Brake fluid low, M6 clutch sticking.
Discussion in 'SRT Hellcat General Discussions' started by DocOz, May 23, 2016.
  1. DocOz
    DocOz Rookie
    Mar 29, 2015
    25
    16
    I'm at 2,500 miles on my M6. Run hard 1st gear, then 2nd gear, then clutch in and shifter back to neutral until slowed down to make a turn. Try to shift into 1st and it just won't go into gear. Brake fluid level has dropped to minimum. Suspect a leak in the clutch line. Going to the dealer next week. To keep them from just replacing the whole driveline under warranty where do you think the problem is?
  2. Racist Cat
    Racist Cat Silver Member
    Jan 28, 2016
    1,382
    491
    Could be heating the clutch discs.
    Dual disc clutches have this symptom when the floater plate gets over heated.
    Your brake fluid is independent from your hydraulic clutch assembly.
  3. carcass
    carcass SRT Hellcat Supporter Gold Supporting Member
    Sep 7, 2015
    857
    260
    173
    the brake fluid I believe he is talking about is the hydraulic aspect of the clutch.
    If the clutch master cylinder any part of the line or the hydraulic release bearing is leaking then its time for a visit to the dealer,
    How did you get home? Start the car with the trans in first and the clutch in?
  4. DocOz
    DocOz Rookie
    Mar 29, 2015
    25
    16
    It's happened several times. I would release the clutch pedal push in again and could get it into gear. Filled the brake fluid back up over the weekend. Now it's back down to nearly low again in 2 days.
  5. NX91Notch
    NX91Notch Gold Member
    Jan 8, 2015
    497
    249
    Seminole, FL
    Incorrect.
    While yes you are correct that technically the clutch master cylinder is independent of the brake master cylinder....the clutch master cylinder DOES get it's fluid from the brake reservoir.
    The brake and clutch system share the same fluid.
    So if brake reservoir is low it could cause issues with the clutch. And/or if the clutch system has a leak it could be the reason why the reservoir is low.
  6. Toolman_42
    Toolman_42 Gold Member
    Jan 26, 2015
    2,462
    750
    Virginia
    Sounds like hydralic clutch is leaking...
    Time for a immediate trip to the dealership. Hope the clutch plates are not contaminated with fluid.
  7. Racist Cat
    Jan 28, 2016
    1,382
    491
    This sounds extremely foolish from a legal/lawsuit perspective.
    Guess I jumped the gun with an assumption from experience with other vehicles.
  8. fnkychkn
    Jan 24, 2015
    1,450
    558
    423
    plastic take-out container
    The reservoir is designed so that the clutch will run dry before the fluid level gets low enough to affect braking performance.
  9. MABBRYFL30
    Top Poster Of Month
    Feb 10, 2016
    5,272
    2,201
    568
    Fc. Based on that if the fluid is hot, this condition could get worse?
  10. Racist Cat
    Jan 28, 2016
    1,382
    491
    Hot fluid expands?
  11. 007
    007 Gold Member
    Oct 24, 2015
    299
    283
    513
    I experienced this with my cat.... there is an in line valve in the line going from the master cylinder to the slave cylinder, about 3 in. Long.. it has 2 horseshoe clamps that hold the valve onto the line.. my horseshoe clamps were weak, and was letting the valve push apart some , when I pushed the clutch in it poured.. this part doesn't have a part number, you have to buy the entire line all the way to the master cylinder.. and yes they are on back order from almost every dealer.
    The part is up under the cowl, behind the master cylinder... .. your problem sounds ,just like the one I had.
clutch stuck on hellcat
new hellcat wont go into fisrt gear
