BWoody Check Valve
Discussion in 'BWoody Performance' started by rayzazoo, Feb 27, 2016.
  1. rayzazoo
    Nov 8, 2014
    3,622
    1,374
    818
  2. Rick@Metco
    Rick@Metco Gold Member Hellcat Supporting Vendor
    Sep 7, 2014
    325
    173
    Tallcool1
  3. TrackDay
    TrackDay Gold Member
    Mar 28, 2015
    1,193
    350
    I don't understand the physics in how this can result in a 2 psi boost gain.
  4. YLWJKT
    YLWJKT Silver Member
    Oct 12, 2015
    411
    Furthermore, if that's true, wouldn't it require tuning to offset the increased boost?
  5. Lord Hellcat
    Jan 6, 2015
    1,606
    723
    UK
    I think it has more to do with preventing boost lost rather than any gain over the stock 11psi
  6. TrackDay
    Mar 28, 2015
    1,193
    350
    My question is how does it prevent boost loss when the PCV is in the supercharger inlet. No boost there.
  7. hellzya
    hellzya Silver Member
    Feb 27, 2015
    599
    109
    OK I admit im lost. What is this exactly and how does it serve as a performance enhancer?
  8. mike@bwp
    mike@bwp Gold Member Hellcat Supporting Vendor
    Jul 20, 2015
    502
    310
    513
    Abingdon, Md
    Sorry guys new website launched feb 1st and some items do not have the correct verbage, it was corrected it should say:
    "Stop the boost leak through your pcv system now! Customers have reported up to a 2psi gain once the check valve was installed on their Aftermarket F/I HEMI. On the Hellcat the check valve does not increase the boost level it just prevents any boost bleed off from the bypass valve from entering the PCV system thus preventing crank case pressurizing. The BWoody check valve is the most affordable checkvalve on the market!!"
  9. Top Cat
    Nov 26, 2014
    1,925
    1,082
    768
    Doylestown,Pa
    I'm a little confused on the new verb age Mike, still have no clue how someone could gain boost?
    TC
  10. Paladin06
    Sep 3, 2014
    4,770
    1,931
    818
    San Tan Valley, AZ
    Stock is 13.
  11. Paladin06
    Sep 3, 2014
    4,770
    1,931
    818
    San Tan Valley, AZ
    Oh boy. Snake oil.
  12. Top Cat
    Nov 26, 2014
    1,925
    1,082
    768
    Doylestown,Pa
    Wish mine was 13 stock,LOL if a product works I'd like to find out more about it and use it.
    TC
  13. TrackDay
    Mar 28, 2015
    1,193
    350
    Absolutely, I just don't understand the claim.
  14. mike@bwp
    Jul 20, 2015
    502
    310
    513
    Abingdon, Md
    We sold this same check valve for customers who add superchargers to the 6.1 - 6.4 based Hemi's, when they installed an aftermarket supercharger they would get boost bleed from the intake manifold into the crankcase VIA the PCV system, on the 6.1l and 6.4l Hemi the intake charge is pressurized before the throttle body and before the PCV system. By no means are we advertising that the Hellcat will gain any boost because it absolutely will not! The check valve for the hellcat is offered as a backup so as when the bypass valve opens up (which is right by the PCV line ) there is no chance of any boost bleed into the crank case. AGIAN this will not increase your boost on the HELLCAT no way.....No how!!!
  15. im3cpo
    im3cpo Senior Hellcat Member
    Oct 25, 2015
    199
    76
    Seattle
    Is there any way you could post pictures as to how the check valves should be installed? Also- I assume this can be done on both passenger and drivers side.. Is that the case?
hellcat bwoody check valve good or bad
