Brake fluid change or flush prior to a track day
Discussion in 'SRT Hellcat General Discussions' started by Jimbo, Jun 24, 2015.
  1. Jimbo
    Jimbo Hellcat Member
    Feb 4, 2015
    38
    20
    CT
    Hi all,
    Recently picked up my challenger hellcat and am booking a track day in sept at limerock in Connecticut. The director suggested I check brake fluid and possibly flush it prior to track day and put in better fluid if necessary. Does anyone know what dot level it comes stock with. And do you recommend flushing and upgrading the fluid prior? Any help would be great. Thanks
  2. B5 Blue
    1,745
    Dot 3 factory I'd use Dot 4 when you do
  3. Aarcuda
    Aarcuda Gold Member
    Oct 22, 2014
    1,464
    472
    258
    The Boonies
    I wouldnt flush. Its not an easy job. and half the times the abs screws everything up. but maybe its different nowadays.
  4. SRT_HC_707
    Jan 1, 2015
    4,938
    1,432
    70.196059, -148.559760
  5. Jimbo
    Feb 4, 2015
    38
    20
    CT
    Thanks for input. Track director said DOT 4 is required especially if it's a hot day
  6. B5 Blue
    1,745
    OMG you agree with me
  7. TallCool1
    2,435
    825
    Pacific NW
  8. fnkychkn
    Jan 24, 2015
    1,535
    642
    greasy cardboard box
    Although DOT4 fluid is preferred for road racing because of it's higher boiling point, one must also be aware that it is more hygroscopic than DOT3 and therefore, needs to be flushed more often.
  9. Srt8u
    Srt8u Silver Member Hellcat Supporting Vendor
    Mar 21, 2015
    724
    229
    You will want to swap out the fluid for a higher temp fluid, I have used ATE Blue, which subsequently was outlawed by the dot due to blue dye...
    Wilwood 570 or 600
    Motul 600
    Are also great choices
    The stock fluid is great for general driving but has a much lower boiling point, so on the track if you push it hard for multiple sessions you will heat it up and experience fade.
  10. TallCool1
    2,435
    825
    Pacific NW
  11. Jimbo
    Feb 4, 2015
    38
    20
    CT
    Wow lot of info here...thanks again guys...so I'm thinking maybe I'll flush and replace with the Torque prior to track day, and then after...I'll probably need new pads by then anyway, go back to the DOT 3...
    any recommendation for new pads that dont produce so much brake dust?
  12. TallCool1
    2,435
    825
    Pacific NW
    Torque is just my preference do your research to see what you decide. I've ran most (and tested a couple) in my multistrada GT (never did analysis in cars but I feel would prove same.) That bike is horrible on brake fluids because in Ducati's infinite wisdom, they placed the rear brake master cylinder too close to the catalytic converter, so the heat fluid is exposed too is very high. When I did last analysis the Torque had about 1/2 the water compared to Castrol SRF (and Castrol should be shot for what that fluid costs.)
  13. Dubs
    Dubs Rookie
    Dec 19, 2014
    15
    1
    Careful with pads that claim less dust, it usually means they are such a hard material (like ceramic) that they have less friction and have bad fade performance. Leave the ceramic for making coffee mugs.
  14. BULL
    Nov 20, 2014
    3,407
    1,127
    628
    Hey guys and gals, 'found this while I was banging around...
    It's updated and can be sorted by the various columns at the top
    BRAKE FLUID CHART
brake fluid capacity of dodge challenger hellcat
challenger hellcat brake fluid dot 3 vs dot4
challenger track day brake fluid
how much brake fluid hellcat
how much brake fluid in challenger hellcat
how to switch to srf brake fluid
srt hellcat track day
srt racing brake fluid
