Can't pair my phone. Little things are so frustrating.
Discussion in 'Dodge Challenger SRT Hellcat' started by Hubbs, Jul 13, 2015.
  1. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    I've got an Samsung Note 3 and it won't talk to my HC. It worked fine in my 2013 SRT8 and works fine in my 2013 Ram. I recently had to exchange my phone under warranty and got a replacement, but it's no different.
    SRT says it's listed as a phone that should work, but they can't figure out what's wrong. Any ideas?
  2. B5 Blue
    1,746
    So you have phone seeking Bluetooth devices and nothing while the car is searching?
  3. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Nothing. The last Note 3 I had would see the Uconnect, but I would get an error "cannot communicate with Uconnect".
    This new Note 3 doesn't see it at all. The response is "no bluetooth devices found".
    I've tried making the phone "visible" to other devices (not required for pairing, but worth a try). No help.
    I've rebooted everything and tried every which way I can think of over the last few months. No luck.
  4. MaxxMuscle
    MaxxMuscle Gold Member Hellcat Car Club HCC Charter Member
    Feb 10, 2015
    728
    297
    Lafayette La.
    I have a Note 3 and mine works fine.Wish I would have watched how my salesman connected before leaving with my car .:(
  5. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    Go into the phone settings and Make it visible to all, start pairing on UConnect, make sure the phone can see the Uconnect (it may show up as headset first), pick that from the phone, should work fine, I have had to change the Bluetooth connection method on advanced settings sometimes though.
    Does your phone see and pair with other Bluetooth devices okay?
  6. B5 Blue
    1,746
    So you disconnected hot all the time (30 circuit) at or to the radio so it went dead? Can someone else bond their phone to the HC?
  7. 70Cuda
    70Cuda Yep, its got a HEMI
    Oct 19, 2014
    4,771
    1,771
    Wisconsin, USA
    Was even better on the 15 than my 12, should work really easy.
    there has to be a setting on your phone turned off.
  8. CubeMan
    CubeMan Tri-State Overlord
    Dec 31, 2014
    2,015
    489
    403
    Westchester
    can you bluetooth your phone to anything else (In-house stereo or etc?). You can go to your dealership and they will help you also.
    Make sure bluetooth is enabled on your phone
    Go to phone on your car and it'll ask if you want to pair a phone, hit yes then it'll tell you to look for Uconnect on your phone's bluetooth menu/list. Tap that and it'll ask you if the numbers match whats on your Radio/NAV screen, hit yes. You are pair'd now
  9. 7777.775
    7777.775 Guest
    Nov 25, 2014
    3,170
    1,460
    768
    Do you have the latest version of U Connect installed? Not that it should matter, but you never know. Also, if you haven't already, make sure there are no other devices previously paired. I think there is a list and you can delete all previous BT devices.
  10. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Done that several times. It won't even see Uconnect. It says "no bluetooth devices detected".
    The phone works just fine with my 2013 Ram.
  11. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    No, I pulled the battery for 2 minutes, then reconnected.
  12. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    The bottom line is, I know how to pair the phone and it works really easily in my Ram. Obviously it's not a problem with the phone.
    I may go by the dealer with it. I called Uconnect and they couldn't figure it out though.
  13. B5 Blue
    1,746
    Try Disconnect battery cables at battery turn headlight switch on then hold the cables together 60 seconds then reconnect
  14. purnrg
    purnrg BANNED
    Apr 12, 2015
    2,619
    1,154
    588
    Try pairing a different phone, maybe the BT in the car isnot active or bad?
  15. Hubbs
    Hubbs Silver Member
    Nov 17, 2014
    703
    154
    McKinney, TX
    Thanks guys. I think I'll try the hard reset of the car one more time just to rule it out plus I'll make sure the wife's phone pairs ok. If her's doesn't either I think I'll know for sure the bluetoof is bad.
cant pair 2014 challenger
make uconnect visible to phone
