Black Plastic Trim
Discussion in 'SRT Hellcat Detailing' started by Dakman, Apr 25, 2015.
  1. Dakman
    Dakman Silver Member
    Nov 12, 2014
    226
    102
    Mystic, CT
    Hey all looking for some advice to get the polish, sealant and wax off of the black trim around the head lights and along the bottom of the car. I cant seem to get it off and even tried covering it up with back to black but it always finds its way back to the surface. Spent the last week (yeah I'm that slow) scrubbing the hell out of the SRT8 from this past winter abuse in prep for trading it in on the hellcat and this is the last detail I need to take care of. Any advice you can throw my way would be greatly appreciated.
    ~Jeff
  2. X-Men Fiend
    X-Men Fiend Gold Member
    Oct 25, 2014
    1,684
    579
    423
    East Phoenix Valley, AZ
    This is something I'm curious about too. Sorry I don't have the answer, but will be watching for somebody who does! Also, anybody have advice how to get rid of water spots. I got them off the painted areas, but the ones on the windshield seem indelible for some reason. I used windex, and rubbed and rubbed, and it got the center portion of each spot out, but left the telltale rings, and I mean like hundreds of little rings, all over my windshield in the Hellcat. I used windex like five different times, even letting it soak in, and rubbing till my arms were tired, and those little circular spots are still everywhere, it's infuriating I tell ya'!!!!
  3. CO Springs Sublime Kitty
    CO Springs Sublime Kitty Gold Member
    Apr 2, 2015
    203
    125
    Use a heat gun. Brings the black right back, no need for products that make it "shiny". They actually just dry it out in the long run. Good luck!
  4. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    Honda spray works amazing on all surfaces except glass!
  5. Carnage
    Sep 21, 2014
    12,107
    3,271
    823
    Houston, TX
    You said Honda sis o_O
  6. HellcatKid
    HellcatKid Silver Member
    Dec 21, 2014
    116
    CANADA
    Don't use hard water on your 70 k car use a water softner and rinse with demineralized water problem solved
  7. Dakman
    Nov 12, 2014
    226
    102
    Mystic, CT
    Never heard of using a heat gun, do have one sitting on the bench next to the car will have to give this a try, thanks.
    I figured you would have some magical fix Tammie :p is this stuff mostly sold online or can it possibly be found at a some store?
  8. CO Springs Sublime Kitty
    Apr 2, 2015
    203
    125
    Anytime. I don't use products on plastics. They tend to speed up the worn out look. A heat gun will bring some of the black polymers back to the surface. There's probably youtube videos on the process.
  9. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
    70.196059, -148.559760
    Two things you may want to try.
    - IPA solution -- mix distilled water and 70% (or 9x% doesn't really matter) isopropyl alcohol to a ratio that is 15% alcohol. Don't get to hung up on the percentage. Even if you eyeball 1/3 to 2/3 water you will be fine. Spray it on, let it sit a bit and agitate it with a microfiber cloth. It won't hurt your paint but will remove wax on the paint
    - Peanut butter. Get some smooth peanut butter and using your finger or a cloth use the peanut butter like polish. Clean up with the solution above when done.
    One of these will most likely do it.
    I'd seriously consider switching to a product that doesn't leave white residue on the plastic. It's such a hassle to cleanup.
  10. noboost4you
    noboost4you <Insert witty title here>
    Oct 30, 2014
    554
    151
    Cleveland, OH
    x2 on the peanut butter.
    "non-whitening on trim" - Amazon.com Meguiar s G18216 Ultimate Liquid Wax - 16 oz. Automotive
  11. SRT_HC_707
    Jan 1, 2015
    4,932
    1,429
  12. CO Springs Sublime Kitty
    Apr 2, 2015
    203
    125
    Like I said, I don't use products on plastics. They all seem to age the plastic faster causing the need to revive it. When doing so, the only permanent method I know of is a heat gun. Other products will only improve the look for a short time, then it will look worse.
  13. Dakman
    Nov 12, 2014
    226
    102
    Mystic, CT
    Thanks for all the tid-bits everyone, guess its time to peel myself off my couch since its a beautiful day outside to go can try them all.
  14. MikeD1
    MikeD1 Silver Member
    Mar 17, 2015
    798
    188
    Central FL
    I'd be real careful with the heat gun, very easy to overdo & create more problems then you are solving ! Also, seems like it would cause the plastic to dry out & age prematurely.
    Way better to use the p-nut butter or the spray SRT_HC_707 provided a link to.
    When waxing I mask off all the trim on the car with blue tape. Takes a little while, but faster in the long run than trying to be careful not to get wax on the trim & then cleaning up the spots that got nailed anyway. Just don't leave it on for more than 2 days !!
  15. Tammie
    Sep 11, 2014
    13,484
    4,561
    1,223
    Washington
    Yes, it is Honda Spray. Get it at the Honda dealer. It works awesome. Takes burnt rubber off the fender's paint, makes rubber and plastic look amazing. Killer stuff!
    • Funny Funny x 1
what is hellcat trim
