Borla ATAK Cat back exhaust install
Discussion in 'SRT Hellcat Performance' started by im3cpo, Mar 14, 2016.
  1. im3cpo
    im3cpo Senior Hellcat Member
    Oct 25, 2015
    199
    77
    Seattle
    I picked up the Borla ATAK cat-back exhaust for my Challenger Hellcat. While I have installed a few exhausts in my day, I have never had to mess with the transfering of exhaust actuators. The instructions are extremely vague on exactly what to do: (http://www.borla.com/140646.pdf).
    I have seen the flowmaster video where they describe the level of care needed when removing and installing the actuators with their exhaust install. Has anyone installed the Borla exhaust and if so, is there any advice you can give me to put my mind at ease? Bottom line is I want to avoid a CEL......
    Any help would be appreciated.
  2. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,980
    1,422
    498
    Virginia
    I looked at the attached file. Seems pretty straight forward. Unplug and unbolt from old system and add to new system with supplied hardware. Shows that actuators go on Borla system with three clips and matching bolts per side. Might be a little lacking in positioning informaiton for actuator ams but with car cooled down, they should be back in normal postion. Bolt them on and plug them back in.
  3. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    The system looks nice
    What's the difference between the atak system and the S type system?i see borla website has 4 systems for our hellcat challenger
  4. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
    I believe its just the chambers of the mufflers used. I think everything else it the same.
  5. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
  6. TallCool1
    TallCool1 Gold Member Hellcat Car Club Nat'l Hellcat Tech Advisor HCC Charter Member
    2,439
    831
    Pacific NW
    Please shoot a couple of pics of where the actuators attach prior to mounting them, and share them. Thank you.
  7. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    Got this from there website
  8. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
    Here is the flowmaster video I referenced in my initial post where they discuss swapping the actuators:
    And here are the pics requested:
  9. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
  10. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    I found out the difference from borla
    Hi,
    One has MDS valves, while the other, has valve simulators to eliminate them.
    Best regards,
    Ernest Raft
    Borla Performance Industries
    (805)246-6031 Ext: 206
  11. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    The 140646 has valves and the 140648 does not.
    Best regards,
    Ernest Raft
  12. rwhite692
    rwhite692 Gold Member
    Jul 17, 2015
    653
    263
    Central Valley, Northern California
    Great info, thanks for sharing. Looking forward to hearing your impressions of the Borla ATAK, once you get the install done.
  13. gto19
    gto19 Silver Member
    Aug 18, 2015
    524
    156
    This was there response to why to choose either or system
    It’s for folks that want to modify the car even further. If the valves are in place, and too much boost is added, it will most likely blow the engine.
    Best regards,
    Ernest Raft
  14. gerlacher
    gerlacher Hellcat Member
    Oct 13, 2014
    94
    22
    So does the 140646 kit come with new replacement valves installed on the kit? And the kit # 140648 with the "simulators" just not designed to use them and have brackets to relocate or just move them so they are plugged in for no cel? I mean it's about 500$ difference between the two and it's just kind of vague.
  15. im3cpo
    Oct 25, 2015
    199
    77
    Seattle
    I can confirm the 140646 comes with the replacement valves installed on the pipes. I hope to have time this weekend to install the exhaust. When I ordered mine, I had no idea there were two part numbers for the same sound level (ATAK); I thought all Borla exhausts deleted the valves inside the pipe and was surprised when mine came with them.
    Hopefully this doesnt quiet the exhaust down too much. The good news is the section of the exhaust with the valves installed is easy to take on and off the car. I figure if I get it on and its too quiet, I may just take that section of the pipe off and either drill the holes in the flaps out larger, or even perhaps manually remove them entirely. It does kinda suck I paid $500 extra for something I honestly didnt want, but it is what it is... Borla really should have done a better job writing their product descriptions.....
borla atak hellcat
borla atak problems on charger hellcat
engine light came on after installing borla exhaust
hellcat borla
hellcat borla atak exhaust horsepower gain
hellcat borla atak exhaust installation cost
mds valve simulator
what p1217
