can I pin the crank
Discussion in 'SRT Hellcat Performance' started by Ray Hunsaker, Sep 26, 2015.
  1. Ray Hunsaker
    Jan 26, 2015
    605
    198
    can any body (that knows) help me find out that if I have my crank pulley pinned will that affect any warranty at all. I would do it for preventative for not spinning crank dampened pulley. I can't think it should.
  2. SRT_HC_707
    Jan 1, 2015
    4,949
    1,439
    70.196059, -148.559760
    Just my .02. Don't touch it with a 10 foot pole. There is probably less than 1% motor failures. If it did fail you have a warranty to protect you.
    Having your crank pinned would only be a warranty issue if something failed that was related to that. The issue is that if the manufacture points to you and denies warranty it's YOUR headache to take legal action etc. to get to resolution. Probably safe to say that FCA has more cash than you do (I don't mean that as an insult).
    Leave it be... If you were to have an issue let FCA correct it.
    • Agree Agree x 5
    • Winner Winner x 2
  3. StellasHC
    StellasHC Platinum Member
    Nov 18, 2014
    1,832
    1,323
    933
    Kenosha, Wisconsin
    I'm going to say that if you drill into the factory crank, they will void your warranty. Wrong as that might be. I've seen a few dampers that have spun on the crank. Once it does that engine is junk.
    I'll be pinning mine this winter.
    • Winner Winner x 2
  4. Gixer Jay
    Gixer Jay Silver Member
    Aug 13, 2015
    354
    143
    Raleigh, North Carolina
    With all that said I would not pin it either with a factory warranty. However, I would be carrying my torque wrench in the car and checking the crank pulley bolt torque regularly. Its torqued to like 235 ft lbs. Just checking the torque would not void the warranty
  5. SRT_HC_707
    Jan 1, 2015
    4,949
    1,439
    I'm just speculating but I'd bet that if yours is torqued properly from the factory using the appropriate threadl ocker or whatever they use it will never be an issue. That's a lot of torque. You will need something to keep hold the crank from spinning while torquing. That's a butt load of torque!
    There has to be either an assembly or part defect causing the problem.
  6. cole3986
    cole3986 Gold Member
    Apr 25, 2015
    1,827
    949
    563
    Lawrenceville, NJ
    That's crazy talk, check the crank pulley torque setting? How are you going to to that, with all the stuff in the way? and I hope you torque wrench goes that high not to mention the engine will turn before you hit that rating (if A8).
  7. Gixer Jay
    Aug 13, 2015
    354
    143
    Get to it from the bottom side of the engine and use a Flywheel Lock. There are plenty of torque wrenchs out there that go that high. Snap-On, Mac, heck you can probably find one at Harbor Frieght although I'd be questionable about the accuracy and calibration
    Not crazy, but not for the average Joe technician either
    That's what I was thinking too. Maybe a few drops of red or blue loc-tight was left off in Mexico
  8. StellasHC
    Nov 18, 2014
    1,832
    1,323
    933
    Kenosha, Wisconsin
    Crank pulley bolt has a "diamond encrusted" washer to hold it tight/torqued....lol... Not lying.
    Ill pin mine... Not he first crank I ve pinned. 5 minute procedure.
  9. bolivarshagnasty
    bolivarshagnasty Gold Member
    Oct 24, 2014
    1,650
    538
    423
    Chattanooga, Tennessee
    Do you use a roll pin or a solid tapered pin?
  10. Ray Hunsaker
    Jan 26, 2015
    605
    198
    I'm sure the pinning won't be a big deal. but getting to it IS a big deal.
  11. StellasHC
    Nov 18, 2014
    1,832
    1,323
    933
    Kenosha, Wisconsin
    • Like Like x 3
  12. Ray Hunsaker
    Jan 26, 2015
    605
    198
    I really think that downshifting with the a8 trans these things hit hard so Im thinking that might have somthing to do with it.
  13. FreightTrain
    FreightTrain Comfortably Numb
    Sep 13, 2014
    3,514
    1,430
    818
    Endless Mtns of Pa
    i was thinking same... is it happening to both A8s n M6s?
  14. TallCool1
    2,439
    829
    Pacific NW
    the snout pulley clutch and boost bypass valve (should) handle that.
  15. cole3986
    Apr 25, 2015
    1,827
    949
    563
    Lawrenceville, NJ
    Hm.. I have a 3/8 and 1/2 torque wrenches, I know the 3/8 does go that high, maybe the 1/2" does. Do not have a flywheel lock, have to check to see if the there is a access plate like on the 727 to get at the flywheel/ring gear on the A8. Ok, half crazy talk ;););)
challanger hellcat crank pin
does pinning a crank void the warrantee
hellcat crank pinning
labor to pin the crank hellcat
pin the crank pulley
pinning crank pulley on hellcat
show actual image of ati hellcat crank damper pin kit
