be able to close the trunk fully with no problems.
    2. I make a small "pigtail" with a two conductor connection (like a flat trailer light connection but just two polarized conductors) and have it either sit in the trunk or through the grill. The other end is hard wired to the battery the hot lead in the engine bay. This way, while the car is laid up, if you want to take it out, you don't have to go through the whole clip/unclip procedure with the leads. Just unplug the pigtail.
    I'll take a picture if someone wants to see.
  10. jaque
    jaque Silver Member Hellcat Car Club HCC Charter Member
    Apr 6, 2015
    532
    140
    chicagoland
    yes post pic please.
  11. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,770
    Wisconsin, USA
    I hook up under the hood and drop the power cord under the car and plug it in.
    you can place the car in Storage model or Shipping mode ( check the threads).
    just make sure the cord does not hit the belts or fans in case you fire it up.
  12. soundman5000
    soundman5000 Silver Member
    Jun 25, 2015
    531
    122
    I have used a Battery Tender on my Harley from 1997 to now! I am on my 4th or 5th battery on an almost 20 year old bike, not bad IMO but won't last a year without a maintainer. I have had bad luck with the actual " Battery Tender" brand but have had great luck with the $27 Advance auto house brand and the Schumacher brand of maintainers over the years. The Battery Tender brand was not lasting as long as the battery it was protecting. On the 3rd tender fail with the same battery, I changed brands.
    I use the included hardwired pig tail on my Harley so I just do the quick disconnect but can't exactly figure out how to wire that under the hood of the cat permanently I use a car cover and would be nice to have the pig tail permanently hardwired with the end out the bottom of the engine bay with the quick disconnect so I don't have to open the hood every time I hit the road.
    For now, I just uses the clips connected under the hood and works well. I would think the trunk would be lots more trouble but never tried it...
    If anyone hardwires your tender please post some pics!
  13. HELLKAT_NY
    HELLKAT_NY Silver Member
    Jun 3, 2015
    333
    131
    113
    My battery tender just keeps blinking charging, never goes to green anymore. I checked the fuse and it's fine, any thoughts? Is the BT bad?
  14. Plum 16
    Sep 12, 2015
    242
    94
    You should check the site. A lot depends on the model you have. I am pretty sure the basic BT Plus (in the metal case) has a 10 yr warranty. I have had to replace them before.
    Be sure all of your connections are really good. Clean them if necessary. If there is any resistance it will think the battery is not charging.
  15. soundman5000
    Jun 25, 2015
    531
    122
    When mine did this the battery was going bad. Even a new battery can have a bad cell. I agree with the post to make sure all connections are clean and tight. Only way to check the battery is to have a free load test done preferably at the dealer. I had 3 battery tenders got bad but my memory fails of what the lights were doing or not doing at that time. I say check your battery tender by charging another car and that will tell you if it is the tender or a bad battery,,,
    Good Luck!
battery tender on hellcat where
using a battery tender on new challenger
