Challenger Hellcat Rough Start (after fuel rail recall performed.)
Discussion in 'SRT Hellcat Maintenance' started by TallCool1, May 6, 2015.
  1. TallCool1
    2,432
    814
    Pacific NW
    Bummed :( Hellcat is sick after fuel rail replaced per recall.
    Symptom: Engine cold. Start car. Fires up for 1 second, immediately sputters, almost dies; that lasts 2...3 seconds then it recovers, warms up and runs normal. (Doesn't do this after car's been on for a few minutes even from a cold start. No misses detected after this happens. No DTCs set (none found on my machine or Witech at dealer. Weird.
    All injector and sensor connections checked and re-checked. Listened to injectors using stethoscope, all sound normal.
    Fnkychkn suggested try to pressurize fuel system prior to start; that is next test. From there back to dealer. Unfortunately my original rail assy. with injectors already returned to FCA. So next steps after seeing if pressurizing fuel system for a few seconds to see what that shows will be to return to dealer, remove fuel rail assy, clean, inspect, re-install. Then replace (2nd time) and / or conduct fuel rail pressure test. And data log.
    With no DTC's set could be a challenge. Of course right in front of show weekend. Planning to go to show then dig into it next week. Maybe sooner if I have time I will remove rail / injector assy. myself clean re-install and see if that does anything.
    Suggestions ideas welcomed. (My Dodge tech is an ace he did install by book I was there I know he can find it but appreciate your thoughts; no one on this forum likes a sick kitty...)
  2. hellcat1
    hellcat1 Gold Member
    Sep 27, 2014
    10,672
    2,030
    I thought the fuel system charged itself once you opened the drivers door??
  3. TallCool1
    2,432
    814
    Pacific NW
    No.
    Depress starter button twice minus brake, you will then hear fuel pump. You will barely hear it during normal start.
  4. Themip
    Themip Gold Member
    Nov 15, 2014
    507
    'Murica
    my charger does this every morning. It sputters so bad 2-3 times almost sounds like it is going to shut off. If you press the start button twice as posted above without break on then you hear the fuel pump running to pressurize system and fixes the issue. Sounds crazy with exhaust cutouts open almost like the biggest cam ever lol.
  5. TallCool1
    2,432
    814
    Pacific NW
    Your sputter description sounds just like what my car is doing. It never did it once prior to the fuel line / rail / injector replacement. 1287 miles on car. Recall performed < 150 miles ago. Appreciate the feedback thanks. (And when will you post some revs or ??? with the dumps open? I'm installing NoWeeds but not until next week.)
  6. Themip
    Themip Gold Member
    Nov 15, 2014
    507
    'Murica
    here is my cat on the dyno with cutouts open
    Charger Hellcat Dyno SRT Hellcat Forum
    startup and idle
    inside car with cutouts open
    i do still need to get video outside the car revving and doing a few flybys.
    but yea i never got the fuel rail recall so they must of done mine before i got it delivered. But definitely noticed the rough idle on cold starts where it sounds like it is going to stall out then comes back up to rpm. Some days it will do it 3-4 times if my cutouts are open and it sounds like a wicked cam haha.
    • Like Like x 3
  7. solo7777
    Nov 25, 2014
    3,102
    1,400
    768
    City Of The Angels
    I would try pulling the fuel pump relay(72) (in the trunk), starting till it dies and replacing the relay. Start again till running...who knows? Unless somehow one of the injectors somehow got dirty or something or an o-ring isn't seated properly? Just a wild guess....
  8. TIGwelder
    TIGwelder SSDD
    Feb 12, 2015
    2,439
    943
    668
    Cape Coral, SW Florida
    Air in rails? Do you have a pressure gauge with a releaf valve/drain hose?
    You could see what the pressure is before you start and then hit the bleed into a container while running and see if there is air in the system.
  9. TallCool1
    2,432
    814
    Pacific NW
    Not my own but appreciate your ideas THANKS!
  10. TallCool1
    2,432
    814
    Pacific NW
    Appreciate the share!
  11. solo7777
    Nov 25, 2014
    3,102
    1,400
    768
    City Of The Angels
    Sounds pretty mean!
  12. Daktur
    Daktur Rookie
    May 29, 2015
    5
    2
    Just got delivery of my hellcat challenger and experience the same issue on almost every start up after a few hours. In fact, she won't even fire until the engine has been cranking for 2-3 seconds. I hope this issue can be resolved by the fuel rail recall.
  13. B5 Blue
    1,745
    What happens if it sits for days is it worse?
  14. Daktur
    Daktur Rookie
    May 29, 2015
    5
    2
    Haven't had it for more than a day!!!
  15. Daktur
    Daktur Rookie
    May 29, 2015
    5
    2
    However as per earlier recommendations on this forum, letting the going to accessories and then ignition allows the fuel pump to pressurize the system, then cranking her after a few seconds solves that problem pretty much.
2011 challenger rough starting
2015 challenger rough idle
2015 hellcat cold start stall
dodge challenger hellcat stalling at cold start
hellcat cold start up rpm
hellcat starting problems
