Carbon Fiber or Aluminum Driveshaft
Discussion in 'SRT Hellcat General Discussions' started by civ101, Sep 30, 2015.
  1. civ101
    civ101 Hellcat Member
    Oct 3, 2014
    53
    7
    Willard, UT
    I know this has been played out multiple times, but I have not really seen enough information to pursuade someone either way. I have to switch out my clutch and I figured while it is torn apart I might as well take care of another known weak link. One concern is if I swap out the driveshaft what will be the next thing to fail, due to a stronger driveshaft? Is the risk of a carbon fiber shaft worth the weight loss compared to the aluminum shaft?
  2. usmc341
    usmc341 Gold Member
    May 27, 2015
    1,715
    497
    368
    Henderson, NV
    I would go with aluminum. CF is stronger when installed but they are fragile. For example, if the CF driveshaft on the Shelby is dropped prior to install, they have to throw it away. Can't go wrong with aluminum and they are less expensive.
  3. Aaron Vogel
    Aaron Vogel Gold Member
    Jan 23, 2015
    1,760
    318
    Everywhere
    The weight reduction across any of them, stock, AL, CF is pretty pointless in terms of benefits. Not going to see anything there. They say the CF is better to reduce NVH and it will be a little more forgiving, as it will twist and absorb a little bit. Like mentioned above, the CF is more fragile in terms on if you drop it, something hits it etc, it gets delamed its going to fail. I liked the CF on my last car, but living in the crappy part of CA I may get the AL just so I don't have to worry about anything hitting it
    • Funny Funny x 1
  4. FA5T CAT
    FA5T CAT Silver Member
    Feb 16, 2015
    464
    180
    Santa Clarita, California
    I have a brand new in box carbon fiber driveshaft for M6 from the driveshaft shop
aluminum vs carbon fiber hellcat
dodge hellcat stock driveshaft weight best one
hellcat carbon fiber driveshaft
