BWoody Charger Hellcat shorter rear sway bar links For drag radials
Discussion in 'BWoody Performance' started by mike@bwp, Jul 29, 2015.
  1. mike@bwp
    mike@bwp Gold Member Hellcat Supporting Vendor
    Jul 20, 2015
    511
    315
    513
    Abingdon, Md
    [​IMG]
    Found here on our website:
    BWoody Performance
    BWoody Performance Challenger / Charger Shorter Rear sway bar links for 17" & 18" Drag radials
    A shorter design from our standard sway bar link upgrade for those of you just wanting a shorter sway bar link to make room for 17 & 18 inch drag radials, these allow the rear sway bar to drop out of the way enough to put those smaller wheels on so you can get more sidewall for better traction.
    The Factory swaybar links are a weak 1/4 inch in diameter the BWoody links are a whopping 7/8 in diameter in the front and 1/2" in the rear and custom energy suspension bushings we used to improve handling even more. Our sway bar links are nearly tripple the the size of the oem links!! The weakest link of the Hellcats suspension is the sway bar links due to the lack of diameter and lack of strength, significant improvments in handling were felt on the test vehicle. Adding these to your vehicle will make your srt-8 handle like it should!!
    The only color available for the rear shorter links is wrinkle black
    • Like Like x 3
  2. hellcat562
    hellcat562 Silver Member
    Jun 4, 2015
    441
    155
    So it can also work with our size 20 OEM rims and improve in handling?
  3. mike@bwp
    Jul 20, 2015
    511
    315
    513
    Abingdon, Md
    We would suggest our OEM length sway bar links if you do not plan on running 17" DR's for better handling.
2015 charger stock sway bar size forum
2015 charger sway bar charger forum
bwoody sway bar links
charger hellcat 17 inch drag radials
dodge hellcat shoeter swaybar end links
hellcat shorter end links
ram shorter rear sway bar links
srt challenger rear sway size
