BWoody CAI
Discussion in 'SRT Hellcat Performance' started by B5 Blue, Jul 24, 2015.
  1. B5 Blue
    1,745
    I tested mine tonight with my son. I didn't tell him what I thought I let him tell me. Both of us agree that off idle and part throttle have more response. IAT readings compared to stock run 6 degrees cooler BUT I didn't test that at WOT I switched to boost. I won't be able to give a track difference as my DR's came today as well and I want traction. I'm impressed with my BWoody intake plus it's a lot cheaper than the competition on here and glad I got it.
    B5
    • Winner Winner x 2
    • Useful Useful x 2
  2. yurdaddy
    yurdaddy Silver Member
    Mar 5, 2015
    323
    99
    178
    Motor City
    Can we see some pics please.
  3. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    That's great..... what about the seat of your pants DYNO
  4. hellcat1
    Sep 27, 2014
    10,672
    2,030
    SOunds like there is going to be a brand new afe intake going up for sale soon....
  5. B5 Blue
    1,745
    Tomorrow
  6. B5 Blue
    1,745
    I like it
  7. Driver72
    Driver72 Gold Member
    Mar 10, 2015
    1,209
    276
    I may get both this and the AFE to compare, return the one that's not as good.
    However, the BWoody is $389, plus $40 for dry charger. So thats $439
    That's only $6 less than the AFE's group buy and you get less materials than the AFE gives, so really the BWoody is more for less.
    But which will perform better is the question.
  8. KLR CAT
    KLR CAT Active Hellcat Member
    Apr 9, 2015
    42
    28
    Just fyi 5" intake piping needs tuning since maf frequency will no longer match calibration for airflow through the change in diameter. You may possibly be rather lean since you are moving more air then the ecu is expecting. Get some wide band info, not just but dyno.
  9. B5 Blue
    1,745
    Yes bit I think afe will retain heat more but you're plan is solid
  10. B5 Blue
    1,745
    Testing WOT shows air/fuel 11.3 so wouldn't that disprove lean?
  11. KLR CAT
    Apr 9, 2015
    42
    28
    Based on what the afr on the srt gauges? That may or may not be correct. If the pid reporting is truly just from O2 sensor scaled for voltage then maybe. If they are using maf frequency for air mass look up in any way could be off. Bottom line the amount of air the motor thinks it's getting is off now, so what it's commanding for afr and what's actually getting fueled is off. That is what tuning is actually all about, having actual and commanded afr match. May not be dangerous at 11.3 but doesn't mean its right.
  12. B5 Blue
    1,745
    Yes the afr in srt gauges and I don't know where it calculates this figure. On my Camaro I backprobed the front O2's and read voltage but haven't looked at this on the HC yet, too much fun driving it. OE box is going back in for testing against BWoody at dragstrip and I'll look at A/F ratio again.
  13. Driver72
    Mar 10, 2015
    1,209
    276
    So KLR CAT, are you saying it may be dangerous to run the BWoody intake as it may be pumping in more air than what the MAF is aware of and therefore running the engine lean?
    That clearly wouldn't be great, has BWoody not tested this on their Beta car??
  14. mike@bwp
    mike@bwp Gold Member Hellcat Supporting Vendor
    Jul 20, 2015
    492
    302
    513
    Abingdon, Md
    The Hitachi MAF sensor in the hellcat has not changed the vehicle still reads the volume and temperature of the incoming air changing that would require a re tune, the computer has several fuel and timing maps that adjust just for this as well as different altitudes temp variations and denser / thinner are around the world. The intake only gives the supercharger a larger supply of air and makes it more readily available making the engine work less, thus creating more power not a lean situation as the vehicles PCM fuel and timing tables would prevent that with an intake.
    • Useful Useful x 2
  15. mike@bwp
    Jul 20, 2015
    492
    302
    513
    Abingdon, Md
    It was tested on their BETA car, AFDR is read through the o2's and a lean spike was never recorded, the PCM fuel and timing tables prevent that from happening with simple bolt ons.
    • Useful Useful x 3
Similar Threads
  1. goingsolo2
    256
    25,760
Loading...
bwoody cai
hellcat cai
