Challenger Hellcat Air Cleaners/Oil Filters Part #'s
Discussion in 'SRT Hellcat Maintenance' started by MOPAR4LIFE, Mar 8, 2015.
  1. MOPAR4LIFE
    MOPAR4LIFE Rookie
    Mar 5, 2015
    4
    Thought this might be helpful for any one that wants to change the paper factory air cleaner and change your own oil....Here are the manufacturers and part numbers for the 6.2 litre SC engine:
    Air Filters:
    AFE Pro Dry S Filter # 31-10220
    AEM Dry Flow # 28-20460
    These are recommended because they don't require oiling.
    Oil Filters:
    SRT # 5038041AA
    Mobil 1 # M1-210
    Mopar # 04884899AB
    Royal Purple # 20-820 *FI
    K&N # HP-2010 & PS-2010
    Purolator # PL-12222 & L-12222
    Pennzoil # HPZ-173 & PZ-173 & PZ-42
    Hope this is helpful...............
  2. rayzazoo
    Nov 8, 2014
    3,470
    1,283
    668
    Please add the SRT oil filter to the top of your list :)
    5038041AA
    [​IMG]
  3. Carnage
    Sep 21, 2014
    12,107
    3,273
    823
    Houston, TX
  4. TallCool1
    2,433
    817
    Pacific NW
    Add this to filter (ra hi power series difficult but not impossible to find having been discontinued...) Open Neo. Magnets easy to source if you do get correct spec for heat range. Also replacing oil drain and oil cooler drain bolts with same that contain magnets. All helps filtration efficiency.
  5. Speedman
    Speedman Silver Member Hellcat Car Club Gold Supporting Member
    Feb 18, 2015
    392
    173
    Maple Grove MN.
    I personally use System One filters in all my cars & trucks. Yes you pay a little bit more but it beats cutting your old school paper filter open and making a mess Oil filter.jpg
  6. CDNHellcat
    CDNHellcat Silver Member Hellcat Supporting Vendor
    Nov 23, 2014
    499
    223
    Vancouver BC
    Thanks always Helpful
  7. scoutermike
    scoutermike Silver Member
    Dec 4, 2014
    471
    177
    Tecumseh, Ontario
    So what is the difference btw. the standard Mopar filter and the SRT filter?
  8. HellcatKid
    HellcatKid Silver Member
    Dec 21, 2014
    116
    CANADA
    The filter media in the V-10 SRT filters is a higher grade it captures finer particles so the micron rating is lower it also has the ability to "hold" more particles than the standard filter.
    The relief valve is higher pressure setting, so when the normal filter would go to "bypass", and no filtration is happening, the SRT one is still filtering without any flow reduction. Better filter altogether not sure why they wouldn't have used this one from factory ;)
    Also its made by Wix for Dodge they make damn good filters :)
  9. scoutermike
    Dec 4, 2014
    471
    177
    Tecumseh, Ontario
    Thanks Clint
  10. MVT
    MVT Silver Member
    Jan 11, 2015
    1,079
    307
    Thanks for the great info, I ordered 2 of them a couple weeks ago and 3, 6 packs of the Pennzoil ultra platinum so I will just bring the stuff to my SRT tech.
  11. Speedman
    Feb 18, 2015
    392
    173
    Maple Grove MN.
    There is a $5.00 coupon from Pennzoil at Pennzoil.com that you can use on Amazon. I bought three 6 packs of the 0-40 and bought them separately and got $5.00 off each order
    Also Napa Carries the same oil Filter as the SRT oil filter 5038041AA this filter is made by Wix for Mopar / Wix makes most of Napa's Filter
    Napa Part Number 7063 Gold
    Napa
    Part Number: FIL 7063
    Product Line: NAPA Gold Filters
    Attributes:
    Filter O.D. (Inches) : 3.681"
    Flow Rate : 7 - 9 gpm
    Gasket I.D. (Inches) : 2.471"
    Gasket O.D. (Inches) : 2.844"
    Gasket Thickness (Inches) : .195"
    Height (Inches) : 3.831"
    Media Type : Glass Enhanced Cellulose
    Style : Spin-On Lube Filter
    Filter O.D. (mm) : 93 mm
    Gasket I.D. (mm) : 63 mm
    Gasket O.D. (mm) : 72 mm
    Gasket Thickness (mm) : 5 mm
    Height (mm) : 97 mm
    Thread Size (mm) : 22 x 1.5 mm
    Brand:
    MOPAR
    Part Number: 5038041AA
    Item Condition: New
    Item Description: Engine Oil Filter
    Manufacturer Brand Description: Engine Oil Filter
    Fitment Notes: VIN- Z;; Qty needed per vehicle- 1 ;
    See Item Specifics section for additional specifications about this part.
    [​IMG]
    Vehicle Fitment Summary
    To confirm that this part fits your vehicle, enter your vehicle's Year, Make, Model, Trim and Engine in the Compatibility Table. Also review the notes section in the compatibility chart for additional specifications about this part.
    This part generally fits Dodge vehicles and includes models such as Viper with the trims of SRT-10 ACR Coupe 2-Door, SRT-10 Convertible 2-Door, SRT-10 Coupe 2-Door . The engine types may include 8.4L 8448CC 515Cu. In. V10 GAS OHV Naturally Aspirated. This part fits vehicles made in the following years 2008, 2009, 2010.
    [​IMG]
    Interchange Part Numbers
    This item may interchange to the following part numbers from other brands. This is provided for reference only and does not guarantee that the part your are buying is identical to the part numbers from the brands listed below. To confirm that this part fits your vehicle, enter your vehicle's Year, Make, Model, Trim and Engine in the Compatibility Table.
    Brands: WIX, WIX CANADA
    Part Numbers: 57063
      File size:
      109.8 KB
      File size:
      75.1 KB
      139
      File size:
      67.8 KB
      142
  12. devildoghellcat
    devildoghellcat VIP Hellcat Member
    Dec 16, 2014
    111
    43
    98
    in
    Thanx for the info
air filters for dodge hellcat
best oil filter for a 2015 dodge hellcat
dodge hellcat air filter
hellcat air filter
mopar oil filter 5038041aa
mopar performance filter can i use on my hellcat challenger oem
royal purple oil filter for a 2015 challenger shaker
what oil filter is needed for challanger hellcat srt
