Brakes and rotor
Discussion in 'General Automotive Discussion' started by Lilla, Mar 29, 2015.
  1. Lilla
    Lilla Silver Member Hellcat Car Club HCC Charter Member
    Mar 11, 2015
    136
    178
    Florida
    Good day,
    I just changed the Beast's oil at 1K miles. While at the dealer I thought I should try and buy new brake pads as I am hell (LOL) on brakes of all types. While there they stated it would be an approximate $1700 job. The SRT tech stated that they can not machine the rotor and when I replace my pads they replace the rotor. Seriously????? Has anyone else heard that? I serious replace brakes on all my other cars about every 2 years...I am hell on brakes for some reason! :)
  2. DGatzby
    Jan 16, 2015
    3,729
    1,994
    748
    Twin Cities, MN
    I am going to have my dealer drop in some nice looking Porterfield pads that a good friend recommended this week. I have 1000 miles also. Can't really say I have used that pedal much, I say they will work. May not still use the brakes, I just like the right pedal anyway. Makes too much dust when you use that left pedal, screw it!
    Really, they were that anal at your dealer? Those rotors of mine look the same as the day I picked it up a couple of weeks ago.
  3. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,674
    552
    423
    Chattanooga, Tennessee
    There is someone here who has already changed their pads to low dust pads. Search brake pads. I don't know why you would change rotors unless they were well worn or damaged in some way.
  4. CDNHellcat
    CDNHellcat Silver Member Hellcat Supporting Vendor
    Nov 23, 2014
    508
    229
    Vancouver BC
    I use these pads on all my vehicles, very low dust and works great
    Wagner ThermoQuiet® is the “One Piece Brake Pad” that provides quieter braking and superior stopping performance in any driving condition. Exclusive Integrally Molded Sound Insulator (IMI) dissipates heat and vibration for quieter braking. Proprietary friction formulations provide superior stopping performance and less dust.
    Wagner ThermoQuiet delivers Brakes Without Compromise:
    • Quieter Performance
    • Superior Stopping Power
    • Less Dust and Longer Pad Life
    Comprehensive coverage for foreign and domestic vehicle applications.
    Part number for Hellcat front QC1149
  5. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,461
    768
    I seriously doubt you could burn through the brembos in 1,000 miles. They work so well at stopping the beast, I'm at 6,500 and there is still a ton of meat on them. Unless you ride them 100% of the time and I'm sure you don't. I believe the dealers when they say 1700. All pads plus rotors probably run around 1K. I Haven't actually checked, but other forum members have and the parts prices are here somewhere. 700 for labor sounds about right. If your mechanically inclined, you could probably save a bunch doing it yourself. As far as if the rotors can be turned, not sure, and would have to see their condition when the time comes. I would probably just replace them, that would be my preference.
  6. Profezzor X
    Profezzor X Silver Member
    Feb 21, 2015
    512
    96
    Los Angeles
    I too remember someone here changing out their brake pads in less than a couple of hundred miles on their Hellcat... Thing is, I can't remember if they said those pads were carbon or not.
  7. CDNHellcat
    Nov 23, 2014
    508
    229
    Vancouver BC
    You can re-machine any rotor as long as you don't machine it below minimum thickness as stamped on the rotor. The down side of this is that the rotor is thinner and more prone to warping.
    For the limited cost saving I don't machine rotors unless they have minimum wear. I would suggest using a micrometer and seeing where they are at before wasting time machining them
  8. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,518
    1,435
    818
    Endless Mtns of Pa
    summit racing has hi performance carbon fiber ceramic pads set of four delivered for under $100
  9. ChallengerDad
    ChallengerDad SRT Hellcat Moderator Staff Member Gold Supporting Member
    Oct 5, 2014
    1,533
    674
    563
    Bethlehem, New York
    A good friend of mine is the SRT Tech at a local dealership. He changed out the Brembo brake system on his IE 392 with the Hellcat system. As I recall, he said the HC Brembo system was VERY pricey. The rotors are two-piece and were very different from what we're all used to seeing on our MOPARs. I wish I had more details, but I know he paid a LOT for the system.
    If you're "hell on brakes", my first guess is you're "riding them". Keep that left foot completely off of the brake pedal when you're driving. The heat from constant scrubbing will not only wear your pads down quickly, but also warp your rotors, causing a vibration issue - in addition to premature wear. These things should last a long time under normal use.
  10. DrBuick
    DrBuick Gold Member
    Oct 11, 2014
    2,408
    1,383
    768
    Slinger Wisconsin
    I changed my pads right from the get go. Low dust power stop pads. Factory pads in a box.
  11. 700plus
    700plus Hellcat Member
    Dec 3, 2014
    89
    27
    18
    Houston
    Do you have a part Number?
  12. FreightTrain
    Sep 13, 2014
    3,518
    1,435
    818
    Endless Mtns of Pa
  13. fnkychkn
    fnkychkn Thread Killer Gold Supporting Member
    Jan 24, 2015
    1,700
    771
    633
    greasy cardboard box
    If your tech can't resurface them, it's most likely he doesn't have the proper equipment.
    resurfacing is only required when surface scoring is evident or runout or thickness variation are out of spec.
  14. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,461
    768
  15. baabootoo
    baabootoo Hellcat Member
    Sep 19, 2014
    68
    15
    Ceramic, Ceramic, Ceramic...............
challenger hellcat brake upgrade
hellcat brake pads
hellcat brake rotor
hellcat brakes
hellcat brembo brake rotors
hellcat rotor size
hellcat rotors
porterfield hellcat brakes
