Burned Rotors
Discussion in 'SRT Hellcat General Discussions' started by digdug33071, Nov 21, 2015.
  1. digdug33071
    digdug33071 SRT Hellcat Supporter Gold Supporting Member
    Dec 19, 2014
    271
    102
    Just got the Challenger Hellcat back from the shop at Arrigo Dodge. 10,000 miles and had burned rotors - replaced all 4 - fortunately under warranty. Anyone else had the issue?
  2. Fast cat
    Sep 23, 2014
    2,255
    713
    498
    Indiana
    No. Burned rotors ? Please explain.
  3. digdug33071
    Dec 19, 2014
    271
    102
    Fast Cat -
    Apparently the rotors got so hot it changed the very molecular structure of the metal. They get brittle and can warp and according to the tech (all he works on are Vipers, Hellcats and SRT's) it impacts brake performance and safety. Nice sound on the 1/2 mile run :)
  4. Catless
    Catless Silver Member
    Feb 2, 2015
    966
    195
    Parkersburg, WV
    Well as long as it was free.
  5. digdug33071
    Dec 19, 2014
    271
    102
    Indeed. Initially they wanted and this is just parts, mind you - $2,300 for the fronts and $900 for the back - I called SRT and got them to warranty them.
  6. FireLane
    Jul 23, 2015
    388
    108
    Palm Beach County, FL
    Are you using Arrigo on Okeechobee? What is the name of your service writer and Tech that you're using? Right now I'm using Napleton Dodge on Northlake and I'm using Johnny who is their Viper tech. How do you like them so far?
  7. Obiefox
    Obiefox Silver Member
    Aug 22, 2015
    378
    97
    Cincinnati
    By 1/2 mile run I assume you were tracking the car at an event and overheated the brakes. IF thats true, I don't think Dodge owed you another set. Rotors are a wear item. You are fortunate to have them warranted.
    $2300 for the fronts and $900 for the rears is ridiculous when it appears you can buy an entire set of factory rotors here for under $1500.
    Hellcat OEM Front & Rear Brake Rotor Package (Set of 4)
  8. Bane
    Bane Silver Member
    Sep 19, 2014
    277
    69
    Maryland
    He was talking about the 1/2 mile run in the video in the post above his.
  9. digdug33071
    Dec 19, 2014
    271
    102
    Arrigo Sawgrass - New York Mike is the guy's name. He seemed very thorough and knowledgeable- plus kept it inside for me. Works on a lot of vipers too.
  10. digdug33071
    Dec 19, 2014
    271
    102
    The 12,000 mile warranty doesn't specify easy miles only :) I might have been to the track a time or two and that's what the car was designed for - tech said it's a race car with license plates - but I was referring to the 1/2 mile video. And I did some research - Speedlogix has a set of 4 replacement rotors for $1,500.
  11. Garfield
    Garfield Hellcat Member
    Nov 1, 2015
    18
    I think someone was speaking out of knowLedge.. Wo researching the exact alloy mix of the rotors I can't give the exact temp to change the molecular density of the steal but I can tell you it's stupid high like melting point temps.. (Think using a torch to bend a piece of metal hot kind of hot as that is exactly what happens that allows for the metal to bend) Your fluid would boil 100's of degrees sooner first as well as the ruining the composition of the pads themselves.. It seems more likely if the rotors were not warped (which they would have to be in order to achieve enough heat) that what happened was just build up on the rotors from the pads and the proper procedure is to replace the pads as they are trashed at this point and just use sand paper to rough up the rotors so the new pads can be properly seated to the rotor.. And a fluid change of course.
    Edit.. If it's not too bad.. You can many times use sand paper on both the pad and rotors and just change the fluid.. Think slotted and drilled rotors.. They are that way for heat and cooling to a point.. But it's actually mostly to allow the break dust to exit so this doesn't happen.. This is why when you have slotted or drilled rotors you end up cleaning your whells of break dust every time you drive ;)
  12. digdug33071
    Dec 19, 2014
    271
    102
    Mia culpa. I was facetious with the molecular structure bit but did heat up the rotors running 150-30 mph on a recurrent basis at the track. I believe you can machine rotors once or twice but why compromise?
  13. Obiefox
    Aug 22, 2015
    378
    97
    Cincinnati
    Umm.....There is a lot going on here. Spelling aside, this is bad information.
    Kevin
  14. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    1,984
    473
    403
    Westchester
    There was a price issue on the brake pads originally, the brake pads are now literally like 25% of the original cost. The quote for replacing the pads/rotors had to be based off old pricing
  15. hellbound
    hellbound BANNED
    Oct 31, 2015
    480
    72
    Columbus ohio
    OMFG....
